RichardP 1,038 Report post Posted February 15, 2012 (edited) I've got a problem with my one touch window close function, the front windows won't go up using one touch.The windows use to respond to one touch opening, now they don't, I'm not sure exactly when they stooped so I can't easily relate it to anything I've done.The rear windows work as they should, one touch up and one touch down.The front windows work for one touch down but not one touch up.Same for 'comfort close' (press and hold lock/unlock on the remote), the front and rear windows open, only the rear windows close.I've checked the coding using SSS Progman, all windows are coded for one touch opening and closing and comfort open and close.Looking at the status in INPA it reports all the correct switch contacts.Doing tests in INPA the windows all respond correctly to one touch open and one touch close.Anyone any ideas where to look? Edited February 17, 2012 by RichardP Share this post Link to post Share on other sites
Paddy O'Furniture 583 Report post Posted February 15, 2012 I know the one-touch doesn't work when the drivers door is open (not sure about other doors) so maybe the car thinks there's a door open. Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 I know the one-touch doesn't work when the drivers door is open (not sure about other doors) so maybe the car thinks there's a door open.Checked that, the car does register that all doors are closed.Try uncoding it with SSS & recoding it ?Tried that too, made no difference. Share this post Link to post Share on other sites
ally 92 Report post Posted February 15, 2012 Does the passenger window not work on one touch with both switches? Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 The passenger window does not do one touch up with the passenger door switch either. Share this post Link to post Share on other sites
andy_ran 499 Report post Posted February 15, 2012 it could be a fault with the safety anti pinch, I know if you activate the anti pinch you have to "reset" the windowIts normally done just by opening the window all the way, then in one go closing it. Then it should operate as per normal. Could be related? Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 Do you know if there is any way of checking the anti-pinch?I've tried resetting the windows by pressing and holding the close button for 30 seconds and that made no difference. I'd guess that they must have been fully opened and closed at some point since they stoped one touch close, but I'll give it a try. Share this post Link to post Share on other sites
andy_ran 499 Report post Posted February 15, 2012 (edited) I know the UP part has to be from the very bottom to the very top in one go if that helpsThe only way i can think of trying it is to put something in the way as the window goes up. It should get to a set pressure and then reopen the windowI would only suggest not your head or arm Edited February 15, 2012 by andy_ran Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 Tried the 'open fully and close in one go' reset, no change.Looked to see if there was any errors in the GM as I've seen that the anti trap errors can prevent one touch from working, there were no errors.Tested the rear anti trap with a rolled up towel, it works fine. I could not test the front anti-trap on one touch because it does not work, but there does not appear to be any anti-trap for the front windows when pressing the button, they just stop, you can see the load in INPA, they cut off when the trigger current is reached.As far as I can tell, everything is functioning correctly, just one touch closing/comfort closing does not work on the front windows. Share this post Link to post Share on other sites
andy_ran 499 Report post Posted February 15, 2012 ummm..... i shall ponder it some more Share this post Link to post Share on other sites
DAB-Andy 18 Report post Posted February 15, 2012 I had a similar problem, no one-touch and no lights on the drivers side. Turned out to be the switch itself (or to be more precise the connectors on the bolttom of it), I think I broke it fitting my speakers, a bit of jiggling has "fixed" it for now. Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 I had a similar problem, no one-touch and no lights on the drivers side. Turned out to be the switch itself (or to be more precise the connectors on the bolttom of it), I think I broke it fitting my speakers, a bit of jiggling has "fixed" it for now.I've checked the switch and wires quite carefully, but not tried another switch yet, but everything looks fine and the passenger door switch does not work either. I guess it's possible that there is a break in the wire where it goes through the door to the body, but INPA is detecting the switch position OK and it seems odd that both front windows don't go up even when using comfort closing. I'm suspecting it may be the GM itself, but how come it works when controlled through INPA? Share this post Link to post Share on other sites
andy_ran 499 Report post Posted February 15, 2012 I have a spare switch unit if you want to test that Richard. The sorround is broken but it works perfectly. Share this post Link to post Share on other sites
Raymond 1,192 Report post Posted February 15, 2012 Not much help but the same happened with my neighbours 530d. Exactly the same symptoms.I replaced the jamming protection switches in all four doors, the driver window switch pack and all three passenger window switches, the GMIII module and the problem was still there.Car was sold so I never got to the bottom of it.Maybe Clavurion can shed some light? Share this post Link to post Share on other sites
