Busterbvi
Wrong size rear wheels !!
Well I have owned the car for a good few months now and just discovered my rear style 66 rims are the wrong size ! Took the car to the local tyre shop to
swap the NSR tyre onto the spare which I wanted fitted to the rear as the rim is in much better condition. When fitted I noticed the rim was wider, a quick
measure across the rim lip to lip was 10in, all others are 9in ! So, anyone got a good condition 10in style 66 to sell me for the other side ?
Style 66s only came in 8J and 9J flavours (8 and 9 inch); if yours is deffo 10" then it much be a replica or it's been widened
Are you positive it's a 10" alloy?! Are you positive it was measured correctly?
You should have x2 8J alloys up front, x2 9J alloys on the rear
Edited by d_a_n1979
That's what I thought. Look at these pics, I have my hand through the wheel holding the tape measure hooked onto the inside lip.
Definitely not welded and wheel looks OEM.
NEAR SIDE FRONT
NEAR SIDE REAR  (Was the spare)
Edited by Busterbvi
Don’t forget the width (9j etc) is the internal tyre seat so the external measurement will be bigger. Looks like one of the rear has been replaced at some point with a front? Think saloons should have a staggered setup and tourings are the same all round.
As above, you need to measure them with the tyre off ;)
You need x2 8J and x2 9J ;) or you can go for a square set up, means you can rotate tyres then, if that's your thing and you can either have x4 fronts (8J) or x4 rears (9J) all round
6 minutes ago, Busterbvi said:
Thanks chaps, Any good reason the rears are wider than fronts on the Sport saloon ?
Rear wheel drive cars pal; wider tyre =  better traction and handling (apparently)
50 minutes ago, lufbramatt said:
Looks mainly. Fair enough on a rwd race car but not a 230bhp family wagon. The sports that came on style 37s have 265 wide tyres on the back, completely over tyred.
 I currently have 265's on the rear and it will not spin the wheels in the dry even with a V8's worth of torque, in the wet on the other hand....:wink:
