Lukai
Windscreen Wipers
I was just putting on some new windscreen wipers and somehow managed to snap number 4 in the image below. Now the drivers side wiper judders, I'm guessing this is the cause?
I just wouldn't of thought it would make that much difference...
Thanks,
Luke
I didn't notice that it made much difference on mine when I left it off temporarily. My driver's side wiper judders a lot even when its got a new blade. Maybe it was because I initially used an SWF one instead of a Bosch but I think clay-barring the glass will probably make the most difference.
That clip shouldn't make the wipers judder, as it's only there as an extra measure to hold the blade to the arm.
Also are you sure the blades are fitted properly, as the wiper blades for an E34 are quite difficult to get due to the driver's wiper arm having a "reverse-hook"? I remember getting a Bosch set from EuroCarParts and it was a straight fit with no problems.
And another thing about the judder, if the windscreen is cold/dry, then the juddering can happen for some reason - I occasionally get that on my driver's wiper blade on cold mornings as well.
Edited by Blackman
Thanks, the new wipers are a Bosch set from ECP too, so should be correct.
It seemed a bit loose without the clip, so I’ve ordered a new one so hopefully that will sort it.
I don't have the link to the tech note but there is a particular angle (I think it's 84 degrees for the driver's side and 87 for the passenger side) that the wiper arms are supposed to have. There's a procedure that describes using a protractor to measure and then set the angle (carefully with a pair of vice-grips). It may be that the arm's angle is slightly off causing uneven pressure against the glass.
Just a thought.
