Tomcat
Coolant bleeding problem
So I'm on position 2, heater on max temp and fan low, both bleeding screws and expansion tank cap off. Tank 3/4 full.
What would cause the circulating pump to come on only intermittently, running about 5 seconds on, 30 seconds off. Every run it bleeds a bit of air, followed by a bit of coolant.
The circulating pump should come on and stay on. I'm really puzzled. What gives?
Which engine pal, petrol or diesel?
You can update your profile so it shows this here:
6 minutes ago, Tomcat said:
Car is a petrol 2.2l. Left it for half an hour and when I came back, it was pumping continuously. I wonder what that was...
With or without the engine running?
If ignition on, the coolant will circulate