richteo 0 Report post Posted February 15, 2012 If you've had the door cards off be aware that the plug and sockets for the anti-trap strip and the tweeters in the door card are the same. If you cross-connect them one-touch up won't work. Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 I think that's my next port of call, door cards off and examine the connections.I can't recall the one touch up working since my respray back last March, maybe the did not reconnect the anti-trap or connected it up incorrectly - I'd like to think I'd notice the tweeters not working though! Share this post Link to post Share on other sites
Raymond 1,192 Report post Posted February 15, 2012 (edited) Don't forget the one for the chromatic mirrors which also fits.On yours the yellow connector is purple though. Edited February 15, 2012 by Raymond Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 Is that yellow connector, tha you say is purple in my car, the connector for the trap sensor, the tweeter or the chromatic mirror? I seem to remember that the tweeter was purple, but it's a while since I've been in there. Share this post Link to post Share on other sites
Raymond 1,192 Report post Posted February 15, 2012 The yellow/purple one is for the chromatic mirror. The tweeter comes of the speaker in the door and the black one on the main loom is the trap sensor one. Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 15, 2012 OK thanks for that, I'm pretty sure that both the tweeter and chromatic mirrors are working correctly, but it's worth knowing what's what just to make sure. Share this post Link to post Share on other sites
Clavurion 370 Report post Posted February 15, 2012 Antitrap sensor should have nothing to do with this. CLICKIf you have access to NCSexpert check the parameters on GM.This should be ece:FH_ABSCHALTKRITERIUM ece usAll of these should be active:FH_TUEREN_HINTEN_TIPP_AUF aktiv nicht_aktivFH_TUEREN_HINTEN_TIPP_ZU aktiv nicht_aktivFH_BEIFAHRERTUER_TIPP_AUF aktiv nicht_aktivFH_BEIFAHRERTUER_TIPP_ZU aktiv nicht_aktivFH_FAHRERTUER_TIPP_AUF aktiv nicht_aktivFH_FAHRERTUER_TIPP_ZU aktiv nicht_aktiv Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 16, 2012 Antitrap sensor should have nothing to do with this. CLICK If you have access to NCSexpert check the parameters on GM. This should be ece: FH_ABSCHALTKRITERIUM ece us All of these should be active: FH_TUEREN_HINTEN_TIPP_AUF aktiv nicht_aktiv FH_TUEREN_HINTEN_TIPP_ZU aktiv nicht_aktiv FH_BEIFAHRERTUER_TIPP_AUF aktiv nicht_aktiv FH_BEIFAHRERTUER_TIPP_ZU aktiv nicht_aktiv FH_FAHRERTUER_TIPP_AUF aktiv nicht_aktiv FH_FAHRERTUER_TIPP_ZU aktiv nicht_aktiv This is the entire output from NCSExpert. Values highlited in red. All the 'TIPP' values are 'aktiv', but the FH_ABSCHALTKRITERIUM is set to 'us'.LASTBEREICHSKENNFELDnicht_aktivDRUCKSENSOR_FAHRER_1nicht_aktivDRUCKSENSOR_BEIFAHRER_1nicht_aktivDRUCKSENSOR_FAHRER_2nicht_aktivDRUCKSENSOR_BEIFAHRER_2nicht_aktivDRUCKSENSOR_FAHRER_3nicht_aktivDRUCKSENSOR_BEIFAHRER_3nicht_aktivCRASH_SPEICHERgrundcode_varVERRIEGELUNGaktivSIDEBAG_FOND_LINKS_1aktivSIDEBAG_FOND_RECHTS_1aktivSIDEBAG_FOND_LINKS_2aktivSIDEBAG_FOND_RECHTS_2aktivITS_RECHTS_1aktivITS_LINKS_1aktivITS_RECHTS_2aktivITS_LINKS_2aktivGURTSCHLOSS_STROMSS_1nicht_aktivGURTSCHLOSS_STROMSS_2nicht_aktivBPLUS_TRENNUNG1_1aktivBPLUS_TRENNUNG2_1nicht_aktivBPLUS_TRENNUNG1_2aktivBPLUS_TRENNUNG2_2nicht_aktivKOPFBAG_FOND_LINKS_1aktivKOPFBAG_FOND_RECHTS_1aktivKOPFBAG_FOND_LINKS_2aktivKOPFBAG_FOND_RECHTS_2aktivFOND_MODUL_1nicht_aktivUEBER_ROLLSENSOR_1nicht_aktivFOND_MODUL_2nicht_aktivUEBER_ROLLSENSOR_2nicht_aktivZAE2_EMULATION_1mrs_modusZAE2_EMULATION_2mrs_modusMRS1_EMULATION_1mrs3_modusMRS1_EMULATION_2mrs3_modusDRUCKSENSOR_1nicht_aktivDRUCKSENSOR_2nicht_aktivKINDER_SBE_1nicht_aktivKINDER_SBE_2nicht_aktivKSE_A/D_1analogKSE_A/D_2analogSBE_A/D_1digitalSBE_A/D_2digitalGURTSCHLOSS_A/D_1analogGURTSCHLOSS_A/D_2analogABLAUFSTEUERUNG_1nicht_aktivABLAUFSTEUERUNG_2nicht_aktivNICHT_BELEGTwert_01HWL_1nicht_aktivHWL_2nicht_aktivSBE2_1nicht_aktivSBE2_2nicht_aktivVERRIEGELN_SITZLEHNE_FA_1nicht_aktivVERRIEGELN_SITZLEHNE_BF_1nicht_aktivVERRIEGELN_SITZLEHNE_FA_2nicht_aktivVERRIEGELN_SITZLEHNE_BF_2nicht_aktivCRASHPARAMETER_0e39CRASHPARAMETER_01e39CRASHPARAMETER_02e39CRASHPARAMETER_03e39CRASHPARAMETER_04e39CRASHPARAMETER_05e39CRASHPARAMETER_06e39CRASHPARAMETER_07e39CRASHPARAMETER_08e39CRASHPARAMETER_09e39CRASHPARAMETER_0Ae39CRASHPARAMETER_0Be39MRSAPARAMETER_0e39KOMFORTSCHLIESSUNGaktivFH_FAHRERTUER_TIPP_AUFaktivFH_FAHRERTUER_TIPP_ZUaktivFH_BEIFAHRERTUER_TIPP_AUFaktivFH_TUEREN_HINTEN_TIPP_AUFaktivFH_TUEREN_HINTEN_TIPP_ZUaktivQUIT_AKUST_DAUER_10_MSnicht_aktivQUIT_AKUST_DAUER_20_MSnicht_aktivQUIT_AKUST_DAUER_40_MSnicht_aktivDME_FREIGABEcodiertes_signalSCHLUESSELAUSWERTUNGwechsel_codeZEIT_BIS_AUTOM_SPERRENwert_01CODIERUNG_ERFOLGTcodierung_erfolgtFEHLVERSUCH_ZAEHLER0_unberechtigte_zugriffeMAIN_SWITCHmultifunktionslenkradLDA_BEI_VERBRAUCHERnicht_aktivLDA_BEI_UNTERSPANNUNGnicht_aktivZUSATZWASSERPUMPEaktivK_ZAHL_TACHO4812_imp/kmK_ZAHL_TACHO_KOMPL4812_imp/kmTANK_SICHERHEITSFAKTOR1.3FEHLERZAEHLERgrundcode_varFEHLER_1_CODEgrundcode_varFEHLER_1_ARTgrundcode_varFEHLER_2_CODEgrundcode_varFEHLER_2_ARTgrundcode_varFEHLER_2_HAEUFIGKEITgrundcode_varFEHLER_3_CODEgrundcode_varFEHLER_3_ARTgrundcode_varFEHLER_3_HAEUFIGKEITgrundcode_varFEHLER_4_CODEgrundcode_varFEHLER_4_ARTgrundcode_varFEHLER_4_HAEUFIGKEITgrundcode_varFEHLER_5_CODEgrundcode_varFEHLER_5_ARTgrundcode_varFEHLER_5_HAEUFIGKEITgrundcode_varWEGSIGNAL_QUELLEabs_sensorTANK_ADC_FEHLER_UGwert_01TANK_ADC_FEHLER_OGwert_01TANK_FILTER_NACHTANKERK1.1_l/secTANK_FILTER_KL157_schritteTANK_FILTER_FALLEND1.9_l/minTANK_FILTER_STEIGEND0.9_l/minTANK_SCHWELLE_RESERVE10_lTANK_MITTLUNGSZEIT5_secTANK_BERUHIGUNGSZEIT10_secKUEHLMITTELTEMP_FEHLER_1wert_01KUEHLMITTELTEMP_FEHLER_2wert_01FEHLER_1_HAEUFIGKEITgrundcode_varDIMMSCHWELLE_TAG/NACHTwert_01TACHO_AUF_DAEMPFUNGwert_01LWS5_KENNFELD_0e39LWS5_KENNFELD_1e39LWS5_KENNFELD_2e39LWS5_KENNFELD_3e39LWS5_KENNFELD_4e39LWS5_KENNFELD_5e39LWS5_KENNFELD_6e39GETRIEBEhandschaltungGETRIEBE_TYPhandschaltungPARK/NEUTRAL_EINGANGnicht_aktivMRA_TAKTUNGaktivSCHLUPFSCHWELLENOFFSETnicht_aktivSCHLUPFBANDMODIFIKATIONnicht_aktivAMR_TYPtyp_3BMR_TYPtyp_2K_ZAHL_WEG4764_imp/kmK_ZAHL_WEG_KOMPL4764_imp/kmSTEIGUNG_EINSPRITZ_KENNLcan_busZYLINDER_ZAHL8_zylinderMOTOR_ARTbenzinerMOTOR_FAKTOR4_imp/umdrehungSPRACHEenglischFGR_KENNDATENe39_m62b44_autZEIT_EINHEIT12_stundenTEMPERATUR_EINHEITgrad_cWEGSTRECKE_EINHEITmlsWEG_DURCHSCHNITTmphWEG_REICHWEITEmlsVERBRAUCH_D1mpg_ukDWAaktivSCHAERFEN/ENTSCHAERFENnur_mit_fernbedienungPANIK_MODUSnicht_aktivFUNK_INNENRAUMSCHUTZaktivQUIT_AKUST_DAUER_80_MSaktivQUIT_AKUST_SCHAERFnicht_aktivQUIT_AKUST_ENTSCHnicht_aktivQUIT_OPT_ENTSCHnicht_aktivQUIT_OPT_SCHAERFaktivNEIGUNGSGEBERaktivALARM_AKUSTISCHintervalltonABSCHALTDREHZAHL_ANLASSER8_zylinder_benzinerZEITDAUER_BIS_ABSCHALTUNGbenzinerSCHALT_KRITERIUM_EWS_38_zylinder_benzinerEWS_3_SCHNITTSTELLEaktivCAN_INSTR2_SENDENaktivCAN_INSTR3_SENDENaktivCAN_GANGANZEIGEkonventionellCAN_VERBRAUCHcan_busCAN_KUEHLMITTELTEMPcan_busCAN_DREHZAHLcan_busCAN_FLAGinfo_ueber_can_busMOTOR_OELSTAND_PREDRIVEaktivHBAaktivBREMSFLUESSIGK_INVaktivHECKKLAPPE_ENTSICHERNaktivSOFT_ON/OFFaktivFH_ABSCHALTKRITERIUMusFENSTERHEBER_HINTENaktivFH_BEIFAHRERTUER_TIPP_ZUaktivEINKLEMMSCH_REVERSIERENlangALARM_AKUSTISCH_LANGaktivUMLUFT_MEMORYnicht_aktivLL/RLrechtslenkerLENKSEITE_1rechtslenkerLENKSEITE_2rechtslenkerSTANDLUEFTUNGaktivSTANDHEIZUNGnicht_aktivGURTWARNUNGohne_gurtschlosskontaktGURTWARNUNG_GONGnicht_aktivGONG_T3aktivTANK_KENNLINIE70_l_prozentskalaTANK_SCHWELLE_AUF/AB5.0_lSIA_GRENZE_ZEIT716_tageSIA_ANZEIGEPARAMETERmit_zeitinspektionSIA_LITER_GRENZEs62b50_mj99KUEHLMITTELTEMP_ADC_WERTkennlinie_04WARNUNG_GESCHW_LIMITnicht_aktivANZEIGE_KVA/OELkvaBC_CODE_AKTIVnicht_aktivSCHWELLE_UEBERDREHZAHLmax_wertDZM_SKALA_ENDWERT7000_u/minDZM_AUF_AB_DAEMPFUNGmotorsportAUSTAUSCHPUNKTnicht_aktivGURTSTRAFFER_FAHRER_1aktivGURTSTRAFFER_FAHRER_2aktivGURTSTRAFFER_FAHRER_3aktivGURTSTRAFFER_BEIFAHRER_1aktivGURTSTRAFFER_BEIFAHRER_2aktivGURTSTRAFFER_BEIFAHRER_3aktivAIRBAG_FAHRER_1aktivAIRBAG_FAHRER_2aktivAIRBAG_FAHRER_3aktivFAHRERBAG_STUFE2_1aktivFAHRERBAG_STUFE2_2aktivAIRBAG_BEIFAHRER_1aktivAIRBAG_BEIFAHRER_2aktivAIRBAG_BEIFAHRER_3aktivBEIFAHRERBAG_STUFE2_1aktivBEIFAHRERBAG_STUFE2_2aktivGURTSCHLOSS_SPANNUNGSS_1nicht_aktivGURTSCHLOSS_SPANNUNGSS_2nicht_aktivGURTSCHLOSS_FAHRER_3nicht_aktivGURTSCHLOSS_FAHRER_1nicht_aktivGURTSCHLOSS_FAHRER_2nicht_aktivGURTSCHLOSS_BEIFAHRER_1nicht_aktivGURTSCHLOSS_BEIFAHRER_2nicht_aktivGURTSCHLOSS_BEIFAHRER_3nicht_aktivERKENNUNG_SITZBELEGUNG_1aktivERKENNUNG_SITZBELEGUNG_2aktivERKENNUNG_SITZBELEGUNG_3aktivAUSLOESEKRITERIUM_1eceAUSLOESEKRITERIUM_2eceAUSLOESEKRITERIUM_3eceSIDEBAG_LINKS_1aktivSIDEBAG_RECHTS_1aktivSIDEBAG_LINKS_2aktivSIDEBAG_RECHTS_2aktivB_SATELLIT_2aktivB_SATELLIT_1aktivCODIERANFORDERUNG_0e39CODIERANFORDERUNG_1e39SATZZEIGER_AIRBAGfeder_hochohmTRIGGERSCHALTER_1aktivTRIGGERSCHALTER_2aktivBAUREIHEe39CRASHPARAMETERe39CRASHPARAMETER_11e39CRASHPARAMETER_12e39CRASHPARAMETER_13e39CRASHPARAMETER_14e39CRASHPARAMETER_15e39CRASHPARAMETER_21e39CRASHPARAMETER_22e39CRASHPARAMETER_23e39CRASHPARAMETER_24e39CRASHPARAMETER_25e39AUSSENTEMP_ANZ_FEHLER_1wert_01AUSSENTEMP_ANZ_FEHLER_2wert_01AUSSENTEMP_DELTA_K1wert_01AUSSENTEMP_WARNUNG_GONGaktivAUSSENTEMP_ZEITKONST_Z1wert_01AUSSENTEMP_ZEITKONST_Z2wert_01AUSSENTEMP_ZEITKONST_Z3/5wert_01AUSSENTEMP_ZEITKONST_ZKwert_01BC_CODEgrundcode_varDAUER_UEBERDREHgrundcode_varOFFSET_GESAMTWEGSTRECKEgrundcode_varJAHRESZAHL_BC2003KVA_SKALA_ENDWERT30_lOELTEMPERATUR_ADC_WERTnicht_aktivOELTEMPERATUR_FEHLER_1untergrenzeOELTEMPERATUR_FEHLER_2obergrenzeOELTEMPERATUR_SKALAnicht_aktivKALIBRIERFAKTOR_VERBRAUCHwert_01TACHO_SKALA_ENDWERT155_mph_e39TANK_ANZEIGEWINKELkennlinie_01DIMMUNG_ADC_WERTkennlinie_01DIMMUNG_FOTOTR_PWM_WERTkennlinie_01DZM_OFFSETbenzinerKUEHLMITTELTEMP_ANZEIGEWIkennlinie_01TACHO_OFFSET155_mph_e39TACHO_OFFSET_KOMPL155_mph_e39TACHO_SKALA_ENDWERT_KOMPL155_mph_e39TANK_UMRECHENKONSTANTE_12932TANK_UMRECHENKONSTANTE_21050_ohmLICHTWARNUNGaktivANZEIGEGERAETEbordmonitorKVA_OFFSET15_gradTANK_VORHALT_REICHWwert_01WEG_EINHEITmlsWEG_LIMITmphZEIT_ANKUNFT12_stundenZEIT_TIMER112_stundenKURVENLOGIKtyp_1MRAGRENZwert_01FEHLER_3.BREMSLEUCHTEmeldenKALTUEBERWACHUNGwert_01KALTUEBERWACHUNG_NSWaktivANPRESSDRUCKVERSTELLUNGnicht_aktivSCHEIBENINTENSIVREINIGUNGaktivSCHEINWERFERREINIGUNGaktivEDC_KENNFELDdv074DME_ACaktiv_highPRUEFSTEMPELgrundcode_varTLNR_KBBgrundcode_varVERBRAUCH_D2mpg_ukZEIT_TIMER212_stundenZEITINSPEKTIONS_ZAEHLER_0grundcode_varZEITINSPEKTIONS_ZAEHLER_1grundcode_varZEITINSPEKTIONS_ZAEHLER_2grundcode_varLETZTER_SERVICEgrundcode_varSIA_LITER_ZAEHLER_0grundcode_varSIA_LITER_ZAEHLER_1grundcode_varSIA_LITER_ZAEHLER_2grundcode_varSLEEP_MODEgesch_pull_upZUHEIZBETRIEBbm_ab_pu96AKUSTIK_PARKBREMSEaktivCAN_ASCcan_busEBVaktivKUEHLMITTELTEMP_WERTkennlinie_01TACHO_AB_DAEMPFUNGwert_01TOG_ANZneuWPaktivZUENDSCHLUESSEL_WARNUNGnicht_aktivAKUSTIK_ABBLENDLICHTaktivAKUSTIK_BREMSLICHTaktivAKUSTIK_HECKKLAPPEaktivAKUSTIK_RUECKLICHTaktivAKUSTIK_TUERENaktivAKUSTIK_WASCHWASSERaktivAUSSENTEMP_WARN_AKUSTIKaktivBUS_OFFnicht_aktivCAN_RXD_ERRORnicht_aktivCC_ABBLENDLICHTaktivCC_BREMSLICHTaktivCC_HECKKLAPPEaktivCC_RUECKLICHTaktivCC_TUERENaktivCC_WASCHWASSERaktivEHC_PREDRIVEnicht_aktivLCM_FLAGdaten_vom_lcm_ueber_k_busSENDERATE_EMV_TESTnormalCAN_INSTR1_SENDENaktivCAN_KVA_TASKaktivCAN_SIA1_SENDENnicht_aktivL_HEIZ_INITnicht_aktivAKUSTIK_BATT_WARNUNGnicht_aktivAKUSTIK_RDKSaktivBATTERIE_WARN_SCHWELLEnicht_aktivEHCnicht_aktivFUNKUHRnicht_aktivFUNKUHR_STATUSnicht_aktivGAL_LOWkennlinie_01GESCHW_GAL_GONGkennlinie_01RDKSaktivBC_KL_RaktivBC_V_KORREKTURnicht_aktivCAN_EBVnicht_aktivCAN_KL61konventionellGPS_UHRnicht_aktivRCC_UHRnicht_aktivRCC_WECKZEITnicht_aktivSIA_RESET_SCHWELLE_LITERwert_01SIA_RESET_SCHWELLE_TAGwert_01