duncan-uk
E28 535i and 525e Motronic non-start trouble shooting guide
yes I did,
I fallowed the instruction above and also from the link I posted earlier here.
I found my DME/ECU cracked.
Just take your time, and slowly check as described and you should find the issue.
unplugged relays and unplugged the spade connector on the crank sensor, wiggled fuses and it started straight up.... driving for 30mins and cut out again, got it home now..... and its starting again!!!
Yea its the silver one then, its clicking when i unplug it and put it back in with ignition on, is this a sign that its working? or can it still be failing?
£13 from bmw.
Relay changed and hoses to afm changed too.... Driving for 4miles and cut out again and it's still turning over.
Looks like I'm gonna have to start going through the list :/
Car wasn't starting so thought I would look at battery connectors, and guess what I see! On the positive terminal there is a nut on the opposite side to the clamp that holds a cable that's runs upto fuel relay and fuse box, that was so lose, tightened and it started first time, just ran for 10miles and no problems.... Re started drove more and seems fine. I'm pretty sure I found the problem! :D
