domt101 0 Report post Posted February 9 I know the whole "lifetime fluid" in the transmission isn't correct and as my BMW E39 530i is coming up to 100k miles i want to do gearbox fluid change. Opie Oils suggest the Motul 75w 80 ( https://www.opieoils.co.uk/pv-166225-motul-motyl-gear-sae-75w-80-fully-synthetic-car-gearbox-oil.aspx ) and wanted to know if any has had any experience with this oil? I've heard it might not be great when the gearbox is cold? Any suggestion on the best oil to use/ experience with any manual transmission oils? Share this post Link to post Share on other sites
LukeH 52 Report post Posted February 10 I use Castrol syntrans B 75w in my M3 which I’d say is pretty similar, and that shifts ok when cold, and that gearbox is known for being a little obstinate when temperatures are low. The gearbox oil in my 530d has just hit 200k, so I’m tempted to see what it’s like after that mileage, it still shifts great but it must be well past it’s best by now. Share this post Link to post Share on other sites
Clavurion 377 Report post Posted February 10 Why not get the original MTF LT-2 (83220396705) from dealer? 1 eb88 reacted to this Share this post Link to post Share on other sites
oilman 0 Report post Posted February 11 On 09/02/2019 at 16:00, domt101 said: I know the whole "lifetime fluid" in the transmission isn't correct and as my BMW E39 530i is coming up to 100k miles i want to do gearbox fluid change. Opie Oils suggest the Motul 75w 80 ( https://www.opieoils.co.uk/pv-166225-motul-motyl-gear-sae-75w-80-fully-synthetic-car-gearbox-oil.aspx ) and wanted to know if any has had any experience with this oil? I've heard it might not be great when the gearbox is cold? Any suggestion on the best oil to use/ experience with any manual transmission oils? Another one we recommend is the Fuchs Titan Sintofluid 75w-80. Has been very well proven https://www.opieoils.co.uk/p-981-fuchs-titan-sintofluid-sae-75w-80-synthetic-manual-transmission-fluid.aspx Cheers, Guy Share this post Link to post Share on other sites
eb88 22 Report post Posted February 11 (edited) Don't muck about, see the attached, only use what the manufacturer recommends and not what you 'heard was good' E39 GEARBOX OIL CHART.bmp Edited February 11 by eb88 Share this post Link to post Share on other sites
domt101 0 Report post Posted February 11 On 10/02/2019 at 17:09, Clavurion said: Why not get the original MTF LT-2 (83220396705) from dealer? True, just feel like it's usually a rip off going to the dealers when you can get more or lest the same oil for much less Share this post Link to post Share on other sites
