whiskychaser
M54 3.0 Wiring blanking plug?
When I discovered the item in the photo, it was tucked up at the back on the inlet manifold. I have to say that at first I thought it may be a sensor. After doing some digging, I discovered it is actually a plug. It is not doing a great deal as the end you can see in the photo is blocked off and there are no connector pins on the inside. So all it is doing is keeping the dirt out
The car does not have the air pump. And it seems a bit of a coincidence that this connector is the same type and size and in the same location as it would be if it did have one. The wires leading to it are red/white and brown/white.
Can anyone confirm if they have the same redundant plug?
Edited by whiskychaser
