bramley007
Warning signs of an autobox on the way out - what are they?
Recently I’ve noticed that changes from (I think) 2nd to 3rd sometimes aren’t very smooth and it feels like the car is slowing just before it changes gear, rather than the smooth and seamless shift it should be. Reverse is fine.
Oddly it was 100% fine this morning. In the last 7 days I’ve used D, S and M and there’s not really a consistent problem. It seems to be worse when cold, then goes away. It also seems to be worse when accelerating very slowly. I realise this is about as vague as it could be, sorry! Weird that one days it’s fine, then the next day it’s a bit jerky.
Any thoughts?
Hi, the zf auto trans will always use the winter or "s" shift programme during the warm up cycle which means it will hold gears for a longer period before changing up, also uses the throttle actuator to back off the engine revs between gear changes, you may have a transmission mount issue or a propshaft guibo (rubber coupling) that is on its way out or even a dodgy abs sensor, may be worth having the autobox fluid level checked which must be done with the engine running and at running temperature, do you have access to a fault code reader may be worth having engine, transmission, and abs codes read. Where abouts do you live mate.
Michael
Its pretty extensive please contact me if you retrieve any codes.
A5S 310Z (5HP-18) - EGS 7.XX
CODE DEFINITION OF FAULT EGS
PIN OUT
POSSIBLE CAUSES
02 Solenoid Parking/Neutral lock 2 Break in wiring
Short in wiring
Defective valve winding
03 Solenoid valve 5 Break in wiring
Short in wiring
04 Solenoid valve 6 - Convertor lockup clutch Break in wiring
Short in wiring
05 Pressure regulator Break in wiring
Short in wiring
08 Shift Lever Position L2 8 Vehicle accelerated while shift lever in park or
neutral position
Engine was started and the EGS control has not
detected park or neutral position signal
09 Shift lever position L3/L4 37, 9 Break in wiring
Short in wiring
Short in sensor
12 Program selector switch 12, 13,
45
Short to ground
16 Turbocharger speed sensor 16, 44 No signal
Anomalous engine speed signal
18 Kickdown switch 18 Short to ground
Anomalous signal
19 ASC monitoring 19 Break in wiring
Short in wiring
EGS detected anomalous ASC signal
ASC operation detected while shift lever in park or
neutral
22 ATF sump temperature sensor 21, 22 Break in wiring
Short in wiring
26 Battery voltage + 26 Break in wiring
Check battery
Check charging system
30 Solenoid valve 1 30 Break in wiring
Short in wiring
31 Solenoid valve 4 31 Break in wiring
Short in wiring
32 Solenoid valve 3 32 Break in wiring
Short in wiring
33 Solenoid valve 2 33 Break in wiring
Short in wiring
35 Throttle valve signal (dtk) 35 Break in wiring
Short in wiring
Anamolous throttle valve signal
36 Shift lever position l1 36 Break in wiring
Short in wiring
Short in sensor
40 Engine intervention 40 Break in wiring
Short in wiring
41 Kva signal 41 Break in wiring
42 Transmission output rotation speed signal
(n-ab) - Stall speed signal
14, 42 No signal
43 Engine speed signal (n-mot) 43 No signal
53 Power supply - Solenoid valves 53 Relay in egs not switching
54 Batter voltage + 54 Battery voltage too low (>9 volts)
Check battery
100 Speed monitoring Trans/engine speed ratio not correct for gear
selected
Speed sensor signal faulty
Slip in transmission too high
101 EPROM checksum error Damaged EPROM
Program in memory faulty
Reinitialize power to EGS control unit
Replace control unit
102 Program checksum error Damaged EPROM
103 Relay - EGS control unit Relay in EGS not switching in time
104 DKT- Temperature signal 35 Break in wiring short in wiring
Anomalous engine temperature signal
105 DKT - Throttle valve signal 35 Break in wiring short in wiring
Anomalous throttle valve signal
106 MUX injection rate DDE sending faulty injection rate signal
110 EGS control unit not programmed Have EGS control unit programmed
(150) CAN timeout 1 CAN signal not sent during engine start (ignition
on)
(151) CAN timeout 2 CAN signal not detected (engine running)
(152) CAN bus monitor Values in CAN ram storage not updated
(153) CAN status fault Control units with different CAN status' are
installed on the same bus
Replace with correct units
(154) CAN throttle valve signal Anomalous throttle valve signal detected by DME
(155) CAN load signal Anomalous load signal detected by DME
(156) CAN engine intervention DME cannot alter engine torque to match EGS
signal
DME does not match other CAN control units
(157) CAN engine temperature Anomalous engine temperature signal detected by
DME
(158) CAN engine speed signal Anomalous engine speed signal detected by DME
200 Kickdown not working
201 Sport car transmission feature not
selectable
202 Manual shift program feature not selectable
203 Program cannot be converted 6
204 No engine deceleration detected 24
205 Brake light
Brake light test switch
206 False code set
300 Diagnostic circuit fault
301 EGS voltage supply No voltage to EGS control unit
Check wiring harness
he does not mention what car its for so maybe diff box as the one you describe ^^
mines a A5S440Z unless the fault codes are all pretty much the same on most ZF boxes ??
Edit :
on another note the A5S 310Z (5HP-18)was fitted to E34 M60 V8's
and the A5S560Z fitted to the E34 540 V8's.
These boxes were prone to failure and were a known weak point
Ha ha fair point, 5hp18 and 5hp19 codes are very similar there is a few valve body codes that are different however the code description will cross match.
Assumption is the mother of all f&&k ups :)
Cheers guys.
It's a 2003 530i Sport Touring, low OBC.
Michael, the Trans Safe warning came on once, about a year ago for about 3 minutes. The car had only just been started and I was in a hurry so put it in Sport then the light came on. It's not been on since then, and that's about 10k miles ago at a guess.
Car was fine yesterday and again today :?:)
Will plug INPA in over the weekend.
I'd suggest resetting the adaptations and see if that helps.
My 530i didn't change very smoothly when I got it and resetting the adaptations made a real difference, (for the best :-)  )
In my case with 523iA was rapidly slowing down and adding gas immediatly i could feel a bump in the gearbox as it shifted.. On my ex 530d it put safe mode twice and then voila it was over :)
I'm experiencing a slight shunt between 1st and 2nd also, gonna plug her in and do the gearbox update :)
Don't rule out a MAF sensor fault either....
What's the gearbox update and how?
Well I use Autologic at work and I know that there is a gearbox update for it, where are you from?
Sunny Derby, miles away from you.
I need a gearbox updates too as when I'm slowing down it feels like I've got warped disks but they are New so hopefully someone can help me thankyou I'm from Derby too
If you update the DDE aswell which ill be doing aswell as a MAF change, as far as I can see in the quite detailed history on this car... In 118k it's not seen a new one so I'm hoping after all of the above to see a massive improvement, Especially after I sort out the calliper sliders on the NSF which are getting 20degrees C hotter than the OSF