TNK_DECKEL_WARNUNGnicht_aktivASC3_AUSWERTUNGnicht_aktivBFD_AX_REF_SCHWELLEwert_02BFD_AX_REF_SCHWELLE_2wert_02BFD_HYSTERESEwert_01BRAKE_FORCEnicht_aktivBRAKE_FORCE_2nicht_aktivCAN_ABSkonventionellCAN_S_GSUnicht_aktivDSC_DEF_GONGnicht_aktivGURTWARNUNG_EURO_NCAPnicht_aktivKL_50_CANnicht_aktivWEG_EURO_NCAPwert_01ACC_FLAGnicht_aktivACC_V_SET_MAXv_max_accACC_V_SET_MINv_min_accALCnicht_aktivANKUNFTSZEIT_VON_NAVInicht_aktivE_LUEFTERnicht_aktivMEMO_FLAGmemo_lcmALARM_OPT_ABBLENDLICHTnicht_aktivALARM_OPT_FERNLICHTnicht_aktivALARM_OPT_WARNBLINKERaktivBAUREIHE_SERVOTRONIKe39DWA_NOTENTSCHAERFENaktivFONDGEBLAESEnicht_aktivGLASDACHnicht_aktivIR_FERNBEDIENUNG_BFnicht_aktivKOMFORTOEFFNUNGaktivLENKSAEULENMEMORYnicht_aktivLEUCHTWEITENREG_AUTOMnicht_aktivLUFTFEDERUNGnicht_aktivPM_SCHIEBEHEBEDACHaktivPM_SITZMEMORYaktivPM_SITZMEMORY_BEIFAHRERnicht_aktivQUELLE_SERVOTRONIK_KENNFromSCA_HECKKLAPPEnicht_aktivSCHIEBEHEBEDACH_TIPP_AUFaktivSCHIEBEHEBEDACH_TIPP_ZUaktivSERVOTRONIKnicht_aktivSERVOTRONIK_KENNLINIEe39_kennlinie_03SPIEGELEINKLAPPENaktivSPIEGELHEIZUNGaktivSPIEGELMEMORYaktivTUERKONTAKT_LOGIKoffenTUERKONTAKT_VORNan_gmUEBERWACH_FENSTER_BF_HInicht_aktivUEBERWACH_FENSTER_BF_VOnicht_aktivUEBERWACH_FENSTER_F_HInicht_aktivUEBERWACH_FENSTER_F_VOnicht_aktivUEBERWACH_HECKSCHEIBEnicht_aktivVERRIEGELN_AUT_AB_X_KM/Hnicht_aktivWEGFAHRSICHERUNG_AUTOMnicht_aktivWISCHERINTERVALL5_secWISCHERPOTInicht_aktivZV_SELEKTIVnicht_aktivABKLAPPSTELLUNGnicht_aktivBC_ANFORD_WEGFAHRSICHnicht_aktivCLT_AKTIV_IM_CRASH_MODEnicht_aktivCODIERUNG_ERFOLGT_1codierung_erfolgtCODIERUNG_ERFOLGT_2codierung_erfolgtDWA_QUITTIERUNGaktivENTFALL_ZV_BEDIENST_HECKaktivENTR_KL.R_30S_NACH_SICHnicht_aktivENTSICHERN_CENTERLOCKnicht_aktivFH_AUF_STUFE2_KLR_AUSaktivFH_TIPP_DISABLE_TUER_AUFaktivFUNKINNENRAUMSCHUTZ_HInicht_aktivHYDRAUL_HECKKLAPPEnicht_aktivIB_EIN_HK_AUFnicht_aktivINNENLICHT_AN_MEHRFACH_ZVaktivK_BUS_FB_SPERRENaktivKEY_MEMORYaktivKOMFORTOEFFNUNG_FBaktivKOMFORTSCHLIESSUNG_FBaktivLIM/TOURINGlimousineNOTSTROMSIRENEaktivPM_SCHALTERBLOCK_FONDnicht_aktivSEL_ZV_SENDER_1nicht_aktivSEL_ZV_SENDER_2nicht_aktivSEL_ZV_SENDER_3nicht_aktivSEL_ZV_SENDER_4nicht_aktivSERVO_KENNL_GESCHWkennlinie_03SERVO_KENNL_STROMkennlinie_03SONDERFHZG_MIT_WSAnicht_aktivSPERRZEIT_KL_R_AUS_0.2_SaktivSPERRZEIT_KL_R_AUS_0.4_SaktivSPERRZEIT_KL_R_AUS_0.8_SaktivSPERRZEIT_KL_R_AUS_1.6_SaktivSTANDRUECKSCHALTUNGnicht_aktivVERRIEGELN_XKM/H_SENDER_1nicht_aktivVERRIEGELN_XKM/H_SENDER_2nicht_aktivVERRIEGELN_XKM/H_SENDER_3nicht_aktivVERRIEGELN_XKM/H_SENDER_4nicht_aktivVERZUG_PANIK_MODUS_0.2_SaktivVERZUG_PANIK_MODUS_0.4_SaktivVERZUG_PANIK_MODUS_0.8_SaktivVERZUG_PANIK_MODUS_1.6_SaktivWEGSIGNAL_SERVO_ABSaktivZV_ENTR_SCHL_BEI_DWA_AKTaktivZV_VR_BEDIENSTELLE_HECKnicht_aktivAUTO_ZV_DISABLEnicht_aktivVERRIEGELN_AUT_NACH_2_MINnicht_aktivVERRIEGELUNGSSCHWELLE16_km/hZV_BEDIENST_BT_DISABLEaktivBAUREIHE_AaktivBAUREIHE_Bnicht_aktivBAUREIHE_Cnicht_aktivCRASH_DISABLE_HECKKL_10Snicht_aktivDEB_TIME_CS_0nicht_aktivDEB_TIME_CS_1nicht_aktivDEB_TIME_CS_2aktivDEB_TIME_CS_3nicht_aktivDEB_TIME_CS_4nicht_aktivDEB_TIME_CS_5aktivDEB_TIME_CS_6aktivDEB_TIME_CS_7nicht_aktivDWAH_PIN_C17aktivFS_UNLOCK_300MS_P_BUSaktivHYD_HECKKLAPPE_OHNE_PDCnicht_aktivIB_CRASH_ON_0_KMHnicht_aktivIB_POWER_CONF_0nicht_aktivIB_POWER_CONF_1aktivIB_POWER_CONF_2aktivIB_POWER_CONF_3aktivIB_POWER_CONF_4nicht_aktivIB_POWER_CONF_5aktivIB_POWER_CONF_6aktivIB_POWER_CONF_7aktivK_BUS_FS_UNLOCK_300MSaktivOEH_POWER_CONF_0nicht_aktivOEH_POWER_CONF_1aktivOEH_POWER_CONF_2aktivOEH_POWER_CONF_3aktivOEH_POWER_CONF_4nicht_aktivOEH_POWER_CONF_5aktivOEH_POWER_CONF_6aktivOEH_POWER_CONF_7aktivOPT_ENTRY_HELPnicht_aktivPASSIVES_DWA_HORNnicht_aktivRDC_ALARM_VIA_HFKaktivRDC_ALARM_VIA_KBUSnicht_aktivSPZ_PROGnicht_aktivSRA_L322_RELAYnicht_aktivVA_2nicht_aktivZV_AGGREGATE_TYPnicht_aktivABTASTFREQ_HINTERACHSEwert_01ABTASTFREQ_VORDERACHSEwert_01ACHSE_OBERGRENZEwert_01ACHSE_UNTERGRENZEwert_01AGRENZEkennlinie_03ANSTEUERZEITkennlinie_01BGRENZEwert_01DAUER_SCHNELLE_REGELUNGwert_01DELTA_SCHNELL_LANGSAMwert_01DELTAWERTE_HINTERACHSEe39DELTAWERTE_VORDERACHSEe39_highERKENNUNG_BREMSLICHTaktivGRENZTEMPERATURwert_02INDEX_MOTORANSTEUERUNGwert_01KL_30_UGRENZEwert_01KURZSCHLUSS_ANZAHLwert_01MAXIMALPOSITIONwert_01MIN_SCHRITT_DIFF1_schrittMOTOR_KORREKTURe39_highMOTOR_OFFSETwert_01MOTORDIAGNOSEaktivMOTORTABELLE_CHECKSUMe39_highOPENLOAD_ANZAHLwert_01REFERENZ_OFFSETwert_01REFERENZFAHRT_PAUSEwert_01REFERENZPOSITIONwert_01SENSOR_OBERGRENZEwert_01SENSOR_UNTERGRENZEwert_01STATUS_LESENaktivSTEIGUNG_HINTERACHSEfallendSTEIGUNG_VORDERACHSEfallendTACHO_A_SPRUNGwert_01V_BEREICHSFELDkennlinie_01V_OFFSETkennlinie_01WARTEZEIT_MOTORwert_01ABBLENDLICHT_PRUEFmeldenANHAENGERLI_PRUEFmeldenBREMSBELAG_PRUEFmeldenBREMSFLUESS_PRUEFmeldenBREMSLICHT_PRUEFmeldenEINSPRITZANLAGEmeldenFERNLICHT_PRUEFmeldenFEUERLOESCH_PRUEFmeldenFUNKSCHL_BATTERIEmeldenGETRIEBE_NOTPROGRmeldenGURT_ANLEGENmeldenGURTWARNUNG_TEXTnicht_aktivI_GONG_GURTmeldenKAT_ZU_HEISSmeldenKAT_ZU_HEISS_PRDmeldenKENNZEICHENLI_PRUEFmeldenKOFFERRAUM_OFFENmeldenKUEHLMITTELSTAND_PRUEFmeldenKUEHLMITTELTEMPmeldenLICHT_ANmeldenLIMITmeldenLUFTANLAGE_PRUEFmeldenMELDUNG_KATALYSATORnicht_aktivMOTOR_KENNFELDm62b44_mj99MOTOR_NOTPROGRAMMmeldenMOTOR_TYPm62b44MOTOR_UEBERTEMP130_grad_celsiusNEBELLI_HI_PRUEFmeldenNEBELLI_VO_PRUEFmeldenNIVEAUREG_INAKTIVmeldenOELDRUCK_MOTORmeldenOELST_MOTOR_PRUEFmeldenPANZERTUER_OFFENmeldenPARKBREMSE_LOESENmeldenRUECKFAHRLICHT_PRUEFmeldenRUECKLICHT_PRUEFmeldenSCHWELLENm62b44SICHERHEITSFAHRZEUGnicht_aktivSTANDLICHT_PRUEFmeldenTUER_OFFENmeldenVORGLUEHENmeldenWASCHWASSER_FUELLmeldenZUENDSCHL_STECKTmeldenDME_K_AB=0kompressor_ausDME_KOaktiv_lowDME_SCHNITTSTELLEkonventionellENTFROSTUNGSANTEILwert_01KENNFELDKUEHLUNGaktivKOMPRESSOR_GEREGELTaktivKOMPRESSORAUSTAKTUNGnicht_aktivUNTERSPANNUNGSSCHWELLENwert_02ZUHEIZUNGnicht_aktivFUSSRAUMKURVENwert_01AUSSENTEMPERATUR_KORRaktivKOMPRESSOR_TRANSPORT_SICHnicht_aktivHEIZUNGS_STEUERGERAETihrSCHRITTMOTOR_UEBERLAUFaktivSTANDHEIZUNG_KONZEPTnicht_aktivDIAGNOSE_SCHRITTMOTORaktivEC_LUEFTERaktivWASSERPUMPEnicht_aktivZUHEIZERkonventionellBEDIENTEIL_ANZEIGEnicht_aktivGEBLAESE_KONZEPTwert_01DIAGNOSE_ZWPnicht_aktivGEBL_OFF_MODEaktivGEBLAESE_BALKENaktivGEBLAESEAUTOMATIKwert_01GEBLAESEAUTOMATIK2wert_01KEY_MEMORY_IHKaktivKLAPPENPOSITIONy_fahrerSOLARSENSORaktivTEMP_FONDaktivABFRAGEZEIT_AHMwert_01ABSCHALTUNG_UNTERSPGwert_01ENTPRELLZAHL_FEHLERERKwert_01FEHLER_ABBLENDLICHTmeldenFEHLER_ANHAENGERmeldenFEHLER_BREMSLICHTmeldenFEHLER_FERNLICHTmeldenFEHLER_KENNZ_LICHTmeldenFEHLER_NSL_LINKSmeldenFEHLER_NSL_RECHTSmeldenFEHLER_NSWmeldenFEHLER_RUECKFAHRSCHEINWmeldenFEHLER_RUECKLICHT_INNENmeldenFEHLER_SCHALTER_BREMSLmeldenFEHLER_STANDLICHTmeldenKALTUEBERWACHUNG_ALnicht_aktivKALTUEBERWACHUNG_FLaktivMELDUNG_AENDERUNG_DIMMERwert_01PROGRAMMPARAMETER_LCMeceSCHALTER_BREMSL_SCHWELLWwert_01SCHALTER_BREMSL_WARTEZEITwert_01TASTVERH_KL_58G_MINwert_01WARNBLINKEReinfachimpulsZUWACHS_TASTVERH_KL_58Gwert_01ABSTAND_HOLD_NORMAL_MODEwert_01BEWERTUNG_FEHLERaktivBEWERTUNG_FEHLER_30aktivBEWERTUNG_FEHLER_31aktivBEWERTUNG_FEHLER_32aktivBORDNETZe38/e39_highDELAYwert_01DFAMHwert_01DFAMKwert_01DFAMLwert_01DFAMVwert_01EEPROM_LCMCmeldenEINSPRITZANLAGE_CANaktivFEHLER_RUECKLICHT_AUSSENmeldenFKT50wert_01GONG_1kein_gongGONG_2gong_t3GONG_3interm_gongGONG_4doppelgongGONG_5gong_t1&t2GONG_6gong_t2HALB/VOLLSCHRITTvollschrittHEIZKwert_01HEIZWwert_01HYSTERESE_STARTBEDINGUNGwert_01HZMAX_Hwert_01HZMAX_Lwert_01HZMIN_Hwert_01HZMIN_Lwert_01I_GONG_PARKBREMSEmeldenKALTUEBERWACHUNG_BLK_HInicht_aktivKALTUEBERWACHUNG_BLK_VOaktivKUEHLMITTELUEBERTEMP_CANaktivKUMAX_Hwert_01KUMAX_Lwert_01KUMIN_Hwert_01KUMIN_Lwert_01MANUELLE_LWRnicht_aktivMOTKALTwert_01MOTOR_NOTPROGRAMM_CANaktivNNORMwert_01NORMHwert_01POSITION_0wert_01POSITION_2wert_01R_POTI_STELLUNG_0wert_01R_POTI_STELLUNG_2wert_01R_Vwert_01REIFEN_DEFEKTmeldenSCHN._KLEMMENW-ERKENNUNG3_secSCHN._KLEMMENW-UNT.DRUECK2_secSCHRITTABSTAND_GRENZEwert_01SCHRITTABSTAND_STARTPHASEkennlinie_01SENKO_Hwert_01SENKO_Lwert_01SENMULwert_01SENTGwert_01TEMPERATUR_GRENZEgrad_-20TESTBETRIEBnicht_aktivTOGKALTSwert_01TOKRIwert_01TOMAXwert_01TTX_S_(CODE)meldenTTX_S1_1meldenTTX_S1_2meldenTTX_S1_3meldenVORGLUEHEN/KAT_HEIZEN_CANaktivDRL_DIMMUNGwert_01ABS_MIN_STELLUNG_2wert_01ACC_ABSTAND_ANZnicht_meldenACC_INAKTIVnicht_meldenAL_ALS_DRLnicht_aktivALARMSCHALTER_SI_FZGnicht_aktivALARMSCHALTER_TAXInicht_aktivAUSBLENDUNG_VORGLUEHEN1.0_sekundenBITTE_SCHALTENnicht_meldenBL_ALS_SL_DIMMENnicht_aktivBL_GEDIMMT_ALS_ERSATZaktivBL_UND_BLK_H_GEMEINSAMnicht_aktivBLK_V_GED_ALS_SIDEMARKnicht_aktivBLK_V_GEDIMMT_ALS_ERSATZaktivCAN_AUSFALL_BEWERTUNGaktivFL_DIMMUNG_ALS_DRLwert_01FL_UND_NSW_NICHT_GLEICHZnicht_aktivGED_FL_ALS_DRLnicht_aktivGURT_MRSgurtmeldung_von_mrsHEIMLEUCHTENwert_02HEIMLEUCHTEN_ALaktivHEIMLEUCHTEN_BLnicht_aktivHEIMLEUCHTEN_FLnicht_aktivHEIMLEUCHTEN_KL58GaktivHEIMLEUCHTEN_KZLaktivHEIMLEUCHTEN_NSWnicht_aktivHEIMLEUCHTEN_SL_HaktivHEIMLEUCHTEN_SL_VaktivKEINE_PARKLICHT_FUNKTnicht_aktivKUEHLWASSER_BEDAEMPFUNG25_sekundenLADEZST_BATTnicht_meldenLENKSTOCKSCHALTER_ANALOGaktivLICHTBEDIENEINHEITnicht_aktivNSL_R_NICHT_ANSTEUERNnicht_aktivOELST_SENS_DEFnicht_meldenOELST_SENS_DEF_WARNUNGnicht_aktivOELSTAND_MOTOR_CANaktivPER_DAUER_DIMMwert_01PIKTOGR_BL_DEF_BLINKTnicht_aktivPIKTOGRAMM_ERWEITERTnicht_aktivPROGRAMMPARAMETER_LCM_1ecePROGRAMMPARAMETER_LCM_10ecePROGRAMMPARAMETER_LCM_11ecePROGRAMMPARAMETER_LCM_12ecePROGRAMMPARAMETER_LCM_13ecePROGRAMMPARAMETER_LCM_2ecePROGRAMMPARAMETER_LCM_3ecePROGRAMMPARAMETER_LCM_4ecePROGRAMMPARAMETER_LCM_5ecePROGRAMMPARAMETER_LCM_6ecePROGRAMMPARAMETER_LCM_7ecePROGRAMMPARAMETER_LCM_8ecePROGRAMMPARAMETER_LCM_9eceRUECKLICHT_INNEN_FEHLTnicht_aktivSCHALTER2_BLnicht_aktivSCHRITTE_STELLUNG_0wert_01SCHRITTE_STELLUNG_1wert_01SCHRITTE_STELLUNG_2wert_01SENSOR_SAEUBERNnicht_meldenSTANDLICHT_VORNEaktivTAGFAHRLICHT_ECEnicht_aktivTANKDECKL_OFFENnicht_meldenTASTER_NSW_NSLaktivU_DIMMUNG_STANDLwert_03U_GEDIMM_BLK_Vwert_01U_GEDIMM_BREMSLwert_02U_POTI_DIMM_DELTAwert_01U_POTI_DIMM_MINwert_01U_POTI_STELLUNG_0wert_03U_POTI_STELLUNG_1wert_03U_POTI_STELLUNG_2wert_03WASCHWASSER_SENSORwaschwasser_altZUENDSCHL_GONG_R_EINaktivZUENDSCHLUESSEL_KBUSaktivAUSBLENDUNG_VORGLUEH_CAN0.7_sekundenBETR_STD_AUTO_LOESCHnicht_aktivBL_DIMMUNGS_OPT_1nicht_aktivBL_GED_ALS_ERSATZ_MIT_AHaktivBL_UND_BLK_H_GEM_BLKnicht_aktivBL_UND_BLK_H_GEM_WBLnicht_aktivBLK_DIMMUNGS_OPT_1nicht_aktivBLK_DIMMUNGS_OPT_2nicht_aktivBLK_V_GED_ALS_PARKLICHTnicht_aktivBLS_PRUEFENnicht_aktivCHECK_FILL_CAPnicht_meldenE52_LINKS_LENKERnicht_aktivE52_RECHTS_LENKERnicht_aktivHEIMLEUCHTEN_ABBRUCHaktivHEIMLEUCHTEN_NSLnicht_aktivHEIMLEUCHTEN_RFSnicht_aktivLED_RUECKLICHT_OPTIONaktivNSW_KEIN_TASTERaktivPULS_TIME_OPTIONnicht_aktivREIFENCONTR_INAKTIVmeldenRL_INNEN_BLINKTnicht_aktivSL_INNEN_ALS_TWLnicht_aktivSL_VORNE_ALS_ZUSATZ_BLKnicht_aktivTAGFAHRLICHT_DANnicht_aktivZUENDSCHLUESSEL_GONGZEIT30_minutenAUTOM_FAHRL_STEUERGaktivBFD_MINDEST_GESCHWwert_01BFD_OPTIONnicht_aktivBFD_STUFE_2_MAX_EINwert_01BFD_STUFE_2_VERZOEGwert_01DSC_INAKTIVnicht_meldenDWA_BLK_ABSCHALTENnicht_aktivFLC_DIMMER_OPTIONaktivFLC_KL58Gwert_02FLC_KL58G_AENDERUNGwert_01NSL_AH_US_OPTIONnicht_aktivRFS_AH_OPTIONnicht_aktivTASTER_NSLaktivTASTER_NSWnicht_aktivXENONLICHT_ZUEND_OPTIONaktivABSENKUNG_10_KM/Hwert_01ABTASTRATE_DYNwert_01ABTASTRATE_TRENDwert_01ABWEICHUNG_TRENDwert_01ANHEBUNG_175_KM/Hwert_01ANZAHL_QUICK_RUNDENwert_01AUSWERT_GRADIENTnicht_aktivAUSWERT_PROP_ABWEICHUNGnicht_aktivBI_XENONnicht_aktivCC_MELDUNG_AL_LaktivCC_MELDUNG_AL_RaktivCC_MELDUNG_BL_LaktivCC_MELDUNG_BL_MaktivCC_MELDUNG_BL_RaktivCC_MELDUNG_BLK_LHnicht_aktivCC_MELDUNG_BLK_LVnicht_aktivCC_MELDUNG_BLK_LZnicht_aktivCC_MELDUNG_BLK_RHnicht_aktivCC_MELDUNG_BLK_RVnicht_aktivCC_MELDUNG_BLK_RZnicht_aktivCC_MELDUNG_FL_LaktivCC_MELDUNG_FL_RaktivCC_MELDUNG_KZLaktivCC_MELDUNG_NSL_LaktivCC_MELDUNG_NSL_RaktivCC_MELDUNG_NSW_LaktivCC_MELDUNG_NSW_RaktivCC_MELDUNG_RFS_LaktivCC_MELDUNG_RFS_RaktivCC_MELDUNG_SL_LHaktivCC_MELDUNG_SL_LHInicht_aktivCC_MELDUNG_SL_LVaktivCC_MELDUNG_SL_RHaktivCC_MELDUNG_SL_RHInicht_aktivCC_MELDUNG_SL_RVaktivDAUER_DYN_NACHFUEHRUNGwert_01DEF_LWR_SENSOR_HIwert_01DIFFERENZ_MSP_DYN_STATwert_01ENABLE_EURO_NCAPnicht_aktivEPSILON_DELTA_Awert_01EPSILON_DELTA_AVwert_01FERTIGUNGSMODEwert_01GETRIEBE_UEBERTEMPnicht_meldenGRADIENT_SCHLECHTWEGnicht_aktivHOEHENWEGwert_01I_GONG_GURT_NCAPmeldenKALTUEBERWACHUNG_AL_LaktivKALTUEBERWACHUNG_AL_RaktivKALTUEBERWACHUNG_BL_LaktivKALTUEBERWACHUNG_BL_MaktivKALTUEBERWACHUNG_BL_RaktivKALTUEBERWACHUNG_BLK_LHaktivKALTUEBERWACHUNG_BLK_LVaktivKALTUEBERWACHUNG_BLK_LZnicht_aktivKALTUEBERWACHUNG_BLK_RHaktivKALTUEBERWACHUNG_BLK_RVaktivKALTUEBERWACHUNG_BLK_RZnicht_aktivKALTUEBERWACHUNG_FL_LaktivKALTUEBERWACHUNG_FL_RaktivKALTUEBERWACHUNG_KZLaktivKALTUEBERWACHUNG_NSL_LaktivKALTUEBERWACHUNG_NSL_RaktivKALTUEBERWACHUNG_NSW_LaktivKALTUEBERWACHUNG_NSW_RaktivKALTUEBERWACHUNG_RFS_LaktivKALTUEBERWACHUNG_RFS_RaktivKALTUEBERWACHUNG_SL_LHnicht_aktivKALTUEBERWACHUNG_SL_LHInicht_aktivKALTUEBERWACHUNG_SL_LVaktivKALTUEBERWACHUNG_SL_RHnicht_aktivKALTUEBERWACHUNG_SL_RHInicht_aktivKALTUEBERWACHUNG_SL_RVaktivKENNLINIE_LWR_SENSOR_HIwert_03KENNLINIE_LWR_SENSOR_VOwert_02LEUCHTWEITENREG_DYNAMnicht_aktivLEUCHTWEITENREGELUNGaktivLWR_AUT_EXTERNaktivLWR_NEIGUNG_KONSTANTEwert_01LWR_VORZEICHENnicht_aktivM_TELEGRAMnicht_aktivMIN_STEIGUNG_VZ_WECHSELwert_01MINDESTANZAHL_VZ_WECHSELwert_01MITTELUNGSINTERV_DYNwert_01MITTELUNGSINTERV_TRENDwert_01MITTELUNGSINTERV_VZ_WECHSwert_01NACHLAUF_SCHLECHTWEGwert_01OFFSET_LWRwert_02PROGRAMMPARAMETER_LCM_14ecePROGRAMMPARAMETER_LCM_15ecePROGRAMMPARAMETER_LCM_16ecePROGRAMMPARAMETER_LCM_17ecePWM_ANSTEUERUNG_AL_Lwert_02PWM_ANSTEUERUNG_AL_Rwert_02PWM_ANSTEUERUNG_BL_Lwert_01PWM_ANSTEUERUNG_BL_Mwert_01PWM_ANSTEUERUNG_BL_Rwert_01PWM_ANSTEUERUNG_BLK_LHwert_01PWM_ANSTEUERUNG_BLK_LVwert_01PWM_ANSTEUERUNG_BLK_LZwert_01PWM_ANSTEUERUNG_BLK_RHwert_01PWM_ANSTEUERUNG_BLK_RVwert_01PWM_ANSTEUERUNG_BLK_RZwert_01PWM_ANSTEUERUNG_FL_Lwert_01PWM_ANSTEUERUNG_FL_Rwert_01PWM_ANSTEUERUNG_KZLwert_01PWM_ANSTEUERUNG_NSL_Lwert_01PWM_ANSTEUERUNG_NSL_Rwert_01PWM_ANSTEUERUNG_NSW_Lwert_01PWM_ANSTEUERUNG_NSW_Rwert_01PWM_ANSTEUERUNG_RFS_Lwert_01PWM_ANSTEUERUNG_RFS_Rwert_01PWM_ANSTEUERUNG_SL_LHwert_01PWM_ANSTEUERUNG_SL_LHIwert_01PWM_ANSTEUERUNG_SL_LVwert_01PWM_ANSTEUERUNG_SL_RHwert_01PWM_ANSTEUERUNG_SL_RHIwert_01PWM_ANSTEUERUNG_SL_RVwert_01REFERENZL_MODE_TEIL1wert_01REFERENZL_MODE_TEIL2wert_01REFERENZL_SCHRITTABSTANDwert_01REFERENZL_SCHRITTANZAHLwert_01SAETT_TIMER_SCHLECHTWEGaktivSCHW_GRAD_BESCHLEUNIGUNGwert_02SCHW_GRAD_BREMSENwert_02SCHW_GRADIENT_SCHLECHTWEGwert_01SCHW_PROP_ABWEICHUNGwert_01SCHW_TRENDwert_01SP_MOTOR_BEWERTENnicht_aktivSP_MOTOR_F_EINTRAGnicht_aktivSP_MOTOR_STOPnicht_aktivSPG_NACHREGELUNG_0wert_01SPG_NACHREGELUNG_1wert_01SPG_NACHREGELUNG_2wert_01SPG_NACHREGELUNG_3wert_01SPG_NACHREGELUNG_4wert_01SPG_NACHREGELUNG_LANGSAMnicht_aktivTDAUER_GURTWARNUNGwert_01TREIBER_BEWERTENnicht_aktivTREIBER_F_EINTRAGnicht_aktivTVERZ_GURTWARNUNGwert_01VMAX_BESCHLEUNIGUNGwert_02VMAX_BREMSENwert_01VMIN_BESCHLEUNIGUNGwert_01VMIN_BREMSENwert_01VMIN_GURTWARNUNGwert_01WARMUEBERWACHUNG_AL_LaktivWARMUEBERWACHUNG_AL_RaktivWARMUEBERWACHUNG_BL_LaktivWARMUEBERWACHUNG_BL_MaktivWARMUEBERWACHUNG_BL_RaktivWARMUEBERWACHUNG_BLK_LHaktivWARMUEBERWACHUNG_BLK_LVaktivWARMUEBERWACHUNG_BLK_LZnicht_aktivWARMUEBERWACHUNG_BLK_RHaktivWARMUEBERWACHUNG_BLK_RVaktivWARMUEBERWACHUNG_BLK_RZnicht_aktivWARMUEBERWACHUNG_FL_LaktivWARMUEBERWACHUNG_FL_RaktivWARMUEBERWACHUNG_KZLaktivWARMUEBERWACHUNG_NSL_LaktivWARMUEBERWACHUNG_NSL_RaktivWARMUEBERWACHUNG_NSW_LaktivWARMUEBERWACHUNG_NSW_RaktivWARMUEBERWACHUNG_RFS_LaktivWARMUEBERWACHUNG_RFS_RaktivWARMUEBERWACHUNG_SL_LHnicht_aktivWARMUEBERWACHUNG_SL_LHInicht_aktivWARMUEBERWACHUNG_SL_LVaktivWARMUEBERWACHUNG_SL_RHnicht_aktivWARMUEBERWACHUNG_SL_RHInicht_aktivWARMUEBERWACHUNG_SL_RVaktivZEIT_KALT_PULSEwert_01ZEIT_KALT_PULSE_QUICKwert_01ZEIT_KALT_RUNDENwert_01ZYKLUS_KALT_RUNDEN_QUICKwert_01ABSCHALT_KL50nicht_aktivALC_AL_DEFEKT_TIMERwert_01ALC_COUNTER_NOKwert_01ALC_COUNTER_OKwert_01ALC_EIN_SCHWELLEwert_01ALC_FAILSAFE_41_51nicht_aktivALC_FAILSAFE_51_52nicht_aktivALC_FAILSAFE_FCTnicht_aktivALC_LED_DEFnicht_aktivALC_LED_DUTYwert_01ALC_VERBAUTnicht_aktivCOD_IFLnicht_aktivCOD_IFL_AN_PIN48nicht_aktivCOD_IFL_ASYNCnicht_aktivFLC_LED_EINaktivKL50_ABSCHALT_ALnicht_aktivKL50_ABSCHALT_FLaktivKL50_ABSCHALT_NSWaktivSPG_NACHREGELUNGnicht_aktivSPG_NACHREGELUNG_ZUSATZnicht_aktivTOENS_SCHWELLENm62b44UEBERSPANNUNG_OFFSETwert_01UEBERSPANNUNG_TIMEOUTwert_01UEBERSPANNUNG_TIMER_DOWNwert_01UEBERSPANNUNG_TIMER_UPwert_01UEBERSPANNUNGSSCHUTZnicht_aktivUEBERSPG_ABSCHALT_58Gnicht_aktivUEBERSPG_ABSCHALT_BLnicht_aktivUEBERSPG_ABSCHALT_NSLnicht_aktivUEBERSPG_ABSCHALT_RFSnicht_aktivUEBERSPG_ABSCHALT_SLnicht_aktivUEBERSPG_ABSCHALT_SL_Hnicht_aktivUEBERSPG_ABSCHALT_SL_HInicht_aktivIHA_KODIERUNGnicht_aktivIHAMODIFYnicht_aktivAMR_TYP_5.7typ_3BMR_TYP_5.7typ_1E39_KURVENLOGIKaktivGETRIEBEVARIANTEtyp_4HBA_ASC_5_7nicht_aktivKLEINE_KURVENLOGIKaktivSCHLUPFBANDMOD_5.7nicht_aktivSCHLUPFSCHWELLENOFFS_5.7nicht_aktivACC_DSC_5_7nicht_aktivCODIERWERTwert_01CODIERWERT_DSC5.7wert_13HBA_DSC_5_7wert_02LAENDERVARIANTE_TVeceMULTIFUNCTIONgreat_britainMULTIFUNCTION_1great_britainMULTIFUNCTION_2great_britainWIDESCREEN_MODIwert_00LAENDERVARIANTE_GTeceSPEED_MAPSwert_01SPEED_ROUTE_MAPSwert_01USER_INPUTwert_01AUTOMATISCHER_NOTRUFnicht_aktivBAUARTlimousineTELEMATIKnicht_aktivANZEIGE_ANKUNFTSZEITnicht_aktivBPLUS_TRENNUNG_1aktivBPLUS_TRENNUNG_2aktivSBE_ALT/NEU_1altSBE_ALT/NEU_2altBASS_TREBLE_GAIN6dbBEDIENELEMENTEbordmonitorECKFREQUENZ_LOUDNESSe39FILTER_FZG_BLOCK_1e39FILTER_FZG_BLOCK_10e39FILTER_FZG_BLOCK_11e39FILTER_FZG_BLOCK_12e39FILTER_FZG_BLOCK_13e39FILTER_