SuperDave
G30/G31 Audio differences
Bit of exploration, the underseat central bass subs are no longer self contained pods - they're actually more like rigid enclosures with an open base that mate to the car body with the help of some thick non adhesive green squashy gasket material.
Effective volume of the sub enclosure is much larger as a result and no chance of any slimline 8" sub hitting the now non existent pod base. Clearance to the cover might be an issue though.
Existing central base speaker just lift out once the t20 screws are removed. Might be easier in situ as the central base pods are a bit of a pita to reinstall. Thick existing gasket makes resealing dead easy but its a few mm of clearance lost to the cover again.
Edited by SuperDave
