fingers63
E28 528i willnt start
I used a hose to refill my wiper water bottle and them the car would not start a couple of hours later...my fuel pump ain't singing when ignition is switch on and the car just turning over fine but will not start can some help
528i, LE Jetronic. Could be anything but fuel pump relay is the obvious first place to look. Joining the three pins* on the relay socket to power the pump and injectors will get it going. It's the tall black relay by the fuse box, seven pins.
87 - red white
87b green violet
50 black yellow
Yes, but he probably doused the two ignition components next to the washer bottle. (One next to the ABS on the inner wing at the front and the other on the wheel arch between the reservoir and the strut turret).
