stu08
Boot Partition Trim Cover
Good evening all,
My car appears to have had the above part removed at some point. I found it loose in the boot today. This trim is fixed to the metal rear bulk head (if that's the right terminology) against the rear seats. When you open the boot it's the furthest metal surface facing you.
Does anyone know how this is fixed on? I have a feeling I'm missing some bits to fit it.
Also, can anyone tell me if the inside ceiling of the boot (not the lid) is also carpeted? This also appears to be missing on mine.
Thanks for any help.
Stu
Edited by stu08
25 minutes ago, stu08 said:
Good evening all,
Stu
I did ask the same question before , answer I got is that  the boot top has no lining
That's great - Thank you. I was thinking it may have also been removed as I found the other piece loose. That's good then, just one thing to fix.
Check out realoem.com for the part numbers of the bits that fix it. From memory there are 2 or 3 plastic press studs at the bottom under the boot floor cover and the top is held in place by the boot seal.
