Boon Ewe
F10 rim 19 inch question
Dear All,
Does anyone know if the below can be fit to F10 LCI 520i 2014 ?  rubbing ?
Front = 19 x 9j ET24, 255/40/19
Rear = 19 x 10j ET24, 285/35/19
(Wheel Style 231 from E65)
Many thanks.
5 hours ago, Boon Ewe said:
Dear All,
Many thanks.
Use this calculator: https://www.willtheyfit.com/
The F10 has M14 wheel bolts and the E65 used M12 so you may have an issue with the bolt not fitting through the wheel bolt hole.
Those tyres are going to put your speedo out as they will have a larger rolling circumference.
9" F10 rear rim is ET of 44. Your E65 wheel has 20mm less offset (offset is the distance from the centre of the rim to the hub mating face which throws the wheel further out. Add 12-13 mm for the extra rim width and the outer edge of the rear tyre on that E65 rim is over 30mm further out than before.
It's a big ask of your arches. Then you have the points Matthew makes.
I run E46 steel wheels on my F20 for winter;  the E46 wheel would have accepted M12x1.5 bolts originally, but the F20 M14x1.25 pass through there just fine. SImilarly I had my current BBS wheels on my old E90; M12 bolts on the E90, M14 bolts on my F10, and no fitment issues.
HTH
