Piper
540i (2000) lacking power under 3000rpm
Took the 540 out and it seems down on power in the low rev range, not an instant shove like it should be.
In D, its not till I get to about 3k rpm before it starts to go like it should. Putting it on S makes it more responsive.
Vanos?
Check intake boots for splits; make sure MAF is clean/working correctly etc
Start cheap & work from there
When was the last time the plugs were changed etc?
Thanks Dan. 12 months ago.
Yes good idea.
Yes good idea.
Before you start spending money i would say check for vaccum leaks, take the car to a garage to get the intake system smoke tested, did mine for 25 quid and found two leaks which were causing my low power problems.
If the test comes back negative then start looking at vanos , sensors,coils etc