FZG_BLOCK_14e39FILTER_FZG_BLOCK_15e39FILTER_FZG_BLOCK_16e39FILTER_FZG_BLOCK_17e39FILTER_FZG_BLOCK_18e39FILTER_FZG_BLOCK_19e39FILTER_FZG_BLOCK_2e39FILTER_FZG_BLOCK_20e39FILTER_FZG_BLOCK_21e39FILTER_FZG_BLOCK_22e39FILTER_FZG_BLOCK_23e39FILTER_FZG_BLOCK_24e39FILTER_FZG_BLOCK_25e39FILTER_FZG_BLOCK_26e39FILTER_FZG_BLOCK_27e39FILTER_FZG_BLOCK_28e39FILTER_FZG_BLOCK_29e39FILTER_FZG_BLOCK_3e39FILTER_FZG_BLOCK_30e39FILTER_FZG_BLOCK_31e39FILTER_FZG_BLOCK_32e39FILTER_FZG_BLOCK_33e39FILTER_FZG_BLOCK_34e39FILTER_FZG_BLOCK_35e39FILTER_FZG_BLOCK_36e39FILTER_FZG_BLOCK_37e39FILTER_FZG_BLOCK_38e39FILTER_FZG_BLOCK_39e39FILTER_FZG_BLOCK_4e39FILTER_FZG_BLOCK_40e39FILTER_FZG_BLOCK_41e39FILTER_FZG_BLOCK_42e39FILTER_FZG_BLOCK_43e39FILTER_FZG_BLOCK_44e39FILTER_FZG_BLOCK_45e39FILTER_FZG_BLOCK_46e39FILTER_FZG_BLOCK_47e39FILTER_FZG_BLOCK_48e39FILTER_FZG_BLOCK_49e39FILTER_FZG_BLOCK_5e39FILTER_FZG_BLOCK_50e39FILTER_FZG_BLOCK_51e39FILTER_FZG_BLOCK_52e39FILTER_FZG_BLOCK_53e39FILTER_FZG_BLOCK_54e39FILTER_FZG_BLOCK_55e39FILTER_FZG_BLOCK_6e39FILTER_FZG_BLOCK_7e39FILTER_FZG_BLOCK_8e39FILTER_FZG_BLOCK_9e39FMID_BEDIENUNGe39GAL_DEFAULTgal_2GERADENSTEIGUNG_LOUDNESSe39HECKDELAYe39INTERNES_EEPROM1e39INTERNES_EEPROM2e39KONF_7_BD_EQUALwert_01MITTENFREQUENZ_BAND1standardMUTE_BEI_POLLINGTIMEOUTdeaktiviertPEGELADAPTIONe39SCHWELLE_LOUDNESSe39START_PEGEL_GAEe39GAE_BLOCK_1e39GAE_BLOCK_10e39GAE_BLOCK_11e39GAE_BLOCK_12e39GAE_BLOCK_13e39GAE_BLOCK_2e39GAE_BLOCK_3e39GAE_BLOCK_4e39GAE_BLOCK_5e39GAE_BLOCK_6e39GAE_BLOCK_7e39GAE_BLOCK_8e39GAE_BLOCK_9e39NENNER_LOUDNESSe39POLLING_TIMEOUTstandardSKAL_FZG_BLOCK_1e39SKAL_FZG_BLOCK_2e39SKAL_FZG_BLOCK_3e39SUBWOOFER_KOPPLUNGstandardSW_ALLEe39ZAEHLER_LOUDNESSe39K_BUS_FREI_OHNEnicht_aktivABSCHALT_GESCHWINDIGKEITe39ABSCHALTMELDUNGnicht_aktivABSCHALTWEGe39ABSTAND_EINBAU_WANDLERe39_m5AKUSTIK_KONZEPTnicht_aktivANFANGSWERT_ECKE_HINTEN100_prozentANFANGSWERT_ECKE_VORN100_prozentANFANGSWERT_MITTE_HINTEN100_prozentANFANGSWERT_MITTE_VORN100_prozentANZAHL_WANDLER8_wandlerDAUERTON_MESSBEREICHe39_m5_9/01ECHOSCHWELLWERTE_ECKE_HIe39_m5_9/01ECHOSCHWELLWERTE_ECKE_VOe39_m5_9/01ECHOSCHWELLWERTE_MITTE_HIe39_m5_9/01ECHOSCHWELLWERTE_MITTE_VOe39_m5_9/01EINSCHALT_GESCHWINDIGKEITe39EINSCHALTMELDUNG_BEI_1MALnicht_aktivEINSCHALTMELDUNG_IMMERnicht_aktivEINSCHALTVERZOEGERUNGaktivFILTER_DETEKTION_WEITnicht_aktivLAUTSTAERKE_TONGEBERe39_pu99MELDUNG_TASTERnicht_aktivMESSBEREICHE_WANDLERe39NOTFUNKTIONnicht_aktivNUR_EIN_TONGEBERnicht_aktivOFFSET_MESSBEREICHe39PDC_AKTIV/DEAKTIVweg_geschwPDC_EIN_BEI_KL15nicht_aktivPDC_SCHALTERaktivRUECKFAHRGONGaktivSKALIERUNG_ECKE_HINTEN0.65SKALIERUNG_ECKE_VORN0.65SKALIERUNG_MITTE_HINTEN0.65SKALIERUNG_MITTE_VORN0.65TONGEBER_HINTENlautsprecherTONGEBER_VORNgongVERZOEG_RUECKFAHRGONGe39WEGKENNZAHLe39AHK_ABSTANDe39ANHAENGERKUPPLUNGnicht_aktivEIS_AUSBLENDENaktivLAUTSTAERKE_HINTENwert_04LAUTSTAERKE_VORNe39MESSBEREICH_HECKKL_ECKEe39MESSBEREICH_HECKKL_MITTEe39NUR_KL15_BETRIEBnicht_aktivAUT_SITZVERSTELLUNGnicht_aktivFERNWIRKEN_GENERELLnicht_aktivFERNWIRKEN_NAVZIELEnicht_aktivFERNWIRKEN_POSITIONnicht_aktivFERNWIRKEN_STANDHEIZUNGnicht_aktivFERNWIRKEN_TELEFONLISTENnicht_aktivHANDY_TYPsiemens_s10WAKEUP_GENERELLnicht_aktivWAKEUP_TAGEwert_01WAKEUP_ZEITwert_01FAHRZEUG_MMIbmwGAL_ANZAHL_STUFENwert_01GAL_KMH_HYSTERESEwert_01GAL_KMH_STUFUNGwert_01NACHLAUF_ZEIT_Hwert_01NACHLAUF_ZEIT_MINwert_01ANZAHL_ANTENNEN4ANZAHL_RAEDER_UEBERWACHT4ANZAHL_RAEDER_VERBAUT4DRUCK_OFFSETwert_01RE_TELEGRAMME3GALwert_02LAENDERVARIANTE_RADIOeceRDS-AF_SWITCHINGrds_on/af_autoTP_FUNKTIONtpTP_MINIMAL_VOLUMEwert_05KEY_MEMORY_RADIOnicht_aktivPTY_TABELLEeceREGwert_04FLC_SCHWELLWERT_SATZwert_01FLC_SCHWELLWERT_SATZ_2wert_01FLC_SCHWELLWERT_SATZ_3wert_01FLC_SCHWELLWERT_SATZ_4wert_01TYP_FRONTSCHEIBEserienscheibeWISCHERMOTOR_RSKwert_01ANZAHL_ANFRTEL_ZUSAETZLwert_01FUNKTION_FBZVnicht_aktivFUNKTION_TOEHKInicht_aktivMAX_AUF_ZEIT_BER_1_HIGHwert_02MAX_AUF_ZEIT_BER_1_LOWwert_02MAX_AUF_ZEIT_BER_3_HIGHwert_02MAX_AUF_ZEIT_BER_3_LOWwert_02MAX_SCA_LAUFZEIT_HIGHwert_02MAX_SCA_LAUFZEIT_LOWwert_02MAX_ZU_ZEIT_BER_1_HIGHwert_02MAX_ZU_ZEIT_BER_1_LOWwert_02MAX_ZU_ZEIT_BER_2_HIGHwert_02MAX_ZU_ZEIT_BER_2_LOWwert_02REVERSIERZEIT_HIGHwert_02REVERSIERZEIT_LOWwert_02TYPaktivVENTILVERZ_STOP_HIGHwert_02VENTILVERZ_STOP_LOWwert_02AD_GAINwert_13AD_GAIN_1wert_13AD_OGAINwert_13AD_OGAIN_1wert_13ANZAHL_STUFENwert_03GERAETENAMEwert_01HD_AC_AVE_THRwert_13HD_AC_MARGIN_BOOSTwert_13HD_AC_MARGIN_W_AECwert_13HD_DO_LEC_ERLEwert_13HD_DT_CLIP_THRwert_13HD_DT_ERLEwert_13HD_DT_HOLDwert_13HD_DT_LOSS_BIASwert_13HD_DT_LOSS_SHIFTwert_13HD_ERLE_2_UPD_AEwert_13HD_ERLE_2_UPD_LMSwert_13HD_HYB_MARGIN_WO_LECwert_13HD_HYBRID_AVEwert_13HD_HYBRID_AVE_LECwert_13HD_HYBRID_AVE_NOTCHwert_13HD_I2DT_RXBSNwert_13HD_I2DT_TXBSNwert_13HD_I2RX_RXEwert_13HD_I2RX_RXSNwert_13HD_I2TX_TXEwert_13HD_I2TX_TXSNwert_13HD_INC_Hwert_13HD_LEC_ERLE_MARGINwert_13HD_LES_MAXwert_13HD_LES_MINwert_13HD_LSW_MINwert_13HD_RX_CLIP_THRwert_13HD_RX_HOLDwert_13HD_RX2DT_RXBSNwert_13HD_RX2DT_RXSNwert_13HD_RX2DT_TXBSNwert_13HD_TX_HOLDwert_13HD_TX2DT_RXBSNwert_13HD_TX2DT_RXEwert_13HD_TX2DT_RXSNwert_13HD_TX2DT_TXBSNwert_13HD_TX2RX_HOLDwert_13HD_TX2RX_RXEwert_13HD_TX2RX_RXSNwert_13KMH_HYSTERESEwert_02KMH_STUFENwert_03NACHLAUFZEITwert_03SPRACHERKENNUNG_EIN_AUSautomatischULF_EIN_AUSaktivV_SNS_LWR_GAIN_BND_D_Nwert_13EC_AUXLMSSTEPSIZEwert_13EC_LMSSTEPSIZEwert_13F_1000wert_13F_1250wert_13F_1500wert_13F_1750wert_13F_2000wert_13F_2250wert_13F_250wert_13F_2500wert_13F_2750wert_13F_3000wert_13F_3250wert_13F_3500wert_13F_3750wert_13F_500wert_13F_750wert_13HD_AC_MARGIN_WO_AECwert_13HD_CC_SUPPRESSIONwert_13HD_DO_NOTCHwert_13HD_HYBRID_MARGIN_W_LECwert_13HD_LLES_MAXwert_13HD_LLES_MINwert_13HD_LOOP_MARGINwert_13HD_LSW_MAXwert_13P_LPF_CLIPwert_13AIRBAG_TRIGGERED_E-CALLnicht_aktivBACKUP_ANTENNAnicht_aktivBACKUP_BATTERYnicht_aktivBACKUP_BATTERY_ENABLEDnicht_aktivBLUETOOTHbt_operationCUSTOMER_CALLS_OVER_GMINnicht_aktivDELAY_PWR_DOWN_INIT_DURwert_01DSP_ACOUSTIC_PROFILEdsp_profil_1E-CALL_HARDKEY_FITTEDnicht_aktivE_CALL_COUNTD_DEL_TMRwert_01GAL_HYSTERISIShysteresis_defaultGAL_KM/H_PER_STEPkmh_per_step_defaultGAL_STEPSsteps_defaultGPS_ON/OFFgps_offNAD_EQUIPPEDnad_equippedNON-TELEMATIC_E-CALLnicht_aktivSECOND_HARDKEYnicht_aktivSIM_IN_TELEMATIK_READERnicht_aktivTCU_TYPEibus_eceTELEMATIK_ENABLEDnicht_aktivTIMER_SMS_NACKwert_01TRACK_WIDTHe39_andereUS_BUSINESS/PROF_VARIANTbusiness_modelUS_CALL_SERVICE_CENTERnicht_aktivWAKEUP_BY_B-CALLno_wakeupWAKEUP_BY_E-CALLno_wakeupWHEEL_CIRCUMFERENCEe39_m5DRIVE_WHEELSrear_wheelWHEEL_BASEe39_limo_touring_m5EHC_KENNFELDe39_ab_sensorOFFSET_HI_LIab_sensorOFFSET_HI_REab_sensorBL_DIMMENwert_02TAGFAHRLICHTnicht_aktivAHC_INAKTIVnicht_meldenENABLE_US_SBRnicht_aktiv Share this post Link to post Share on other sites
