Followers 0
hass
TYRE CONTROL INACTIVE (POSSIBLE ABS SENSOR) NOW SORTED
4 posts in this topic
Hi
my tyre control light has been on for a couple of months now
ive done so much research into finding the problem but end up with nothing
basicly my system is the one which DOES NOT have the valve as a sensor
and from what i can understand is that the only other way of it getting a reading is via my abs sensor
i took the car to a bmw specialist and he had the car on the machine
the end results were that the nearside front signal was low
it came up 256 times that there was a fault in that side
now
ive checked all my tyre pressures a number of times
ive tryed setting it
but no joy
also i thought it might have something to do with the right hight sensor
but thats on the off side
my only other therory is the abs sensor
but i have no tracktion or abs light on
any ideas
thanks hass
How are you actually trying to reset it? Best way to do it i found was to turn the ignition on, reset it, then start the engine and drive away and it resets
cheers
I have the same thing, it just doesn't work no matter how many times I reset it.
I've given up, I have a pressure gauge in the glove box instead...
Hakon
Finally sorted the problem
it wasn't the abs sensor
I had poor conection in the abs multiplug
bit of wd40 and job done
took ages finding the problem but wen I found
the dws unit under the glove box I worked it out from
there
so peeps if u start having problems like I've had
check the abs multiplug
Followers 0
