It is currently Wed Sep 08, 2010 15:16
The Team: Admins: donut, fellie, bigpow, sandip, robbo :: Moderators: alpinaman, alun, duncan-uk, sepia, splondike, rob-the-viking
Click the Shop link to become a Gold Member!
More information here
Post new topic Reply to topic  [ 24 posts ]
Author Message
 Post subject: FRONT AND REAR WINDOW TRIM
New postPosted: Sat Mar 31, 2007 17:55
Offline
Member
Fitted new chrome window trim to the front and rear windscreens this afternoon, took approximatley one hour to fit using washing up liquid and a small flat head srewdriver.
It has totaly transformed the look of the car and it has to be the best 50 quid i have spent in a long time, got it off ebay and i think the bloke still has some available.
Top
 Profile E-mail
 Post subject:
New postPosted: Sat Mar 31, 2007 18:55
Offline
Principal Member
Sounds good - where's the pictures then?
Was the seller donniebmwm535 by any chance? :lol:
_________________
1986 Lachs silver E28 535iSE on 66k.
Fitted 740 front and 540 rear calipers, braided hoses and yellowstuff pads
Sitting on H&R and Spax lowering springs and 17" Alpinas
Top
 Profile
 Post subject:
New postPosted: Sat Mar 31, 2007 23:33
Offline
Advanced Member
I have a back one going spare if anyone doesn't want to buy both.
_________________
_1985 BMW Alpina B2.8______1994 BMW M5______
Top
 Profile E-mail
 Post subject:
New postPosted: Sun Apr 01, 2007 20:20
Offline
Member
User avatar
Hello Chris,
My new chrome set is sitting on a shelf in the garage .... please stick some phots up and a description of how you did it and it might motivate me to get orf my fat 'arris and do mine :oops:
Chris
_________________
"You're only supposed to blow the bloody doors off!"
Top
 Profile
 Post subject:
New postPosted: Sun Apr 01, 2007 21:54
Offline
Member
The best way to do this job is to take your time and start on the rear screen first this is the easier of the two.
First carefully remove the two chrome corners with a small flat head screw driver, put the screwdriver into the rubber seal on the windscreen side and lift upwards, the reason for for putting it into this side is in case it slips, and it will not mark the glass but it would sratch your paint so try and stay on this side of the rubber whenever you are using the screwdriver.
Now pull the old locking strips out, try not to snap them as you want to use these for measuring the new strips.
Now you want a bucket of warm water add some washing up liquid and clean the inside of the rubber seal.
Now get a bottle of fairy liquid and fill the channel in the rubber seal use your finger to get it right into the grooves, dry your hands and you can proceed with the first strip on the drivers side, place the strip in the top corner and slide it down until it locates the grooves in the bottom chrome corner piece, you may have to fiddle about a little to get it into the grooves but sure you will get what i mean, repeat on the opposite side.
Now for the top strip, slide it in form one side until the whole strip is even on each corner now all you need to do is put the chrome corners on and use your screwdriver to ease them below the rubber.
Sure by now you have got the hang of it, but on the front one DO NOT CUT THE NEW STRIP TO SIZE, FIT THE WHOLE STRIP AND THEN CUT OFF THE EXCESS, dont be put off by the two bends it is strong material. Now all you need to do is wash them down with warm water to get rid of the washing up liquid.
I have to say this one of the most satisfying jobs i have done, sure you will feel the same when you see the end result. Will try and post pictures tommorow when i get to work.
The old strips snap easily due to age.
Top
 Profile E-mail
 Post subject:
New postPosted: Tue Apr 03, 2007 10:34
Offline
Member
User avatar
Top write up mate. No excuses now .... :lol:
_________________
Top
 Profile
 Post subject:
New postPosted: Wed Apr 04, 2007 20:38
Offline
Advanced Member
Good write up Chris, did my front last night. My back screen was done some time ago. Excellent advice on keeping to the windscreen side.
BTW I have a back set going - any offers?
