It is currently Wed Sep 08, 2010 15:06
The Team: Admins: donut, fellie, bigpow, sandip, robbo :: Moderators: alpinaman, alun, duncan-uk, sepia, splondike, rob-the-viking
Click the Shop link to become a Gold Member!
More information here
Post new topic Reply to topic  [ 26 posts ]
Author Message
 Post subject: Urgent 525E help please!
New postPosted: Mon Feb 08, 2010 22:00
Offline
Newbie
I'm trying to get my 525E back on the road. Problem is I need a bit of help figuring out what goes where and was hoping someone on here would have (or could take) pictures of the motor so I can get a better idea. I never stripped the motor down so more as a precaution, but also because of the differences bewteen the normal E30 M20B25 and M20B27 motors.
Much appreciated! :D
Top
 Profile E-mail
 Post subject: Re: Urgent 525E help please!
New postPosted: Tue Feb 09, 2010 01:14
Offline
Advanced Member
Bit dark out there for photography at the moment, or I'd have nipped out and taken a few pics for you. Do you just want general shots of the engine bay or more specific areas.
A quick google search revealed these.
_________________
.........................NEVER QUITE THE SAME........................
Top
 Profile
New postPosted: Tue Feb 09, 2010 07:34
Offline
Newbie
Cheers! those are great. I might need a closer look at some areas as I go along if that's ok? Many many thanks.
Top
 Profile E-mail
New postPosted: Tue Feb 09, 2010 08:50
Offline
Principal Member
User avatar
Current Car: 130i and the hind leg of the dog
525e engine bay complete with tool :wink:
_________________
*your pith*
Top
 Profile
New postPosted: Tue Feb 09, 2010 11:09
Offline
Newbie
Right then.....there are three wires that are on a breakout from the injector harness, two are together and are green and black, the other is a single spade connector with a round rubber shroud. WTF do I do with these? Also....the water pipes on the throttle body......does the top one route back to the thermostat? Or the bottom one? The top one goes but it's a bit of a stretch.
Ta!
Top
 Profile E-mail
New postPosted: Tue Feb 09, 2010 11:18
Offline
Advanced Member
what you need is another 525e beside yours to do the job, maybe some one with one lives near you..
_________________
............................................ Bayerische Motoren Werke............................................
Top
 Profile E-mail
New postPosted: Tue Feb 09, 2010 13:41
Offline
Advanced Member
Took these in case they are any help. 1987 D reg 525e.
Click on thumbnails for larger image.
Image Image Image Image
Image Image Image
Image Image Image
_________________
Top
 Profile
New postPosted: Tue Feb 09, 2010 13:51
Offline
Newbie
Cheers for that, they will help. These are the wires I am on about......
Top
 Profile E-mail
New postPosted: Tue Feb 09, 2010 13:53
Offline
Newbie
Added.....they are so long (even though they come from the same part as the injector harness) that they could go anywhere. I can see a male spade connector on the starter, but not sure if that's where the single one goes. The other two appear to screw onto something.
Top
 Profile E-mail
New postPosted: Tue Feb 09, 2010 14:50
Offline
Advanced Member
Ignition coil
Green +
Black -
I've just stared into the engine bay on mine for a few minutes, and that's the only green and black wires I can see like the ones in your picture. Only thing is, on mine, the coil is on the drivers side of the engine bay (towards the front), Is your coil connected already ? If not, and if the wires stretch to your coil, it could be what they're for. :?:
(coil top, slightly right of centre in 1st picture I posted)
_________________
Top
 Profile
New postPosted: Tue Feb 09, 2010 17:32
Offline
Newbie
Aaah! yes thanks! the little buggers do stretch all the way over, I should have noticed by the odd sizes on the terminals. Damn! Thanks. Just the little black capped one now. Still won't start but I can't hear the fuel pump even though the relay seems to work.
Top
 Profile E-mail
New postPosted: Tue Feb 09, 2010 17:35
Offline
Newbie
BTW....the other wire is on the same main wire as the coil wires, just on it's own from about halfway down the harness. So it breaks off from the coil wire harness about a foot from the coil.
Top
 Profile E-mail
New postPosted: Wed Feb 10, 2010 01:11
Offline
Advanced Member
Sorry, missed that. I think it's the oil light sender wire (on drivers side of engine block).
