Andrew S
5 40 or 5 30?
On a 530D is there any downside to using 5 40 instead of of 5 30?
I am sure there were comments about the lifters wearing on cold start when cold with thicker oil?
Would 40 make it quieter LOL?
Andrew
Thinner oil flows better and will reach components quicker after a cold start
Thinner oil causes less drag so will make the engine (marginally) more efficient
Thicker oil however will probably result in a quieter engine
However when we're talking about 20 year old cars it makes next to no difference - I wouldnt worry too much as the differences are small. If it seems to run better on 5W40 then just use that
The short answer to the original question is "no". I switched to 5W40 some years ago on my 525d and change the oil and filter every 6000 miles or so. The car is now on 227000 miles. I doubt that there is much discernible  difference between 5W30 and 5W40 in practical use but 5W40 is cheaper and we experience higher temperatures here.
Thanks All
My main concern was due to the fact that on my old E34 525 I have to have the followers replaced due to a couple of tappets that drove me made and the last thing I wanted to do was knock these ones out with cold starts with a 5w 40 oil. With 150k miles as said, there should not be an issue then
Andrew
