BMW 5 Series Owners Board uses cookies. Read the Privacy Policy for more info. To remove this message, please click the button to the right:    I accept the use of cookies
Will this M-Tech II steering wheel fit my E34?
  • Please log in to reply
11 replies to this topic
#1 HCP
HCP
  • LocationBournemouth
  • Occupation:Graphic Designer
  • Current Car:E46 330ci Sport
Posted 03 August 2012 - 02:06 PM
Quick one, just seen local breakers has an E36 328 with a decent-looking M-Tech II steering wheel on. Could probably pick it up for cheap. Just some questions:
- How do I remove it from the car, what tools do I need?
- Will it fit my E34, 1995 car with airbag steering wheel. I know I can delete the bulb to stop the airbag warning, but will it actually fit somehow?
Posted Image
1996 E34 525iA - gone
2000 E46 323iA - gone
1995 E34 530iA V8 - gone
2002 E46 330ci M Sport
#2 540i/6DB
540i/6DB
  • Current Car:04/'94 540i manual, 06/94 525iT manual +04/'98 728i
Posted 03 August 2012 - 02:18 PM
From my experience no I don't think it will fit straight on.
I had to transfer the top half of the column along with the wheel to fit the one in my airbag-equipped 540. From memory the airbag wheel is held on with a bolt while the M-tech II uses a nut. That was an E34 to E34 swap though.
EDIT: I've just had a look & mine is actually the earlier M-tech I wheel so the above info may or may not be of any use!
Edited by 540i/6DB, 03 August 2012 - 02:32 PM.
E34 540i 6-speed manual, Build No.17-Date 27/04/1994, last 1 of 4 RHD in Diamantschwartz Metallic.
#3 HCP
HCP
Posted 03 August 2012 - 07:38 PM
Cheers buddy. Anyone else know about these? Kinda want to go down in the morning before someone else has it off, if they haven't already...
#4 Idiot
Idiot
  • LocationSW
  • Occupation:CNC Artist
  • Current Car:e34 540iT/6, e34 525i/5
Posted 03 August 2012 - 08:06 PM
sskoda might know, i think it was him that did a big thread of all the different steering wheels that could be fitted. check searchy thing for it.
#5 HCP
HCP
Posted 03 August 2012 - 08:09 PM
Done some looking around and I think that E36 wheels should fit perfectly, but apparently the horn won't work, and I can't find the solution...
#6 Idiot
Idiot
  • LocationSW
Posted 03 August 2012 - 08:15 PM
ive found a shotgun to be much more effective than a horn. hope that helps!
#7 hamish262001
hamish262001
  • LocationDublin
  • Current Car:E34 520 touring
Posted 04 August 2012 - 08:53 AM
http://forum.bmw5.co...teering +wheels
I removed the Sports II Wheel (10th pic down) from my e36 328 and fitted to my 1995 e34 both had air bags
#8 Spice-Boy
Spice-Boy
    Advanced Member
  • Platinum Members
    • Member ID: 29,097
  • 1,521 posts
  • LocationCardiff, S.Wales, UK
  • Occupation:Mobile Automotive Telecommunications Engineer
  • Current Car:E34 525i sport in Avus blue
Posted 05 August 2012 - 07:29 PM
YES! It will certainly fit...
The later E34 (facelift) used the same spline as the E36 so that is the actual one you will need...
The biggst issue you will encounter will be the fact your horn wont work... But I have found a work around for this involving an earth strap that you can pick up from most motor factors :)
When you remove the airbag from your current steering wheel be careful (disconnect your battery) as someone I know set one off by accident whilst removing it... Although this is unlikely but safetly first!
If you have any specific questions then leet me know as I have done exactly what you are about to do :)
Craig
Building a Stroked and Twin Screw Supercharged '530i' - M54 parts have arrived!!
#9 HCP
HCP
Posted 05 August 2012 - 09:15 PM
Well unfortunately the wheel was gone when I got there.
Awesome Craig, I may PM you if I get hold of one in the near future, cheers!
#10 Spice-Boy
Spice-Boy
    Advanced Member
  • Platinum Members
    • Member ID: 29,097
  • 1,521 posts
Posted 05 August 2012 - 09:19 PM
Thats a shame!
Well aslong as you source an E36 M-Tech 2 wheel then you will be able to fit it... For the older cars it's the E30 item that is needed :)
Craig
#11 HCP
HCP
Posted 05 August 2012 - 09:22 PM
Is the e36 wheel a lot smaller than the "sport" standard e34 airbag wheel? that's the main reason I'd like to change it..
#12 bigtelbmw
bigtelbmw
  • LocationNorthumberland
  • Occupation:Retired detective
  • Current Car:1995 E34 520
Posted 07 August 2012 - 11:33 AM
Hi
I found from experience that there are two sizes of splines 20mm & 25mm and the horn does not work unless you add an earth to it. My 96 E34 has the rarer 25mm. Good luck.
Terry
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
