seanmul
Light control module pins outs E39
Can someone point me in the way of the pin outs of the LCM please.
In particular the I-bus (instrumentation bus)connections.
I need to know where the flowing signals or sent from:
Belt warning
Reverse gear detection (manual transmission)
Left turn signal indicator
Right turn signal indicator
Front fog light
Rear fog light
High beam
I'm not looking for repair links etc....
I just want the 3 connectors and what each wire does and goes to.
thanks
After 09/98.
A3 Light module
Plug connector overview
Number X-pin, colour Description
X12 15-pin, black Plug connector Light module
X38 15-pin, white Plug connector Light module
X10117 54-pin, black Plug connector Light module
Pin assignments at plug connector X12
Pin Type Description / Signal type Connection /
Measuring notes
1 A Right rear fog light Rear right light I
2 A Left tail light Rear left light I
3 A Right front turn signal indicator Right front turn signal indicator Front right auxiliary flasher unit USA
4 A Right fog light Right fog light
5 A Left licence plate light Left licence plate light
6 A Right front turn signal indicator Right front turn signal indicator
7 M Control unit ground Ground point
8 A Rear left turn signal indicator Rear left light I
9 A Left brake light Rear left light I
10 A Centre brake light Raised brake light
11 A Left low beam light Low beam light, left
12 A Right licence plate light Right licence plate light
13 A Right high beam light Right high beam
14 A Right front turn signal indicator Tyre pressure control Front right auxiliary flasher unit
15 E Voltage supply terminal 30 Fuse F112
Pin assignments at plug connector X38
Measuring notes
1 A Signal line, night lights Connector terminal 58
2 M Control unit ground Ground connector
3 A Right low beam light Low beam light, right
4 A Left front turn signal indicator Tyre pressure control Front left auxiliary flasher unit
5 A Inner left tail light Rear left light I
6 A Left high beam light Left high beam
7 A Left fog light Left fog light
8 E Voltage supply terminal 30 Fuse F113
9 A Left reversing light Rear left light I
10 A Right reversing light Rear right light I
11 A Left front turn signal indicator Left front turn signal indicator
12 A Rear left turn signal indicator Rear right light I
13 A Inner right tail light Rear right light I
14 A Right brake light Rear right light I
15 A Left rear fog light Rear left light I
Pin assignments at plug connector X10117
Measuring notes
1 A Lighting, light switch Light switch
2 A Signal, headlight vertical aim control Actuator for headlight beam throw control, left
3 A Signal, headlight vertical aim control Actuator for headlight beam throw control, left
4 A Signal, headlight vertical aim control Actuator for headlight beam throw control, left
5 A Signal, headlight vertical aim control Actuator for headlight beam throw control, left
6 E Belt signal Driver's airbag
7 E Signal, hazard warning lights ON Hazard warning flasher switch
8 E Signal, rear fog light ON Fog light switch
9 Not used
10 E Wash water level Wash water level switch
11 Not used
12 Not used
13 E Voltage supply terminal R Fuse F41
14 E Signal, right turn signal indicator Turn indicator/low beam selector
15 E Oil level - thermal DME control unit DDE control unit Digital diesel electronics control unit
16 E Signal, night light dimmer Dimmer
17 A Right tail light Rear right light I
18 A Front left parking light Left front turn signal indicator
19 A Lights, hazard warning switch Hazard warning flasher switch
20 A Signal, headlight vertical aim control Actuator for headlight beam throw control, right
21 A Signal, headlight vertical aim control Actuator for headlight beam throw control, right
22 A Signal, headlight vertical aim control Actuator for headlight beam throw control, right
23 A Signal, headlight vertical aim control Actuator for headlight beam throw control, right
24 E Coolant level Coolant level switch
25 E Brake light signal Brake light switch
26 A Reversing signal Gong, Japan
27 A Supply for beam throw control unit (LWR) Beam throw adjustment control unit (LWR)
28 A Reversing signal Intermittent wipe/wash control unit, rear
29 Not used
30 Not used
31 E Terminal 15 Fuse F16
32 E Signal, left turn signal indicator Turn indicator/low beam selector
33 E Headlights ON signal Light switch
34 E Signal Beam throw adjustment Headlight beam angle adjust potentiometer
35 A Interface AHM/LM Trailer module (AHM)
36 E/A I/K-bus signal link Connector, I/K-bus
37 Not used
38 E Reversing signal Navigation control unit
39 E Reversing signal Electrochromic interior rear view mirror
40 Not used
41 E Brake fluid level Brake fluid level switch
42 Not used
43 E Headlamp flasher signal Turn indicator/low beam selector
44 E Signal, high beam ON Turn indicator/low beam selector
45 E Signal, rear fog light ON Fog light switch
46 Not used
47 Not used
48 Not used
49 Not used
50 Not used
51 E Signal, parking light ON Light switch
52 Not used
53 E Signal Beam throw adjustment Headlight beam angle adjust potentiometer
54 A Lights, terminal 58 EDC control unit
Before 09/98.
Not M62.
A3 Light module
Measuring notes
14 A Right front turn signal indicator Front right auxiliary flasher unit
Measuring notes
4 A Left front turn signal indicator Front left auxiliary flasher unit
Measuring notes
2 Not used
3 Not used
4 Not used
5 Not used
9 Not used
11 Not used
12 Not used
20 Not used
21 Not used
22 Not used
23 Not used
26 Not used
29 Not used
30 Not used
35 Not used
37 Not used
39 Not used
40 Not used
42 Not used
46 Not used
47 Not used
48 Not used
49 Not used
50 Not used
52 Not used
Fixed it at last, the I Bus comms wire that comes from the IKE to the LCM
was corroded, looks like it was just from constant rubbing off the car body.
Anyone that's removed a LCM before will know how tight these wires are crammed in.
I managed to get a hold of AUTODATA on a laptop also, it helped to located the correct wire.
Anyway, I cut out the offending wire and replaced it, and bingo, all my lights on the dash,
my OBC functions like door open, lighhts on, check rear lights etc....now work.
I now also have reverse light,
my tick tock and green arows work again, as do my front and rear fog and high beam inticators.
I'll do up a document and post it with my other thread on the car problems.
If I didn't get thi going myself, to be honest the cars days were numbered. I wasn't paying for
a new LCM. The car is too old to justify the expense.
I'm looking for the pins/wiring colours for a post 9/2000 touring LCM.  Unfortunately the links to the PDFs no longer work.  Any ideas?  Basically just need to know which one/ones run to the N/S rear inner and outer tail lights.
Dave
