BMW 5 Series Owners Board uses cookies. Read the Privacy Policy for more info. To remove this message, please click the button to the right:    I accept the use of cookies
Facelift 16:9 screen in a pre-facelift car
  • Please log in to reply
12 replies to this topic
#1 BriC
BriC
  • LocationSale, Manchester
  • Occupation:Draughtsman
  • Current Car:1999 BMW M5
Posted 30 June 2011 - 12:23 PM
I'm going to view a car tomorrow that is a '99 E39. It had sat nav as standard, however a 16:9 monitor has been fitted over the standard 4:3 unit. He says the Mk.2 sat nav drive is broken, and also the unit still runs 4:3 mode, as the TV module wasn't upgraded.
My question is this - what do I need to look for in order to get it running in 16:9, as I've searched for BMW E39 Screen Module in eBay, and had 0 returns. Also, will I just be able to buy a more modern cumputer (mk.3 for example) off eBay, connect it up, and be sorted, or is it not that simple?
Cheers :)
Current car:
1999 BMW M5 Avus Blue
Previous cars:
2000 BMW 535i Sport Manual Biarritz Blue
1999 BMW 520i SE Manual on LPG Titanium Silver
Restored 1989 Renault 5 GT Turbo
#2 DennisCooper
DennisCooper
  • LocationSlough West London/Heathrow
  • Current Car:Ex Police - E39 530d Touring
Posted 30 June 2011 - 02:46 PM
Hi Bric
You should be able to get away with Mk3 or Mk4 GPS computer as they have the ability to drive a 16:9 output directly. If you are going to be dropping the cash, you might as well get the Mk4 as it's also faster in use and operation. The more experienced guys will be along for any other info too in case there's any other gotchya's to be aware of.
Cheers, Dennis!
Tel: 07708 804500 10am-9pm
#3 BriC
BriC
Posted 30 June 2011 - 03:52 PM
Cheers Dennis.
Could someone confirm if the more modern computers are a straight swap into the older cars. Does any of the wiring need to be adapted or anything?
Thanks.
Current car:
Previous cars:
#4 rob-the-viking
rob-the-viking
  • LocationCambs
Posted 30 June 2011 - 05:23 PM
To upgrade from a mk2 to a Mk 3 or 4 I think you just need to disconnect the Trimble unit and connect the gps aerial to the rear or the drive. The TV tuners aspect ratio is software driven I think, so you should be able to switch it with the right software,such as navcoder. As for the screens, I've got a 16:9 in my pre facelift and it fts and works fine.
RichardP will know the score drop him a PM.
Posted Image
55,573
#5 RichardP
RichardP
    Chief Member
  • Platinum Members
    • Member ID: 30,340
  • 2,949 posts
  • LocationNorth Yorkshire
Posted 01 July 2011 - 10:45 AM
OK, here's a summary :
- The MK II uses an external Trimble module, the MK III and MK IV have it internally, so to upgrade from MK II to MK III/IV you must disconnect the GPS antenna from the Trimble and connect it directly to the Nav. The Trimble is a small metal box about 3x3x1 inches, usually located right behind almost everything in the left side boot cubby hole.
- Apart from the Trimble issue, Mk II to Mk III/IV is plug and play.
- All but the earliest MK II Nav computers support 16:9 output as well as 4:3. Mk II Nav with a hardware version of 1.x I believe do not support 16:9.
- Early TV module do not support 16:9 output at all. Worse still, as all the video feed goes through them, they convert the 16:9 output of the Nav to 4:3 and you get two black lines down the side of the display, just like a wide screen TV displaying a 4:3 picture.
The following TV part numbers are 4:3 only.
4100223
6900858
6901456
6902015
6902016
6903727
6903728
8381940
8383520
8383521
8385959
8386287
8483733
8483734
0181221
The following have 16:9 support
4124836
6906923
6906924
6911221
6911222
6916136
6916137
6923268
6923418
6924749
6924750
6936759
6936096
6946423
6945298
6953002
6953003
6970581
6973091
9119653
9149315
9178796
The following are Hybrid Digital/Analogue
6126251
6908079
6956832
6962190
6962212
6966615
6966696
6988906
9112837
9118577
9126252
9147138
9147139
There may well be more part numbers, if the number differs by +1 then it may be a remanufactured unit, -1 the it's the original and the part number given is the remanufactured unit. It's quite possible that some of the part numbers are in the wrong group so don't take my word for it!
- You can by pass the TV module by unplugging the blue plug from the TV module and connecting it directly to the Nav, in some cars you may lose Nav audio unless you move some pins about in the plug.
Posted Image
2003 Carbon Black E39 M5
Evolve remap, headers & race cats | Intravee II for iPod, DVD & DAB plus PXA-H100 DSP emulation | Valentine One mirror integration and head rest stealth install
#6 BriC
BriC
Posted 01 July 2011 - 10:57 AM
OK, so I'll need a new computer and TV module.
Cheers :)
Current car:
Previous cars:
#7 Mikey_535i
Mikey_535i
  • LocationHampshire
  • Occupation:Radio Design Engineer
  • Current Car:2005 CTR
Posted 01 July 2011 - 01:02 PM
mine has the original drive and a widescreen, as said it has 2 black lines where it doesn't fit the screen, it's not annoyed me enough to spend the money replacing it as it works, when the tv stops working i may look at it then :)
My old car - 1999 BMW E39 M5 - Carbon Black - Caramel Heritage Leather - click pic below for journal
Posted ImagePosted Image
#8 RichardP
RichardP
    Chief Member
  • Platinum Members
    • Member ID: 30,340
  • 2,949 posts
Posted 01 July 2011 - 01:12 PM
If you don't use the TV module, just by pass it by disconnecting the blue plug and connect that directly to the Nav.
Posted Image
#9 Mikey_535i
Mikey_535i
  • LocationHampshire
Posted 01 July 2011 - 01:14 PM
i watch tv occassionally even with the crappy picture, mainly because i can ;) but i will remember that for when it switches over
#10 rob-the-viking
rob-the-viking
  • LocationCambs
Posted 02 July 2011 - 10:15 AM
16:9 one On fleabizzle
Posted Image
55,573
#11 BriC
BriC
Posted 02 July 2011 - 04:00 PM
Not to worry anymore, as I think I know which car I'm going for, and this one doesn't have nav anyway :) Cheers for the replies though!
Current car:
Previous cars:
#12 M5 HOH
M5 HOH
  • LocationScotland
  • Occupation:IT
  • Current Car:2001 E39 M5
Posted 02 July 2011 - 04:24 PM
Oh, so you're going to be joing the ranks of the M5 owners then? :wink:
Posted Image
2001 E39 BMW M5 Titanium Silver
Gone:1999 E46 BMW 328Ci Titanium Silver; 1997 E36 BMW 318iS Coup� Montreal Blue; 1996 Rover Mini Sprite 1.3i Electric Blue
#13 BriC
BriC
Posted 02 July 2011 - 05:37 PM
Certainly am! Needs to be done :D
Current car:
Previous cars:
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
