Okay... the latest. As suggested in here decided to strip off the AFM and check it for freedom of movement and cleanliness.
Anyway it wasnt so long ago that I adjust the throttle position switch, and whilst this was being done I cleaned out all the pipework that came apart easily. Today after I'd removed the AFM, I noticed a residue inside the pipe connecting the AFM and thottle body. This residue stinks of petrol. I would've thought that this area should be free of fuel, so what is likely to be causing it. Bear in mind I don't have a cold start injector. Any thoughts?
Heres a pic of the area.
and here is another
As you can see theres quite a lot of it smeared around the pipework
Also whilst I've got the AFM off can anyone give me the a circuit diagram / pinout of whats inside.
I tried putting my meter across the pins to see if I could work out the internal connections but apart from some random varying resistor values, I couldnt figure it out. Update :- just read another thread that says this needs to be done reading a voltage instead of a resistance - it just doesnt work apparently, but still need the pinout.
The pins are marked 5 9 E 7 8. On the wiring loom connector there is nothing connected to E
Sorry I seem to have hijacked your thread
robertpat20!
Why dont you pop down your local motor factor and get a length of suitable diameter pipe. Given where it is routed you might get away with not having the specific part as the curvature doesnt look too extreme.
