Dakota
Door lock pin rattle - solved
So the door lock pin rattles away in my ear when ever the music is load. Guess I'll need to pop a bit of felt or insulation tape around it to dampen if down. Does anyone know if they unscrew, or does the door card need to come off to access them?
First world problems I know!
Edited by Dakota
Door card needs to come off.
Ok, so that was an easy fix.
Removed the door pin surround, they pop off easy enough with a trim tool, easier from.the outside of the car with the window down. Placed few small adhesive pads on the inside of it and popped it back on. Tested the bass, rattle 100% gone. Was so easy I did the passenger door as well. Happy days, I had actually turned the bass to me minimum to stop it before. Back to enjoying the music.
Hope this helps.
