Tenorsax
Springs
Hi... Recently ordered H&R lowering springs to fit E39 523 saloon. Drop is 30mm front and 30 rear. Had a call from supplier asking if I am sure I had ordered the correct set up, as they felt my vehicle has a self adjusting mechanism at the rear. I'm confused. I was under the impression only touring had self leveling suspension. Please someone tell me that I can!! just change springs old for new without concern for leveling issues. I thought just a straight swap over.. I'm confused.... Help.... Please...
Put your VIN in realoem and it should tell you if you have SLS or not.  If it is still unclear, just have a look underneath. SLS will look like this:
 https://www.realoem.com/bmw/enUS/showparts?id=DD32-EUR-01-1998-E39-BMW-523i&diagId=33_0520
Stick this in the E39 tech section pal; you'll get better coverage and answers
However, unless your car has SLS/EDC or as you said, it's a touring on rear bags, then no, the springs will work fine
Edited by d_a_n1979
