stevewilley
On 15/01/2017 at 9:42 PM, Piper said:
Brought her back from the deadB)
Hi Piper,
I've got a 1998 non vans 540 too. As I understand it there are only 5 or 6 of these in the country. Hence I'll be keeping mine & doing it up. Interestingly, mine is green too!
spent about £2k on it since I bought it in Dec 15, but since I got it for £1031, I'm not really complaining. Mot needed soon, but I expect it will pass unscathed. It's had a complete brake overhaul and 4 new tyres recently.
next is the little bits of bodywork.
Straight forward service today.
Worryingly I drained 5 litres of oil out and put 7 in.
Is it common to use a bit of oil on an E39 530d?
Best check my oil level a bit more often!
Your filter would probably hold a litre on its own, so likely you weren't that low
Absinthe makes the tart grow fonder.
1 hour ago, eleanorsskipper said:
Hi Piper,
Sounds good buddy
thinking of getting a f10 520D... went for a test drive in one on saturday:
Took my E39 530d for a 400 mile trip from london to manchester and back on sunday:
Edited by IINexusII
I went from my house in Warwick yesterday, down to Dartford to meet a man who knows his stuff and had number 1 diesel injector replaced. Then drove to Bournemouth for dinner and a catch up and then back up to Warwick. Just the 460 miles as I detoured a couple of times.
Used it for the first time this month when I drove to work..........
I'll admit that I was a little bit excited about using it and I wasn't disappointed!
Replaced the battery. The last one did six years, so seems reasonable. I only use the 5 about once a fortnight at best, so a battery that isn't holding a charge is not much use.  Haven't used the car for a couple of weeks and guess what, the new battery is so flat the locking won't function.  So, chances are high that the there was nothing wrong with the old battery and I've got some fault draining the power. Bugger!  I will have to swop up on what fuse does what and start the long and boring rack of tracking it down.  Been asked many times I'm sure, but what's favourite?
On 13/02/2017 at 5:34 PM, Doddy666 said:
What's that?
Sent from my SM-G935F using Tapatalk
It controls the heaters basically, so when (not if) your heaters either blow flat out cold or do nothing and you can't change any settings on the panel, your hedgehog has died.
I had a look at the wiring loom amp thing I got for pennies and made it work, then found that it had a dicky connection so unplugged it....then drove it home, hit a bump which threw up traction light, abs light and (!) light .....on the bright side at least the abs and (!) light has gone out now so after a few restarts, so I've got that going for me, which is nice.
And it can run your heater motor when your car is parked so it drains your battery.
Fitted my new BM24 unit (thanks Piper) and gave it it's first proper wash of the year, true to form its now pissing down!
Just collected the car from an indy.
It kept going into slow mode - diagnosed as a faulty transmission position switch ( not a cheap part:().
Had the gearbox oil and filter changed at the same time.
General clean inside and out, felt good.
Went over the engine and checked everything is good, then blasted back to london from my parents. If it wasn't for the traffic it would have been amazing.
Bought a new radiator which I'm hoping to fit tomorrow. While I'm there, I'll also replace the oil filter and oil filter housing gasket, the VANOS pipe washers, the drive belts, and the washer for the chain tensioner cylinder. Hopefully, this will sort out most of my oil seepages and my slight coolant leak. Next will be to replace my CCV system.
Collected the recently purchased 530i Individual from my Indy where its had a full service,new viscous fan,new thermostat and discs and pads front and rear also fitted some gloss black bonnet grilles as it had matt black in which i wasn,t keen on.
Replacement of the radiator and oil filter housing gasket went well. Glad I decided to do it on Wednesday, the day before storm Doris :lol: It took about 8hrs from start (waiting for the engine to cooldown) to finish  (packing everything away).
Any pictures Mick?
