mikem
centre console removal
Not aware of any online guides, but I've done it a few times and it's pretty straight forwards. You'll have it out in half an hour.
Off the top of my head...
  • I removed the front seats cos it's much easier to get at some of the screws and to wriggle the console itself out. Sounds drastic but seats out is easy peasy - four bolts on the runners, electrical plug, 1 bolt for the seatbelt and unclip the steel wire for seatbelt height adjustment.
  • Remove front cupholders (two screws) then fingers behind the switch pack above and push it out, then fingers behind the climate control and push that out
  • Remove rear cubby hole under air vents (it clips in at the sides so prise out there)
  • Slide rear air vent down and pull out
  • Two screws and two nuts can now be accessed to remove arm rest and cubby hole underneath
  • Remove the two little carpet panels on the tranny tunnel (one screw then they slide back and off)
  • Remove triangle handbrake lever cover and invert handbrake gaiter out the way
  • Pop out black gear lever surround panel (easiest way is put fingers underneath it by pushing the gear lever gaiter down/under and pull out the panel)
  • Pop out hazard and lock switches
  • Unscrew and remove main trim panel including sliding door storage (or cassette holder if you have that). Having the key in and a foot near the brake pedal so you can move the gear lever if required helps
  • Now you can go round and remove all the screws that hold the console on - couple right at the front that are also through the lower dash, couple underneath where those little carpet panels were, couple (or just one?) inside near the gear lever, couple at the sides towards the rear (under little covers), couple inside right at the back
  • Now its a jiggling act to get it out past the handbrake lever. If I recall you can pull it back till its out from under the dash, then lift up at the front then move it forwards and past the handbrake lever
  • Refitting is reverse of removal :)
Hope that helps (and that I didn't forget too much or get too much wrong).
Edited by Liam79
That sounds like something fitted to Thai spec models...:lol:
Oh yeah forgot to mention disconnect the battery. That's probably cos I'm naughty and don't bother as I seem to be whipping seats in and out so much these days. You only get the airbag light if you go and turn the ignition on while you have a seat unplugged.
