KiHe
What makes the belt to vibrate and resonate? 530d 2003
Hi folks, Im just new here and try to find some help to my problem. Have spent time and money already and without a solution yet.
The main problem is that the belt starts to vibrate and resonate causing a really bad noise when idle.
I have changed already all the pulleys and tensioners (SNR and INA) + the big vibration damper (SNR) + both belts (Gates).
Today we changed also the alternator and earlier a used power steering pump -> still no change.
It seems that noise comes from the belt when idle, because the belt starts to vibrate and resonate but haven't found the reason why. I made a small research that with same OE-nr 11232247890 there are many manufactures and also the diameter may change a little (150mm and 155mm). Any idea what causes the belt to vibrate so wild?
Picture below and short video
Are you sure you’ve got the right belt?
Could it be that you’ve fitted a bad tensioner at all?
Belts were changed by a garage so I hope they have changed the right one. It seems to be Gates 5PK 2063, which seems to be right one.
The same noise came also before with old tensioners and there were no change with the new ones.
I have also another new belts (Federal Mogul) in storage so I will try also those ones later on.
Edited by KiHe
Have you checked the water pump, that's the only thing that you've not changed.
Or take the AC belt off and check without
 As above, I'd check the a/c compressor, I've had a couple of Mondeos with failed bearings in the a/c clutch and both cars made a rattly drumming sound similar to that in your video.
Could
Plus 1 ... Water pump
