525-Jay 37 Report post Posted September 13, 2018 I need to change mine. I have the service manual which explains it. But I was just wondering if it's something that you can royally mess up and should only tackle it if completely competent? I'm not too bad with a spanner or 2 but I wouldn't say I'm an expert.... Share this post Link to post Share on other sites
pidgeonpost 684 Report post Posted September 13, 2018 I don't think it's too bad a job, but as I didn't have access to a ramp I bought the filter and got the local garage to do it. The filter proved to be the wrong one which would have been a real pain for me as I'd have had to reinstall the old one whereas the garage just sent for the correct one. Couple of videos on YouTube You can see the difference between the two filters - original on the right. 1 Doggzy reacted to this Share this post Link to post Share on other sites
jake13 404 Report post Posted September 13, 2018 It all depends what type of fuel heater you have. https://www.mahle-aftermarket.com/media/media-global-&-europe/products-and-services/technical_messenger/tm_issues_2011/tm_sheet_02_2011_e_neu_bearbeitet.pdf Share this post Link to post Share on other sites
dj1233 98 Report post Posted September 14, 2018 its not that hard TBH. Takes longer to drop off enough screws from the under panelling to get access to it! Share this post Link to post Share on other sites
keliuss 29 Report post Posted September 14, 2018 I agree with dj. There are DIY "how to's" out there. Find them and familiarise yourself with the process before starting. There's no need for a ramp either, a couple of axle stands will suffice. When I did mine I did not remove all the screws from the plastic panel/undertray to remove it either. I just undid enough of them to let it hinge/hang down from the center of the car to have access. Keliuss Share this post Link to post Share on other sites
-AJC- 4 Report post Posted October 18, 2018 525-Jay I've just done mine on the driveway. I found this video useful in explaining the process involved albeit the car in the video is not fitted with the under trays. They've made several video guides for the E60 which cover most of the serviceable items involved. As dj1233 and keliuss have said you just need a pair of axle stands and raise the nearside (passenger) side of the car. If your car still has the under trays fitted then you'll need to remove the left nearside tray to gain access to the filter. 1 keliuss reacted to this Share this post Link to post Share on other sites