_________________
Top
 Profile
New postPosted: Wed Feb 10, 2010 06:48
Offline
Newbie
Top bloke you are! Your assistance is much appreciated. I owe you a beer1
Top
 Profile E-mail
New postPosted: Wed Feb 10, 2010 12:31
Offline
Member
User avatar
You never said what year it was, mine's a 1985 & has a different throttle bypass valve arrangement, might be able to get some pics together if you really need them, will take a few days though, as I've recently moved & can't find anything. But if yours looks the same as those posted then I'll keep my nose out to avoid confusing you.
_________________
Image Image
1985 525e (Zinnober Red)
1973 2002 touring (Chamonix)
Top
 Profile E-mail
New postPosted: Thu Feb 11, 2010 18:08
Offline
Newbie
Ok, the fuel pump runs if jumped but not on the key. The car starts with easystart so there's spark. Even if I bridge the relay I get no power to the pump. I have fuel pressure from jumping the pump with 12V direct but even then it still won't start. :roll:
Top
 Profile E-mail
New postPosted: Thu Feb 11, 2010 18:40
Offline
Advanced Member
Is the air flow meter plugged in ? Thought I'd better ask as I could see the wiring connector in your picture.
_________________
Top
 Profile
New postPosted: Thu Feb 11, 2010 18:47
Offline
Moderator
User avatar
cars usually start with disconnected AFM but won't rev.
_________________
www.duncanjamesdesign.com
Need arch rolling? Click here! Archenemy
andyb wrote:
OK I give in I actually quite like the M535i look, especially in white with black wheels
Top
 Profile
New postPosted: Fri Feb 12, 2010 01:53
Offline
Advanced Member
Just another thought. Is the crank sensor where it should be, in a clip, above the crank shaft pulley, and connected ?
Easy start is so volatile I wouldn't be surprised if a car with no coil would start with that, as long as it had compression. Regular use overheats and weakens the piston rings because it burns so hot.
_________________
Top
 Profile
New postPosted: Fri Feb 12, 2010 18:37
Offline
Newbie
Can anyone tell me where the little wire that connects to the top spade connector on the starter solenoid goes to? Ta!
( there's one on the E30 325i that goes into the main harness, but I can't find any wire on this one that would connect to it though the spade looks too clean not to have been used.)
Top
 Profile E-mail
New postPosted: Wed Feb 17, 2010 15:46
Offline
Member
User avatar
It can also bend the con-rods slightly, causing engines to become "addicted" to it. Bad news that stuff, to be avoided at all costs I would say.
_________________
Image Image
Top
 Profile E-mail
New postPosted: Thu Feb 18, 2010 12:22
Offline
Newbie
GOT THE BASTWARD!!!! I pulled the Fi rail off completely to discover that 5 injectors were knackered and one was half way there. Went to scrappy, pulled another rail from a 320i E30 (same injector part no as a 1986 525e so should be fine) swapped injectors and reassembled. Fires up. Yeeee-Haaa! Did all this in the snow, but will wait now till it clears so I can flush the engine and doo all the small checks. Oh, and fit the complete new exhaust.
Top
 Profile E-mail
New postPosted: Fri Feb 19, 2010 15:49
Offline
Member
User avatar
Glad to hear this, well done.
Where did you get your exhaust from? Was it over #250 all in? (that's the best I've been quoted for a standard system, but can go stainless for #440)
(There is NO pound sign on this computer?!!, some idiot has put it onto american settings :roll: & I can't change it!! How very annoying :x :evil: :twisted: )
_________________
Image Image
Top
 Profile E-mail
New postPosted: Fri Feb 19, 2010 16:06
Offline
Newbie
Paid £150 for it from my local factor (who did have to search a bit) for the front/mid box (the two into one with the baffle) and the single pipe rear section.
Top
 Profile E-mail
New postPosted: Fri Feb 19, 2010 17:01
Offline
Advanced Member
Here's one in case you need it.
Quote:
My last keyboard went tits up and several symbols stopped working. I copied them and pasted them into a text document, so I could still use them when needed.
_________________
Top
 Profile
New postPosted: Fri Feb 26, 2010 15:14
Offline
Member
User avatar
Thanks anyway, but the keyboard's fine, it's just the person who set up the computer, but it's shared so I'd better just grin & bear it.
That exhaust price sounds about the same as what I was quoted, only I'm after the whole thing. Certain parts of this 4 piece system seem much more expensive than others, for no real reason. I still haven't made my mind up yet, & the money's not there yet either. I'm even tempted to sell the whole car & buy an e23!
_________________
Image Image
Top
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
The views and comments expressed on this board are the views of individual members not bmw5 as an entity or its staff
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
