sparky
Gearbox part numbers.
My box has given up the ghost. I believe from a earlier thread that the early 6 series had a close ratio H pattern box, Does anybody have the part numbers for this, and is it a direct replacement for mine.
My car is a 03/1987 E28 528ise manual. The box I have just removed is a GETRAG and part number 2600105091 (The bellhousing and box are one complete unit.)
Wow, the gearbox has broken! I would've put money on it being the linkages...
Good luck with the gearbox search, AIUI the 'H' pattern close ratio box was a very rare fitting even on the 6 series.
I know, I really thought it would be the linkage, but no such luck. going to get a linkage anyway whilst its all out. The breakers have a selection of boxes including one from a 635 csi, I might drop lucky on this one....
Now I'm confused. Checked on realOEM.com for box part numbers and none of them match the box I've just removed, unless I'm missing something?
01 RMFD-FIVE SPEED (OVERDRIVE) TRANSMISSION 260/5.27-NS 1 01/1984 23001220651
01 RMFD-FIVE SPEED (OVERDRIVE) TRANSMISSION 260/6.03-TAJE 1 01/1984 23001221327
01 RMFD-FIVE SPEED (SPORT) TRANSMISSION 265/5.53-AEU 1 01/1984 23001220610
01 RMFD-FIVE SPEED (SPORT) TRANSMISSION 265/5.45-HZ 1 01/1984 23001222446
ONLY IN CONJUNCTION WITH
-- RETROFIT KIT F COUPLING FLANGE 1 01/1984 23211222896
01 RMFD-FIVE SPEED (OVERDRIVE) TRANSMISSION 260/5.28-NR 1 01/1984 23001220650
02 ASBESTOS-FREE GASKET SET 1 23129065642
03 STICK-ON LABEL, TRANSMISSION OIL ATF-OIL 1 23111228008
The number on mine is 2600105091.
The breakers rang me back the other day and told me they have one in stock for £75.00. Might just take a chance, need to get mobile again very soon, the renault seanic just aint the same...
