JCR53S 0 Report post Posted May 30, 2016 Hey Richard, Are you still offering to do these mods? I had a go.. and frankly, I seriously over-estimated my rusty skills with a soldering iron! I might have damaged the board a bit, but do you think (by looking at the photo) that this is salvageable? If so, and if you're still happy to do it, could you pass me your details? Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted May 30, 2016 (edited) That does not look like it's damaged beyond repair. The damage looks like it's not an important part of the board, there are other points to pick up a 5V supply. If you post it together with a stamped addressed envelope for return I'll mod it for you. Edited May 30, 2016 by RichardP Share this post Link to post Share on other sites
Rewmer 2 Report post Posted November 8, 2016 Just remind me, do I have to drill out the via as mentioned ? Its been a couple of years since I did my X5 one. Anyone got a picture with the location ? Share this post Link to post Share on other sites
Rewmer 2 Report post Posted November 12, 2016 Can anyone show which via I have to drill out. Its been a couple of years since I last did this I cant for the love of me remember ? Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted November 12, 2016 Share this post Link to post Share on other sites
Sven Grunewald 0 Report post Posted December 15, 2016 Hi there I have tested this Mod.But i don´t work for me.I´ve drilled the via and solder the cable.KCA420 still works,but Ipod touch 4.gen don´t stand up after start engine.So i´ve to push button in trunk. LOad the ipod also won´t do! Ist the Ipod touch the problem? Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted December 15, 2016 The mod will work for any iPod. However the iPod must be capable of being charged, so all but the earliest Touch will need a charge converter. Does you iPod Touch show the charging symbol? Share this post Link to post Share on other sites
Sven Grunewald 0 Report post Posted December 15, 2016 Must Car engine started?When not my ipod shows "Mit dieser Hardware kann der Ipod nicht geladen werden". So no charging symbol. Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted December 15, 2016 You need a charge converter. Share this post Link to post Share on other sites
Sven Grunewald 0 Report post Posted December 15, 2016 okay thx or other ipod.such like nano gen 2 ?But sleep modus still alive. So i think the mod has not solved correctly by me :/ Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted December 15, 2016 Can you take a picture of what you have done and post it here. Share this post Link to post Share on other sites
Sven Grunewald 0 Report post Posted December 16, 2016 Here ist the pic.Hope u can see? Share this post Link to post Share on other sites
Sven Grunewald 0 Report post Posted December 21, 2016 Hi There After Update my Intravee,the mod still running.Charge Adapter must i look.But i hvae Ipod nano 2.gen. These must still charge,or? Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted December 21, 2016 The mod looks ok as far as I can tell, unless one end of the wire is not making contact. Any iPod Nano with a dock connector should work without a charge converter, so the gen 2 (tall and thin, Aluminium case with curved sides) should charge without one. Share this post Link to post Share on other sites
Sven Grunewald 0 Report post Posted December 22, 2016 Okay.Still testing this.So after that great work from you!Many thx!! Share this post Link to post Share on other sites
Larbel 0 Report post Posted May 19, 2017 Hi guys, New here, only recently did I learned about Intravee, had my '02 E39 M5 since 2005 and the Icelink+ I had finally gave up so Intravee II + KCA-420i it goes... Been trying to read up but I guess I didn't read enough, I did the wake up mod yesterday and it appeared to be working properly (waking up the iPod etc). But after reading a post by Richard saying don't use multi strand wire as it could ruin the KCA-420i and now I'm worried, so two issues, I did the via drilling and wire soldering together, is there anyway now to tell is the via is drilled out properly? And the wire I used is just regular automotive multi strand 18 gauge wire, is that bad even though it's working properly now? Should I take it apart and redo it with single strand wire? Thanks! Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted May 19, 2017 If you have used multi strand wire and it's working, you should be ok. The issue is normally that the wire unravels a bit and can cause a short. drilling out the via is a procaution. The ideal way to check the via is drilled out is to connect and iPod before the wire is added, if the track has been broken the iPod will not charge. If you have drilled right through the board then it will almost certainly be ok. Share this post Link to post Share on other sites
Larbel 0 Report post Posted May 19, 2017 Thanks for the quick reply Richard! Intravee is really worth every single penny! Thank you for keeping this product alive for us late comers! Oh, one my quick question, my car doesn't have Nav computer so it's on the TV module layout, the problem is I can't figure out how to set the clock without GPS, I tried selecting the date etc but nothing worked... Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted May 19, 2017 There are several versions of the TV UI and it's a long time since I've used then to actually 'do' something! There should be a set clock option in the TV UI settings menu, it may be on the 2nd page. Share this post Link to post Share on other sites
