d_a_n1979
Platinum Members
    8,804
  • Days Won
    142
    100%
Everything posted by d_a_n1979
  1. d_a_n1979
    E39 525i
    Low miles, looks very clean & well looked after and with a good spec too; but £5.5k?! Asking a bit much IMO https://www.ebay.co.uk/itm/E39-Bmw-525i-Individual-automatic-35000-mileage-New-MOT/324027625701?hash=item4b718d30e5:g:9FEAAOSwEy1d4--U
  2. d_a_n1979
    Eibach ARB upgrade kit - E39 touring
    Super, thanks pal
  3. Has anyone on here fitted the Eibach 18/27mm ARB upgrade kit to their touring/wagon and if so, what were the differences you found in ride/handling?Also; do you need to replace any bracketry / clips etc, or does the kit come with everything needed to fit it including bolts/bushes and ARB brackets?Thanks
  4. d_a_n1979
    Re the ARB mounts; are they rears or fronts, or both?
  5. d_a_n1979
    Lambdaintergrator 2 not changing
    @Clavurion Any ideas pal?
  6. d_a_n1979
    Air con refresh
    This, IMO, is paramount. It gets musty from lack of use; so it's worth keeping it on all the time (great for coolness in summer and great for demisting in winter)
  7. d_a_n1979
    Airconditioning re-fresh
    Can do; won't really cause any issues and deffo better to not run it through old filters
  8. d_a_n1979
    Air suspension / Changed No air !
    Meyle HD; they're all you need for an every day road going car I sourced mine via BMWmotormec on eBay for c£120 and borrowed the tool off @jimmy ; took us 2 hours to change all 4, that's after I'd doused them in WD40 a few times a week before and the car up on proper ramps etc These are the bushes: https://www.ebay.co.uk/itm/BMW-E39-5-Series-Tourer-Rear-Axle-Rubber-Mounts-X4-Meyle-Heavy-Duty-33311094036/392113678099?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
  9. d_a_n1979
    E34 M5 Touring restoration
    Absolutely stunning @RichardP - every credit to you
  10. d_a_n1979
    HID dim beam aim too low
    You haven't seen me trying to attempt something like this
  11. d_a_n1979
    E39 530i Agean
    Lots in the eBay listings as a 'classic car' https://www.ebay.co.uk/itm/BMW-530i-M-SPORT-AEGEAN-EDITION-2003-ONLY-52-000-Miles/133298117847?hash=item1f092fdcd7:g:OEYAAOSwnKFeFhlL Low miles; looks in excellent condition, but a few £k overpriced maybe?
  12. d_a_n1979
    Tiff drives every m5
    A good watch Out of them all; the E34 wins it for me on looks and interior; there's just something about that old-skool look I really like I'd have that, the E39 and the E60 in all honesty, I like them to be NA
  13. d_a_n1979
    93 525ix tourer
    https://www.ebay.co.uk/itm/1993-BMW-525IX-TOURING-MANUAL-4X4-525I-X-E34-ESTATE-WHITE-5-SERIES-4WD-LOW-MILES/143512397428?hash=item216a016674:g:ob4AAOSwKKBeH39X Looks a solid car! Never seen one that like that before
  14. d_a_n1979
    02 E39 530i saloon
    Very low miles: https://www.ebay.co.uk/itm/2002-BMW-e39-530i-Msport-65848-miles-private-plate-removed-original-RX02-NXU/274227439065?hash=item3fd93aa5d9:g:SUsAAOSw61BeLLZI Looks like it's been driven and cared for by Ray Charles. Needs c£1k minimum of bodywork doing IMO, but could be a good project for someone!
  15. d_a_n1979
    Rear brake overhaul
    Thank you Squire
  16. d_a_n1979
    Rear brake overhaul
    Have you got the specs for these?
  17. d_a_n1979
    What did you do to your E39 today ?
    Meyle or Febi Bilstein one from BMWmotormec for c£20 IIRC pal Good/lucky save though
  18. d_a_n1979
    E39 530 Touring - new wheels
    18" tyres aren't rubber bands on the E39, they were spec'd from factory and ride very well indeed. But, that's on a Sport. On an SE that's not lowered, they'd look lost IMO For an SE, personally I'd go 17s max and Style 32s at that (just ensure they're off an E39 with the correct centre bore) MV2s don't suit the E39 IMO and need silly wide spacers to get the to fit too When it comes to tyre sizes, as Ray said, use willtheyfit, but also use a tyre calculator to ensure you've got specs within the 2.5% +/- so that speedo and diff ratios aren't messed with too much etc 17 Style 32s look well IMO:
  19. d_a_n1979
    Rear sub frame variations
    Sorry, I meant SE and Sport, just mentioned the touring bushes etc
  20. d_a_n1979
    G30 auto gearbox problem?
    You need to pop this question into the relevant G series tech section further down the homepage @Larkey106 - this is just general chat etc You'll get better, more relevant answers from fellow owners
  21. d_a_n1979
    E39 new seats?
    Stunning 530i Sport James; welcome into the forums... Re wiring, as far as I’m aware no it’s not, so you’ll need the seats with the necessary loom & switch pack(s) unfortunately
  22. d_a_n1979
    As far as I’m aware for SE vs Sport, bar the subframe bushes which differ between saloon & touring **As said by Ray below, saloon & touring frames are not the same **
  23. d_a_n1979
    G30 creaking
    Welcome to the forums @Richard Carr Ask your question in the relevant G series tech section further down the homepage. Your question is lost in here with it being general chat and not really car related
  24. d_a_n1979
    E39 touring rear number plate recess
    Thanks, but I think you missed the message above asking for the 2 other part prices also...
  25. Part number: 51138244885 Can you quote a price for this please and also, do you know if it needs any fixings? Reg is SE52 LMV - FYI Cheers
