Auto Box Prolems - Has a mind of it's own?
#1
Posted 29 September 2006 - 06:56 PM
Usually the gear changes take place between around 2500 and 3000 rpm
Doing my usual route down a dual carriage way, was cruising around 30 when the car could make up its mind to which gear it should be in.
It would drop down a gear for about 3-4 secs then back up. It was like saying to me "hmm, I wonder what 30 feels like in 3rd, nah, 4th is better, but then again...
This carried on for a few seconds, by then I cheesed off and put into sport mode and then back into drive and then the everything was ok.
Only happens occasionally, tried a battery reset - but its still the same.
Is it the torque converter playing up?
#2
Posted 29 September 2006 - 08:55 PM
#3
Posted 29 September 2006 - 09:04 PM
have a read of this :
IMPORTANT INFO #1:
'It has no memory - it reacts constantly to whoever is driving the car, and to changes in the driving conditions'
'The four main programs are chosen by the way your are driving from moment to moment. So for example, if you press or lift off the accelerator gently, AGS will chose Extra Economy. More determined pressure or quick release will select Extra Sport instantly'
Which would explain why diconecting the battery has no effect and why my mate ragging my car only had a short effect.
IMPORTANT INFO #2:
'AGS knows when the car is cornering hard, and surpresses gear changes to maintain optimum stability and control'
IMPORTANT INFO #3:
'Find a downhill gradient of at least 10% with a clear section of about 500m. Enter the section at a steady 50mph. Slowly take your foot off the accelerator. The car's speed will start to increase - as it does so, gently touch the brakes - AGS will change from fifth to fourth so that the engine's braking pwoer will help to slow the car down.'
IMPORTANT INFO #4:
'If you have been driving for at least three minutes or have driven at more than 62mph, the stop and go traffic program is available.
To experience this for youself, stop, then move off without applying more than 20% throttle, up to a maximum speed of 20mph. The gearbox will select first gear to pull away. Stop again then repeat. Next time, AGS will set off in second gear to give a smoother start. To exit traffic mode simply apply more than 20% throttle'
#6
Posted 30 September 2006 - 04:56 PM
I have heard of that kind of thing for electronic auto's but have no knowledge of whether it applies to the Beemer.Have you heard of this?
My transmission likes to get itself back into the "just cruising" program as quick as it can and defaults to that setting in very few minutes of gentle driving. Equally well it takes very little vigorous use of the accelerator to get it into a "sport" frame of mind, although I usually instigate that program manually when required.
It's a fine transmission IMO.
PS It's best not to use manual downshifting to decelerate the car with engine braking as this can cause premature wear of the transmission bands. Brake pads are a lot cheaper than a transmission rebuild!
#7
Posted 02 October 2006 - 05:19 PM
Are you sure about this? I frequently knock the gearshift into Sport to drop a gear and get some engine braking.
Richard.
1999 535i V8 Steptronic
#8
Posted 02 October 2006 - 11:11 PM
Yes, I'm sure. It's the slippage as the gears change which is the problem area rather than the subsequent engine braking itself. You can reduce the effect by "rev-matching" as you change down, just the same as (I hope) you would with a manual transmission. At the end of the day it's not going to kill your transmission overnight but does lead to accelerated wear.Are you sure about this? I frequently knock the gearshift into Sport to drop a gear and get some engine braking.
#11
Posted 03 October 2006 - 12:25 PM
I would recommend going to a gearbox specialist and having the gearbox sump dropped and cleaned out, a new filter screen and fresh oil - you'd be surprised how 'orrible it looks/smells after 60'000 miles. It'll be about £100 and is well worth it. Mine had done 62'000 when my local BMW dealer did the job and it did upshift better.
#13
Posted 16 November 2006 - 04:32 PM
#14
Posted 17 November 2006 - 10:21 AM
Had a repetition of this one yesterday. Driving south from Leeds the M1 runs slightly uphill. I was on "cruise" at normal speed and the hill caused the transmission to shift down to fourth. Where it stayed. I decided to wait and see how long it would remain in fourth and the and the answer was, for ever! Eventually I had to apply the brakes when coming up behind slower traffic and once the cruise disengaged eveything was back to normal. .
Same thing happened to me from a trip down to london on the M40.
car has done 77k now, will look into changing the gearbox fluid.
#16
Posted 18 November 2006 - 07:56 AM
Since the gearbox having new oil in mine (and adaptions reset), the car drives beautifully.
E39 523i SE, Black - 2000/W
Toyota Rav4 XTR, Black - 2010/10
#17
Posted 27 November 2006 - 03:43 PM
I reckon it has something to do with AGS.
IMPORTANT INFO #1:
IMPORTANT INFO #2:
IMPORTANT INFO #3:
IMPORTANT INFO #4:
Looks familiar!
Just to add, the long term memory is only in respect of clutch pack wear, oil levels etc. Reseting this will actually make it worse AFAIK. The short term memory is the one that affects behaviour.
I'm having issues with the box at present, so much so i'm thinking of swapping for a manual.
With current cash flow issues, i'm going to try the cheaper option of a oil/filter swap and a diff swap to see if i can get it to behave a little better.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
