stebooth
webasto heating.
I don't think BMW added Webasto's to any of their cars, is it an option?
For those who are going Huh  :huh:  They are normally fitted to vans and larger trucks they use the vehicles fuel to pre-heat the coolant circuit and turn on the vehicles heater fan. You can normally hear them whirring away on BT box vans
If memory serves me right and I could be wrong, the webasto heater was an option in this country on all E60/E61`s. It`s not available at all in the US due to restrictions.
All UK X5 diesels came with them standard, alot of 5 series diesels did too Sent from my iPhone using Tapatalk watch out for autocorrect!!
Learn something new everyday
I doubt e60's have it, it's just not cold enough in this country
Your quite right, auxiliary heating as it was called option code S536A was available but I should think it`s rarer then hens teeth.
had it on my 2003 x5 diesel. Was brilliant. I fitted a remote control kit to it aswell!!
i bought a webasto remote heater, i programmed it, closed the car, pressed the webasto heater and got nowt! i was told if you can set the heating to go off at anytime in the climate control, the webasto will be compatible.!!!
as well as the webasto heating query, can anyone tell me how to connect a multichanger cd in the boot, thank you.
CD-changer goes behind the glove box not in the boot.
Shouldnt matter atall. If you put power to pin 7??? off top of my head with a maplin rf remote switching kit, it should kick in automatically, this bypasses all the checks such as fuel level in tank, ambient temp etc.
can you find out exactly what i need please.
How longs a piece of string? I know nothing about your cars spec. You may CD-changer prep and you may have nothing at all. Do some research.
