Dave21
Bmw 520d e61 2008 fuel pump problem
Hi all I’m new here so please bear with me lol
I’ve got a Bmw 520d e61 2008 lci was driving and a message came up on Idrive saying something about fuel pump then car cut out tried to restart but would cut out straight away now want start at all after I changed fuel filter and had a look at pump in the tank but is the pump in the tank meant to pump when the ignition is turn on? I.e without starting the car? As mine isn’t,when I changed fuel filter I put  ignition on while filter was off and no fuel came out of the pipe I’ve plugged laptop with ista+ and it’s saying fuel rail pressure too low any help would be really appreciated
Edited by Dave21
Hi I bought a 2nd hand in tank fuel pump but it still doesn’t pump with  ignition on still had same codes in ista+ so I bought a 2nd fuel rail with both  sensors I put that on and codes have gone but car still won’t start and there’s no fuel coming to  injectors can any one help I’m running out of ideas
Are the  sensors meant to be coded when replaced? Using ista+ I’ve tried to reset  fuel rail  pressure valve and it keeps saying reset  failed I’ve been at this for a few week now and I’m not getting anywhere I’m really  frustrated