_________________
Top
 Profile E-mail
 Post subject:
New postPosted: Tue Apr 10, 2007 01:03
Offline
Newbie
well I would be interested in a set for my e28 84 the strips on my BMW are sun burned and look really nasty, Let me know where or if they are available from a fellow member.
Fred
_________________
THE ULTIMATE DRIVING MACHINE..
Top
 Profile E-mail
 Post subject:
New postPosted: Tue Apr 10, 2007 14:03
Offline
Member
User avatar
Fred,
Try this link, it's where I got mine:
http://cgi.ebay.co.uk/BMW-E28-E12-5-Ser ... dZViewItem
_________________
Top
 Profile
 Post subject:
New postPosted: Wed Apr 11, 2007 12:25
Offline
Newbie
Hi there I have a spare set unused and still wrapped if anyone is interested. Would have transformed the look of the car if I had fitted them on my eta, but sold it for an M535i instead with ALLLLLL black trim...nice!!!
Top
 Profile
 Post subject:
New postPosted: Sun Apr 15, 2007 20:45
Offline
Member
User avatar
Finally done it .. easy job thanks to the write up. Used Meguire's Trim Detailer instead of washing up liquid so now the black rubber is gleaming as well 8) and the tip about using the driver on the windscreen side is priceless.
Cheers chris100 ... not sure what DRP535 was on about (other forum) as the new strip looked bigger than the one I took out :!: Ah, maybe the old one (that looked like it was the original) was also a cheap internet jobbie too :?
_________________
Top
 Profile
 Post subject:
New postPosted: Sun Apr 29, 2007 18:30
Offline
Moderator
User avatar
got some of this trim from morse & thought i'd give it a whirl today! basically its as the write up - i chose to use megs as the lube and also took the opportunity to t-cut and polish under the rubber - its very easy with the trim out so just the rear took me a couple of hours - pics:
Before:
carefull now
found it easiest to pull the trim out from the corners - it then slides off the main chrome easily. once you get one corner out its easy to pull out (mine wasn't brittle):
thinking what it might look like dechromed after a good clean - removed vents - oooh mould gave them a good clean too!
ahhh thats better
Fin! 8)
_________________
www.duncanjamesdesign.com
Need arch rolling? Click here! Archenemy
andyb wrote:
OK I give in I actually quite like the M535i look, especially in white with black wheels
Top
 Profile
 Post subject:
New postPosted: Sun Apr 29, 2007 18:33
Offline
Admin
User avatar
nice work, really makes a difference 8)
_________________
Just an Avus Blue E34 M5 3.8 now 8)
Top
 Profile E-mail
 Post subject:
New postPosted: Sun Apr 29, 2007 18:39
Offline
Moderator
User avatar
it does, front next when i get some more chrome.
thinking i'll have the rear clusters out for a good clean and the front grille next for a scrub!
_________________
Top
 Profile
 Post subject:
New postPosted: Sun Apr 29, 2007 18:43
Offline
Admin
User avatar
my god, you've got that analcleaningofcaronsunnydayitis bad m8!
:lol:
Wanna do mine as well?
_________________
Top
 Profile E-mail
 Post subject:
New postPosted: Sun Apr 29, 2007 19:03
Offline
Moderator
User avatar
:lol: not really - wifes away so thought i'd make use of the time - doing some proper work now :(
Thing is i want the couple of scabby bits doing so when their done this will show up the rest.
I find if you say right i'm gonna blitz the car it ends up as a wash and perhaps a polish.
this way i do one bit for a couple of hours and get a good result the rest might get done a couple of evenings a week - before too long it will be looking spanking again 8)
_________________
Top
 Profile
 Post subject: Re: FRONT AND REAR WINDOW TRIM
New postPosted: Sun Dec 14, 2008 19:14
Offline
Sponsor
User avatar
Can still get these from > Email: info@wallothnesch.com <mailto:info@wallothnesch.com>
> Internet: www.wallothnesch.com <http://www.wallothnesch.com/>got a quote from them for the front.
