Smiler
Replacement Sill Panels
According to the above post the front repair section from BMW doesn't include the jacking point it's falls short. Can someone please advise if that is really the case as that would mean you'd need to buy #2 panel to cut and suite the front jacking point?
Hi
The BMW sills come in 3 sections
If my memory is right the rear repair
Section has the jacking point and part
of the lower arch ... The middle section
Has the front jacking point.
 The cost of the rear section was £150
 about 3 years ago
 Carl
Hi
 about 3 years ago
 Carl
Hi carl
So for a full sill repair I need 2, 5 and 6? From the diagram in my last post?
Go for the OEM bmw rear sill assembly if at all possible. This is a superb item that comes complete with the jacking point strengthener. Depending on how corroded your car already is, this panel will do all you need unlike the (still good quality) kolkkenhom sill panel.
To do this job properly with all rot cut out and a decent repair means time, effort and courage. What the real problem is regards what you can't see namely the inner sill. If the outer sill is as rotten as you say, the inner will also more than likely be at least rusty at best. The inner sill is heavily sculptured and would be seriously difficult to fabricate. You've also got the inner wheel arch to consider and again its shape will be difficult to replicate. Where the rear suspension brackets bolt into the floor beside the battery also rots out meaning more fab work. I know all this because I've been (and still am) doing it.
If you were to buy all the panels needed oem it will become expensive, around £500+ for the rears only and i believe one side inner sill is NLA. The frustrating thing is you probably won't need all of the panel. For example, you'll only need perhaps a 8" high section of the inner wheel arch and maybe 10" length of the inner sill.
The front jacking points look to be fairly straight forward to repair but I've not yet got that far. There is a strong possibility that the floor pan adjacent to the jacking point going forward will also be rotten. My plan is to use the kolkkenhom outer panel suitably cut to the required length/shape and fabricate the rest as necessary. This is the area behind the lower (sill) section of the front wings, so invisible though again that lower section of wing will more than likely need repairing or replacement.
My advice to anyone with this problem is to firstly establish exactly where and how much corrosion there is. Secondly, obtain the required panels now, either new or very good used (difficult i know).Thirdly, if your not doing it yourself, find yourself a good welder/fabricator.
I've learnt so much about e34 sills and how to repair them and whilst difficult it's not impossible. E39 owners are discovering sill rot now also, but to my eyes its seems a much easier repair as there only seems to be flat surfaces to deal with though the fuel tank is a problem. If i get the time i will do a proper thread regarding the e34 rear sill issue.
Edited by FIVE-OH
9 hours ago, cableguy said:
I'd stick with OEM BMW Parts, particularly on an M5. The metal is generally thinner on the copy parts.
C.
Last time i looked the Klokk panels came in 0.8mm and 1mm versions.
Some of the sellers on eBay don't know what they are selling!
If i was purchasing another 540 that
needed rear sills and jacking points.
I would use the BMW rear repair section
and the Kolkkenhom sills for other repairs.
Great post !
Looking forward to your thread !
The rears sills don't look that bad ...
Just make sure the welders leave or
make the two drain holes in the double skinned front foot well area. If the rot
has reached that point.
We need more pictures of the whole M5
:wink:
Hmmm... on the face of it it doesn't look too bad.
But...
The e34 series tend to rust from the inside out and whilst it looks like it will respond well to cleaning up, I'm willing to wager that corrosion is munching away inside the box section of the sill. Get under the car (suitably supported) and have a good look at the area behind the 'beer cans' of the rear suspension. This is the back of the inner sill and any rot here means rectification. Don't be shy. Prod it with a suitable tool to find any weak spot. Having said that the repairs if needed should hopefully be fairly localised.
The front right is finished. I can even just make out the sound insulation lulling about inside the cavity. This is the area below where the front speakers are situated. From the angle of the shot it does appear that the inner sill is corroded also but not sure how far up. If you pull back the carpet all should be revealed.
:wink:
The welder will be me
This is how she looked when I bought her. Had it in storage for 4 years finally getting round to doing it after finishing of my H26
The previous owner had chavved it up so any tatt will be coming off.
Also whoever worked on the wiring on this car needs a proper smack hid kit installed but cutting connectors twisting wires and a bit of tape
Don't get me started on the mess they made while wiring up amps and poo poo. Shoddy work really pisses me off.
Wow ! uber cool !
I know the feeling of pain at finding rotten sills etc after being
told the sills were rust free and superb body work by the former
Owner .... Strangely another well known dealer/parts breaker.
Edited by Carl-e34
Not sure if the Euro car part or Car parts for less part numbers have been recorded
Their catalogue states full sill 1.0mm thick   88-96 and part numbers 884110091  /  884110101
They are currently £71.99 with a 7% saving on ECP or £48.48 saving 38% on CP4L
They don't come up in the usual way, you have to do a search by part number then confirm car details
Edited by stevenc3828
More info
Will take a look thanks.
The Kolkkenhom sill panel is a decent bit of kit if your not too corroded, but here's why they come up slightly short.
There is simply not enough to effect a full front section repair which is unfortunate. Depending how you wish to proceed in the repair they may still be of some use.
Spent an hour chatting to a friend on the parts desk @ BMW on Saturday morning.
FYI there are now 11 inner sills left in stock (in europe) for the nearside and none for the drivers side. When BMW run out of stock they sit down, work out how many they can sell, and then usually outsource the production, so when it comes back in stock its alot more expensive. (think E39 front corner trays... Before ~ £60, now over £100...)
I’m after the jacking point strengtheners for both front sides of the car. Can anyone help? I believe the a pillar which can be bought from Bmw at an eye watering £200 per side has this. Can someone please confirm this is the case? Anyone know of an alternative?
Pic shows what I need circled in yellow.
