d_a_n1979
M57 running temps
Noticed my 730D seems to take an age for the dash to go black (engine upto temp); took over 60miles yesterday in the motorway down to Anglesey for it to do this
Using torque Pro, its running 74-78 degrees, so has a stat or stats failed/failing?
Suggestions on what to replace and with what from where welcomed?
Has to be the main stat or egr cooler stat Dan, usually was the egr cooler first but that is a very low temp. Egr is a fair bit easier on the m57 though from what i remember.
Oh, and check your fan clutch thing is working properly. Usually more of an overheating cause but you never know.
Edited by SuperDave
Cheers Dave
Have seen red the stats after doing a bit more searching on here (albeit on 530D cars etc) and EGR stat looks a 10min job, but going to get both stats ordered and will get my pal to sort the main one for me too
Car runs perfect otherwise, think it’s only just started playing up as it’s come up to temp readily before the other day
