duncan-uk
Mobile broadband temp set up
Long story short to achieve some building works we will need to move out of home for a couple of months.
I'll still be able to work from home and so can't transfer BB to rented property. Is there a reasonable mobile BB hub type thing? I.e. With a SIM card  one can give wifi to a number of devices?
suggestions welcome.
The Vodafone looks the sort of thing but i wouldn't want 12months
I might see whats coming up in terms of wifi networks and see if we can blag a go on the neighbours!
Or can one extend range of ones own wifi?
rented property will be about 50m form our own!
50 metres is quite a range to boost. Can you run an extension cable between the two properties, or would it cross a road or neighbour's property? Reason being, if you can, then a pair of Powerlines ethernet adapters might work, coupled with another wifi router in the rental place. I'm not sure how much it would degrade over that distance though.
If i can run a powerlead can i not run an ethernet cable? it would be over three gardens but we know all the neighbours so might be possible.
Wireless bridge, something like
https://www.amazon.co.uk/150Mbps-Wireless-Outdoor-Extender-Repeater/dp/B00HJUHX68
Bearing in mind your power may be interrupted due to the building works.
Some other bits here..
https://www.broadbandbuyer.com/store/wifi-links/wifi-building-links/
Edited by sshooie
