Dotcom1970
Pinout diagram of iPod Changer
I've picked up an official BMW iPod controller that would replace the CD Changer.  However, the pre-installation wiring has been hacked, and the power plug chopped off (the MOST optical leads are fine), so I don't know where the positive and negative power leads go vis a vis the Controller.  I have a replacement power plug and cables to hand, but just need to connect them in the correct place.  Can anybody advise the pinouts of the controller or take a photo of the power plug and leads in situ so I can reconnect things?
TIA
(Yes, car is already coded for iPod/MP3 playback)
10 hours ago, Rosie said:
They were designed so the plug for the CD Changer is a direct plug in.
so Pin 1 is RT/VI terminal 30 from Fuse 38 and Pin 2 is BR - earth/negative.
Brill, thank you
I had an odd one over the weekend, guy said he took the cd changer plug out as it no longer worked, the car has a MOST break fault logged. I couldn't find the wiring for the changer anywhere, all I could find with what looked like BMW loom tape was the optical leads and power plug without the main plug carrier taped right next to the MOST diagnostic port. I gave up looking after an hour.
Edited by GoNz0