Clavurion 370 Report post Posted February 16, 2012 (edited) I checked this again on my E39 and actually it's "us" on mine too. My one touch is working OK. Here is FSW_PSWfrom my GM3. Check for differencies.If nothing helps I would test with another GM3.KOMFORTSCHLIESSUNGaktivFH_FAHRERTUER_TIPP_AUFaktivFH_FAHRERTUER_TIPP_ZUaktivFH_BEIFAHRERTUER_TIPP_AUFaktivFH_TUEREN_HINTEN_TIPP_AUFaktivFH_TUEREN_HINTEN_TIPP_ZUaktivQUIT_AKUST_DAUER_10_MSnicht_aktivQUIT_AKUST_DAUER_20_MSnicht_aktivQUIT_AKUST_DAUER_40_MSnicht_aktivCODIERUNG_ERFOLGTcodierung_erfolgtDWAaktivSCHAERFEN/ENTSCHAERFENschloss_und_fernbedienungPANIK_MODUSnicht_aktivFUNK_INNENRAUMSCHUTZaktivQUIT_AKUST_DAUER_80_MSaktivQUIT_AKUST_SCHAERFnicht_aktivQUIT_AKUST_ENTSCHnicht_aktivQUIT_OPT_ENTSCHaktivQUIT_OPT_SCHAERFaktivNEIGUNGSGEBERaktivALARM_AKUSTISCHintervalltonHECKKLAPPE_ENTSICHERNaktivSOFT_ON/OFFaktivFH_ABSCHALTKRITERIUMusFENSTERHEBER_HINTENaktivFH_BEIFAHRERTUER_TIPP_ZUaktivEINKLEMMSCH_REVERSIERENlangALARM_AKUSTISCH_LANGnicht_aktivBAUREIHEe39ANPRESSDRUCKVERSTELLUNGnicht_aktivSCHEIBENINTENSIVREINIGUNGaktivSCHEINWERFERREINIGUNGaktivALARM_OPT_ABBLENDLICHTnicht_aktivALARM_OPT_FERNLICHTnicht_aktivALARM_OPT_WARNBLINKERaktivBAUREIHE_SERVOTRONIKe39DWA_NOTENTSCHAERFENaktivGLASDACHaktivIR_FERNBEDIENUNG_BFnicht_aktivKOMFORTOEFFNUNGaktivLENKSAEULENMEMORYaktivPM_SCHIEBEHEBEDACHaktivPM_SITZMEMORYaktivPM_SITZMEMORY_BEIFAHRERnicht_aktivQUELLE_SERVOTRONIK_KENNFromSCA_HECKKLAPPEnicht_aktivSCHIEBEHEBEDACH_TIPP_AUFaktivSCHIEBEHEBEDACH_TIPP_ZUaktivSERVOTRONIKnicht_aktivSERVOTRONIK_KENNLINIEe39_kennlinie_01SPIEGELEINKLAPPENaktivSPIEGELHEIZUNGaktivSPIEGELMEMORYaktivTUERKONTAKT_LOGIKoffenTUERKONTAKT_VORNan_gmUEBERWACH_FENSTER_BF_HInicht_aktivUEBERWACH_FENSTER_BF_VOnicht_aktivUEBERWACH_FENSTER_F_HInicht_aktivUEBERWACH_FENSTER_F_VOnicht_aktivUEBERWACH_HECKSCHEIBEnicht_aktivVERRIEGELN_AUT_AB_X_KM/Hnicht_aktivWEGFAHRSICHERUNG_AUTOMnicht_aktivWISCHERINTERVALL5_secWISCHERPOTInicht_aktivZV_SELEKTIVnicht_aktivABKLAPPSTELLUNGnicht_aktivBC_ANFORD_WEGFAHRSICHnicht_aktivCLT_AKTIV_IM_CRASH_MODEnicht_aktivCODIERUNG_ERFOLGT_1codierung_erfolgtCODIERUNG_ERFOLGT_2codierung_erfolgtDWA_QUITTIERUNGaktivENTFALL_ZV_BEDIENST_HECKaktivENTR_KL.R_30S_NACH_SICHnicht_aktivENTSICHERN_CENTERLOCKnicht_aktivFH_AUF_STUFE2_KLR_AUSaktivFH_TIPP_DISABLE_TUER_AUFaktivFUNKINNENRAUMSCHUTZ_HInicht_aktivHYDRAUL_HECKKLAPPEnicht_aktivIB_EIN_HK_AUFnicht_aktivINNENLICHT_AN_MEHRFACH_ZVaktivK_BUS_FB_SPERRENaktivKEY_MEMORYaktivKOMFORTOEFFNUNG_FBaktivKOMFORTSCHLIESSUNG_FBaktivLIM/TOURINGlimousineNOTSTROMSIRENEaktivPM_SCHALTERBLOCK_FONDnicht_aktivSEL_ZV_SENDER_1nicht_aktivSEL_ZV_SENDER_2nicht_aktivSEL_ZV_SENDER_3nicht_aktivSEL_ZV_SENDER_4nicht_aktivSERVO_KENNL_GESCHWkennlinie_01SERVO_KENNL_STROMkennlinie_01SONDERFHZG_MIT_WSAnicht_aktivSPERRZEIT_KL_R_AUS_0.2_SaktivSPERRZEIT_KL_R_AUS_0.4_SaktivSPERRZEIT_KL_R_AUS_0.8_SaktivSPERRZEIT_KL_R_AUS_1.6_SaktivSTANDRUECKSCHALTUNGnicht_aktivVERRIEGELN_XKM/H_SENDER_1nicht_aktivVERRIEGELN_XKM/H_SENDER_2nicht_aktivVERRIEGELN_XKM/H_SENDER_3nicht_aktivVERRIEGELN_XKM/H_SENDER_4nicht_aktivVERZUG_PANIK_MODUS_0.2_SaktivVERZUG_PANIK_MODUS_0.4_SaktivVERZUG_PANIK_MODUS_0.8_SaktivVERZUG_PANIK_MODUS_1.6_SaktivWEGSIGNAL_SERVO_ABSaktivZV_ENTR_SCHL_BEI_DWA_AKTaktivZV_VR_BEDIENSTELLE_HECKnicht_aktivAUTO_ZV_DISABLEnicht_aktivVERRIEGELN_AUT_NACH_2_MINnicht_aktivVERRIEGELUNGSSCHWELLE16_km/hZV_BEDIENST_BT_DISABLEaktiv Edited February 16, 2012 by Clavurion Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 16, 2012 I changed FH_ABSCHALTKRITERIUM from us to ece, still no one touch closing.Time to take the door cards (or at leat one door card) off and check the wires I think. Share this post Link to post Share on other sites
RichardP 1,038 Report post Posted February 17, 2012 Problem solved!It's always the simple things isn't it. The trap detector and mid range speaker wires were swapped over.The only explanation I can give is that when the car was in for a respray in Spring last year, they stripped everything back to get access to the wing mirrors. When connecting everything back they connected the trap sensor to the mid speaker unit connection block. You can see how the mistake could be made, the wire is in exactly the right place (on the drivers side especially) and the connector is exactly the same. Also, when the door card is off there is no other obvious wire to plug into that socket. The connector in the main loom for the trap sensor is black, the same colour as the connector on the mid speaker.My only possible excuse for not realising that the mid speakers were not working is that while the car was in the body shop I was driving out 1L 3 cylinder Yaris which has a woeful radio and is an incredibly noisy environment at motorway speeds, going back to the M even with 2 speakers out was orders of magnitude better. I had been thinking that the sound was crap, it's definitely better now and all my windows one touch and comfort close again. Share this post Link to post Share on other sites
