UPDATE: WORKS! Wire colours? Retro-fitting BMW reverse parking sensors.
  • Please log in to reply
10 replies to this topic
#1 Trisman
Trisman
  • LocationCowfold, Nr.Horsham, W.Sussex.
  • Occupation:Project Management, Construction industry.
  • Current Car:E39 '532i' Touring. 'E12 M535i. E24 635CSi manual. Papa Smurf 540i.
Posted 21 February 2012 - 08:42 PM
I thought this would be simple... :neutral:
Got the Sensors, trims, looms, black-box and sounder unit,
There are 5 wires on the loom that connects to the car.
Two blue wires (red trace on one, white on the other). = Sounder unit.
Brown (black trace) = Earth.
Easy!  :)
Then there's the  green wire (white trace) and white wire (Black trace).
When I checked on the donor car, both show 12 volts with the ign. on, regardless of whether reverse is selected or not.
The system works fine when it is plugged back into the donor car...
What's going on?! :?
Edited by Trisman, 10 March 2012 - 12:11 AM.
Trisman.
Current: E39 Touring B10 3.2 replica in Oxford Green.
Alpina 3.2 engine & gearbox mit flappy paddles, 19" alloys, spoiler etc.
E12 M535i Kashmir Gold.  E24 635CSi manual, work-in-progress...
Gone:  E39 '00 530i Sport manual Red.
'98 528i SE Auto Arctic Silver. (237k miles!)
E28 M5 No.8, (now Conan's). E28 M535i NO2 Monster, Red.
E24 635CSi, Blue, E28 M5, Lach silver.
(Click here for my very old site).
#2 rob-the-viking
rob-the-viking
  • LocationCambs
Posted 21 February 2012 - 09:05 PM
There's a how to guide in the sticky at the top of the E39 forum Tris if that helps mate.
Posted Image
I bought the wife a Memory Stick, it's great!  She hasn't forgotten my beer, dinner or sex once since the first beating.
www.marhamtrackday.co.uk
#3 Trisman
Trisman
Posted 21 February 2012 - 09:33 PM
D'oh!   Should have looked a bit harder..!
Cheers :)
Trisman.
#4 Trisman
Trisman
Posted 21 February 2012 - 10:06 PM
The PDF files are for 1998 & later cars...
Mine is a 1997.
However, it looks like the installation is identical, save for the wiring colours.
One wire goes to switched 12v supply, the other to the I-bus.  Problem is, which wire.....?
Trisman.
#5 rob-the-viking
rob-the-viking
  • LocationCambs
Posted 21 February 2012 - 11:06 PM
WDS is your friend tris, or i'll look for you tomorrow night.
Posted Image
#6 Trisman
Trisman
Posted 21 February 2012 - 11:36 PM
Cheers!  I've been looking at WDS, doesn't help that the colour codes for the wires are in German!  :lol:
The I-bus wire is either: WS GR GE or WS RT GE.
From that, I'd guess the white/black-trace wire is power, green/white-trace goes to the I-bus.
Suspect this'll need coding..
Plus, is there anything on the I-Bus I can take a feed from in the boot/load area?  (Touring, donor & recipient).
Edited by Trisman, 21 February 2012 - 11:42 PM.
Trisman.
#7 know-dice
know-dice
  • LocationReading, Berkshire
  • Current Car:E39 530d
Posted 22 February 2012 - 10:31 AM
You need this :-)
Posted Image
#8 Clavurion
Clavurion
  • LocationFinland
Posted 22 February 2012 - 12:08 PM
Checking the retrofit instructions from EBA. Green/white wire should be voltage from fuse 21. Didn't find that white/black wire on them. I/K-bus should always be white wire with red/yellow or gray/yellow stripe. Different stripe colour depending if it's I- or K-bus (high or low OBC). Check the pin numbers they are on the connector. That should define things. You can connect the bus wire in parallel to any place you find it. From WDS you can find the connector locations for I/K-bus.
E39 530dA M-Sport
#9 jimmy
jimmy
  • LocationTeesside
Posted 22 February 2012 - 07:20 PM
CD  changer.
Regards
Jimmy
jimmy@e28m5.co.uk
E60 525d Sport
E39 530d Sport
E39 530d Sport Touring
E34 M5 3.8/6
E28 M5 #70
E28 M5 #31
2005 4.6 Savage
Posted Image
#10 Trisman
Trisman
Posted 23 February 2012 - 02:52 PM
Thanks chaps!  I think it's sorted, just need to fit it now, once the rear bumper is repainted....
Trisman.
#11 Trisman
Trisman
Posted 10 March 2012 - 12:10 AM
My recent late night car jobs haven't gone too well,  see:  Ooops..  but I thought I 'd connect anything up & see what happened...
I wasn't to hopeful...
It works!! :)
I found an IBUS cable within the battery compartment, but weirdly, I couldn't find an ignition switched live...  So I used a switched live that comes on with the stereo system.
Plugged it all in and it works 100%!  No coding or messing around & I now have rear reverse sensors.
So:  Does anyone know the wiring colour codes for an ignition switched-live in (or near) the rear battery compartment in a Touring?
Edited by Trisman, 10 March 2012 - 12:34 AM.
Trisman.
