straight_6
Getting steering lock off without the key
Don't know if this is any help, but I think it's the steering wheel that locks on these, not the column. If you don't mind damaging the steering wheel, you could unbolt it, then force it off. It can take a bit of effort, but it can be done. Then remove or disable the spring loaded lock pin to stop it engaging with the cog teeth at the back of the steering wheel.
* this is the Dewhurst method (butchery). There are probably better ways, but I've never had to take a lock barrel off one of these cars.
I know of no easy way of dismantling the steering lock or removing the steering wheel if you don't have the keys. You will need power tools! I've tried before using a lump hammer, chisel and crow bar. Just succeeded in cutting my hands. Ouch.
If you have the V5, the dealer can get you new keys IIRC, problem solved?
you can't remove the wheel with the lock on either
Ummm.... not quite true!
Yup! Can vouch for that!! :lol:
Don't you just remove the small BMW roundel, and then remove the hex nut beneath that holds the wheel on.?. Might help with access to the locking mechanism - or am I talking sh1t?. :lol:
Don't you just remove the small BMW roundel, and then remove the hex nut beneath that holds the wheel on? ...
You can do this but it's not possible to pull the steering wheel off if the steering lock is on, the thing that locks your steering wheel in place when you remove the key.
Stewart
:D
ok, i meant you can't removed the wheel without destroying it in the process!
i used a hacksaw last time :shock:
I got an E28 off some local auction boys years ago for something stupid like £30 including delivery.
It was a runner, but they lost the keys!!
Brute force, a hammer & applied ignorance had the wheel off smartish (I only wanted the car for a few bits & pieces), very little damage to the wheel, the ignition-lock, & steering-lock mech were mullered...!
Eventually had the car driving round the yard!