Thought it not to bad....
thank you for your enquiry. We can offer as follows:
> upper front windscreen chrome strip (plastic) 17,50 EUR
> lower chrome trim (metal) 42,80 EUR
> connectors left or right side 3,00 EUR each
> postage to UK 17,50 EUR
_________________
PPPaints. Based in Swindon M4. Good quality work on most BMWs specializing in E28 and E30.
Welding, body kits repairs or full restos.
Call 01793 637326 for more details
Top
 Profile E-mail
New postPosted: Mon Mar 02, 2009 22:15
Offline
Newbie
Just looking around as new here, I've just had a local firm powder coat ALL the internal and outer chrome finish aluminium door and windscreen trims in hard satin black, for £30, plus another £25 for fine shot blasting. bought new black corners from BMW for about £2.50 each, result is fab! haven't had time to fit them all yet, but quite a transformation. Thats the way to do a dechrome!
Top
 Profile E-mail
New postPosted: Sat Aug 01, 2009 20:13
Offline
Chief Member
User avatar
Current Car: half an '86 520i, and an '86 528i project
I would really hate to throw a spanner in the works here, but it is not a good idea to use washing up liquid to help with fitting screen seals and trim: It contains quantities of salt, which, as we all know, induces corrosion, especially when sandwiched between two layers of seal with no possible exit.
Cooking oil is the ideal substitute.
_________________
1987 520i lux:~~~~~~~~~~~~~~~:1987 528i SE:~~~~~~~~~:100cc Motorised Bath. Dont ask..........
Are Manhole covers politically incorrect?
Top
 Profile E-mail
New postPosted: Wed Aug 26, 2009 09:50
Offline
Member
this is the next job on the list for me... isn't natural rubber slightly soluble in oil hippie dave? at least, that's what it says on this pack of condoms.... I'll be taking Durex's advice and using a water-based lubricant, just in case.
_________________
Top
 Profile
New postPosted: Wed Sep 02, 2009 15:34
Offline
Member
I had the afternoon off today so I got round to fitting the chrome trim- I struggled for about an hour trying to get the first side strip on the rear, using the technique described above (if I understand it correctly?) Sliding it in from the top just wasn't working for me, no matter how much lubrication I used (and I used a lot!) it was just going so far and jamming completely- and that was on the shortest sections- no idea how you would push the 7ft long front section in like that?
So I used a different tactic, and armed with a pair of plastic bicycle tyre levers (a £1 investment and a lot kinder to the rubber/glass/paint-work when the inevitable slips happen), I put one edge under along the full length, and then zipped along with the lever, popping the other edge under- much easier and quicker.
Well pleased, it looks so much better!!... and another job crossed off the list :D
_________________
Top
 Profile
New postPosted: Wed Sep 02, 2009 15:56
Offline
Principal Member
User avatar
:lol: :lol: :lol:
_________________
Image Image
Pat: You wouldn't be advising the use of artificial contraception now Father? Would ya?
Father Ted: Yes I...no I...if you're going to be...I...of course you, you...just feck off!
The Flying Banana wrote:
Hoooolleeeeee f*******k !!!!!!!!
Top
 Profile
New postPosted: Mon Jan 04, 2010 20:56
Offline
Member
User avatar
Ask your friendly local sparky for some "yellow 77" cable pulling lubricant, or use silicone spray or silicone grease, all these are silicone based & are innert, so shouldn't eat the rubber, or anything else for that matter. I haven't done mine yet, but the rear windscreen definately needs doing, I expect once I do it, it'll show the rest of it up & I'll have to do the front as well. A job for the spring, methinks.
_________________
Image Image
1985 525e (Zinnober Red)
1973 2002 touring (Chamonix)
Top
 Profile E-mail
New postPosted: Mon Jan 04, 2010 21:29
Offline
Chief Member
User avatar
Mine needs doing on the 528 but Im tempted to just paint the trims either black or silver.
_________________
Top
 Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
The views and comments expressed on this board are the views of individual members not bmw5 as an entity or its staff
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
