USTBUTLER
E34 535 Imported
its grey on grey and auto!  Being SA, i really hope its been cavity waxed other wise it will be dissolving.  SA rust proofing was non existent compared to German built cars of this era
I kike this even if it is an auto. Although it has failed its MoT a few times since 2006 none of the failures related to rust or corrosion. Also it has not done many miles since the figure of 78563 recorded in 2006
K838SGCBMW 535
Close All
MOT history
Date tested27 June 2018
PASS
Mileage95,721 km
MOT test number4984 3700 6476
Test location
 View test location
Expiry date26 June 2019
Repair as soon as possible (minor defects):
  • Nearside Front Lower Suspension arm ball joint dust cover severely deteriorated (5.3.4 (b) (i))
Monitor and repair if necessary (advisories):
  • oil leak
  • Nearside Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
  • Offside Rear Brake disc worn, pitted or scored, but not seriously weakened (1.1.14 (a) (ii))
  • Rear Exhaust has a minor leak of exhaust gases corroded (6.1.2 (a))
  • nearside/offside front shock absorber sleeves come adrift
  • offside handbrake effort just met legal limit
  • offside sill damaged
 What are advisories?
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested30 March 2017
PASS
Mileage95,292 miles
MOT test number5871 7281 0863
Test location
 View test location
Expiry date29 March 2018
Date tested28 March 2017
FAIL
Mileage95,292 miles
MOT test number3017 0956 1383
Test location
 View test location
Reason(s) for failure
  • Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
  • Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
  • Nearside Headlamp not working on main beam (1.7.5a)
Advisory notice item(s)
  • Nearside Front Tyre perished and cracking on side wall
  • Offside Front Tyre perished and cracking on side wall
 What are failures and advisories?
Date tested25 February 2013
PASS
Mileage95,033 miles
MOT test number4572 7605 3083
Test location
 View test location
Expiry date20 March 2014
  • Nearside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
  • Offside Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
  • Rear Exhaust has a minor leak of exhaust gases (7.1.2)
  • Front Drag link end ball joint has slight play (2.2.B.1f)
  • Rear Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
Date tested24 February 2012
PASS
Mileage90,816 km
MOT test number3078 2555 2052
Test location
 View test location
Expiry date20 March 2013
  • Steering system has slight free play detected at steering wheel (2.2.A.1a)
  • Front Lower Steering column universal joint has slight play (2.1.5)
  • Nearside Front Lower Suspension arm has slight play in a track control arm inner bush (2.5.B.2b)
  • Offside Front Lower Suspension arm has slight play in a track control arm inner bush (2.5.B.2b)
  • Spare tyre defective
  • Oil leak
  • speedometer does not have a dual scale to show mph.
  • nearside front chassis rail slightly corroded, caused by hydraulic brake fluid spillage
  • rear exhaust box deteriorated but not leaking
FAIL
Mileage90,816 km
MOT test number3870 6565 2033
Test location
 View test location
  • Nearside Front Headlamp aim too low and too far to the right. (1.8)
  • Offside Front Headlamp aim too high and too far to the right. (1.8)
  • Oil leak
Date tested21 March 2011
PASS
Mileage88,103 miles
MOT test number3377 0018 1082
Test location
 View test location
Expiry date20 March 2012
  • Exhaust has part of the system slightly deteriorated (7.1.1a)
  • air filter tube split
  • wiper blades worn
Date tested13 October 2009
PASS
Mileage87,999 miles
MOT test number3545 5658 9402
Test location
 View test location
Expiry date12 October 2010
Date tested9 October 2009
FAIL
Mileage87,999 miles
MOT test number3028 9268 9207
Test location
 View test location
  • Offside Stop lamp not working (1.2.1b)
  • Offside Rear position lamp(s) excessively deteriorated so that it is not visible from a reasonable distance (1.1.A.3d)
  • Nearside Headlamp aim too low (1.8)
  • Nearside Rear Shock absorber has a serious fluid leak (2.7.3)
  • Front Suspension arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
  • Rear Sub-frame rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
  • Rear Exhaust has part of the system slightly deteriorated (7.1.1a)
Date tested8 October 2009
FAIL
Mileage87,992 km
MOT test number9018 2178 9287
Test location
 View test location
  • Centre Rear Statutory seat belt missing (5.1.1)
  • Offside Headlamp aim too high (1.8)
  • Nearside Steering locking device insecure (2.2.C.1g)
  • Offside Rear Sub-frame rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
  • Oil leak
  • rear silencer corroded.
Date tested24 September 2007
PASS
Mileage83,960 miles
MOT test number5033 9756 7252
Test location
 View test location
Expiry date28 September 2008
  • Damage to offside front body.
  • Petrol cover lose but not inscure.
  • Rear discs slightly pitted.
  • Rear axel bushs starting to perish.
Date tested13 September 2006
PASS
Mileage78,563 miles
MOT test number5536 4695 6243
Test location
 View test location
Expiry date28 September 2007
Date tested12 September 2006
FAIL
Mileage78,563 miles
MOT test number5317 2505 6242
Test location
 View test location
  • Front Windscreen washer provides insufficient washer liquid (8.2.3)
  • Brakes imbalanced across an axle (3.7.B.5b)
  • Front Brake pad(s) wearing thin (3.5.1g)
  • Rear Brake pad(s) wearing thin (3.5.1g)
  • Front Tyre worn close to the legal limit (4.1.E.1)
  • advised brake lining warning light on.
