Simonr60
Battery discharge warning
Hi there.
So this morning my wife came in from work (works nights) and said when she first started the car this morning a high risk of battery discharge warning came up on the idrive, this is the first time and I've had a trawl of the internet and got a few different cause's, I still have a months warranty left on the car so hopefully can find the issue,
The car mainly does short round town trips, would the battery need a charge and would this need to be registered or is that only of the battery is changed.
It is a 2008 E60 lci 520d with 23k on the clock.
Many thanks
Si.
There's a heavy electrical/electronic load with these cars and short trips may not provide enough charge to recover what's taken out in starting the beast. You could try a long charge overnight which may help, or the battery may be dying. If its still under warranty that would be my first port of call though. There's no need for registering or coding if recharging, only if you fit a new battery.
So a quick update...
I came home tonight and put the car on charge (ctek charger) and the battery is quite low (still on charge now), anyhow I sat in the car and with the doors shut and everything turned off so it was quiet I could here what I can only describe as a low humming noise from the centre single CD drive/ control area it wasn't a cd spinning noise or buzz/ crackle/data noise so I'm not sure if it is the drive, could this be my possible battery drain if so what could it be..
Si.
That could be the car running checks. My old E46 used to open and close the blend doors every third time it was started or something when you turned the ignition off.
It might be worth getting the battery checked at ATS or somewhere similar, it could just be a weak battery. If you have a multimeter, you can do tests for a parasitic draw.
There are plenty of videos on youtube on how to do it, You'd have to give the car upto an hour to shut everything down after you turn the ignition off.
Edited by Deviant
Probably the climate fan sniffing the air temp, behind the small plastic grill above the rear demister button, often fills with fluff if you don't push a hoover/soft brush on it every now n then ;). Normally powers off when the car goes to sleep.
If you are charging the battery in the car, check the voltage across the battery is less than 15v (slow charge) or you may cause damage to other electrical components.
Edited by DarkHorse
typo's
Battery has now been fully charged...and so far haven't had the warning again...will keep monitoring,. hopefully that was the issue.
Thanks again.
If your IBS (intelligent battery sensor) is either unplugged or not working, the car will not optimally charge the battery based on usage. Apparently it charges the battery faster when it recognises you are doing shorter journeys. It may also be worth registering the battery once full charged out of the car, as it also will not charge to full capacity if it thinks there is an old knackered battery in there. I learned all this when I installed a new battery after buying my car and it made no difference, only sorting out the IBS and registering kicked the new one in to life.
Update...
So it has been a week and today the battery discharge warning came back on..
I'm thinking it must be a duff battery (probably original) gunna load test and report
Mine is the same, I cant leave the keys in for any length of time, or it wipes the date and time info in I Drive. I suspect I may well have an original battery, but it shows 12v off charge and over 14v whilst running.
I Googled it and it appears that it can be due to the IBS playing up. Bearing in mind that you do short trips a helping hand every so often either as a long run, or a charge of the battery should keep you going.
I'd happily give mine a new battery but with conflicting reports of it needing coding or not I think it's easier to sell the car and buy a horse.
Will get it checked out tomorrow...but I've just had a look and it is an original black BMW 80ah
It is a march 2008 lci,will this have the new type ibs.
Edited by Simonr60
Well it looks like the issue is fixed....it was the towbar wiring....looks like they took the feed for the split charge relay from the wrong place and this was keeping the relay live so kept waking the car up and draining the battery,just pulled the fuse coz I'm going away  but when I get back the towbar fitters are going to re-do the wiring...he knew as soon as I told him.
