rob-the-viking
How to guides and useful information
I am in the process of rebuilding the how to guides into one thread that is stickied to the top of the forum. If there is something you think should be in here, please PM me.
Owners manuals - Thanks to Sepia for these!
2000 E39
2001 E39
2002 E39
2003 E39
2000 E39 M5
2001 E39 M5
2003 E39 M5
On board computer, radio and phone manuals
OBC with MID and CD Changer manual
OBC with 16:9 screen
Bluetoth ULF manual
Another Bluetooth manual
Official BMW E39 retrofit guides
PDC front and rear.pdf
Rear PDC.pdf
E39 MID retrofit.pdf
E39 High OBC Retrofit.pdf
E39 Reversing Camera.pdf
E39 Sat Nav Retrofit.pdf
E39 Touring Sat Nav Retrofit.pdf
Cruise & MFSW retrofit.pdf
Hands free retrofit.pdf
Headlight Washers.pdf
Illuminated Gearshift.pdf
Manual Rear Sunblind.pdf
Rear Power Supply.pdf
Seat Ventilation System.pdf
Sound Module.pdf
Touring Luggage Partition.pdf
Touring Subwoofer Retrofit.pdf
E39 Seat Heating V1.pdf
E39 Seat Heating V2.pdf
How to guides by forum members
E39 Electric Memory Seat retrofit - By Raymond
E39 Electric steering columm retrofit - By Raymond
How to fit an LPG kit to your V8 E39 - By V8Warrior
How to fit an LSD to your E39- By V8Warrior
How to fit a big brake kit to your E39- By V8Warrior too!
Crankshaft Position Sensor BMW E39.pdf - Thanks to Paulo for this one
How to fit a 12v socket in your boot (to keep your beer cool!) By Liam79
Door seal replacement by frankc
How to fix your clinking seat By Liam79
How to retrofit E39 OEM heated seat mats to your existing seats By Liam79
CPS replacement by crosslwired
Other useful info
How to reset service and brake fluid change lights - Thanks to DavidW53 for reminding me of this!
Other useful information
BMW online parts catalogs
http://www.realoem.com
http://www.bmwfans.info
BMW Technical Information System (TIS) online
http://tis.spaghetticoder.org/
BMW Wiring diagrams (WDS) online
http://spaghetticoder.org/bmw/wds/
t
Voice Input System PDF http://www.m5board.com/vbulletin/attachments/e39-m5-e52-z8-discussion/60671d1206157480-voice-input-system-manual-pdf-voice-control-manual.pdf
When i click on that link i get a message from Norton that say`s this file can harm your computer. ???
I'm a newbie to the site, so i hope it's ok for me to post in here, but i thought this would be usefull to ALL BMW owners...
First, disable popup blockers (i know this looks bad, a newbie asking you to disable popups, i promise there won't be anything you won't like). Then, right click this link... https://www.parts.bmwgroup.com/ , and open in either a new tab or new window. It will probably pop up another window asking you to login in. For a username type in eu111111 and for a password, type in bmwetk1 .
It may open another window, but if not, click the link on the left of the page that says service/technic and again, it might open a new window. On the next page (or new window) look for webepc, with a pic of either a suspension strut or a brake disc next to it, and click start.
A new window will almost definately pop up now, and this is where the fun begins. This is very much like realoem, only it's BMW's own site. Put in the last 7 digits of your vin in the box near the top, and click the >> button. At the top of the new page, you'll see some links in the greyed section. Click options, and a new window will open with the options list for your car as it came out of the factory :D
I haven't seen this posted anywhere else on this site yet, so hopefully it's not a repost, but, enjoy :)
Edited by Gav.
Any chance of volume 2 for the above please?
Volume 2 contains section 6 which covers electrical stuff.
Cheers,
Gavin :)
Cheers,
Gavin :)
Sorry, that was just a random find...:/
Found this a while ago.
http://www.cooper-bmw-parts.co.uk/
Coopers have their parts prices online, saves you bothering kev and tony!
And you'll see that kev and tony will still supply it cheaper delivered to your door!
Handy to get quotes though if you know the part numbers.
Not sure if the older stuff (E28 etc) is on there mind.
Probably needs to be viewed on a computer or view the desktop site on a smart phone rather than the mobile version.
BMW E39 540i oil filter mount removal. I saw that its a pain to remove old mounts as they tear off so easily. I made a tutorial on how to remove the base plate of the rubber mount.
Also please do share this if you want to.
Many Thanks,
amand
BMW E39 540i M62TU Oil filter mount DIY.pdf
Edited by amand
Thread bump, in case anyone's looking for E39 weld-in sill sections this place does them in Bolton.
http://www.autocrashparts.co.uk/
They're able to order items.  Non-genuine but the fit is good and are only about £25 a side!  I also believe they're galvanised.   Myself and another member have used them with success on our M5s
Wiring diagrams that should work on modern browsers. OK only on IE or Safari which still support Java...
https://www.pss-autosoft.net/diagrams/bmw/index.htm
Apparently if you buy their DVD even the component hot links work as they have recoded everything!!
Also some awesome dude put them on an Android app removing all dependence on Java...
https://play.google.com/store/apps/details?id=com.dcsoftware.eu.bmwwdsviewer.free
Edited by Liam79
Are there any guides / HowTo's to retrofit (Bi)Xenon headlamps to a pre-facelift car?
Is it even possible?
NF aka Deepan
