mike.
Anyone know what this means?
Ran a diagnostics with carly after the DPF warning popped up and got the following.
Motor Control:
Engine / Motor
particulate filter system
 Code: 00480A
Glow plug cylinder 2, control
 Code: 004222
 Code: 00481A
I'm guessing I need to sort this for the car to 're gen. Any idea what sort of cost these parts may be? I had the heated going control replaced on my e92 4 pot a while back, and remember it costing quite a bit of labour
1 hour ago, Clavurion said:
Blocked DPF and one failed glow plug. Check exhaust back pressure and that coolant temp reaches at least 75 C so DPF regeneration is enabled.
Cheers. Had both stats replaced over Xmas so the cars reaching mid 90's. How do i go  about checking coolant temp and exhaust back pressure?
If it's an auto I suggest you check the temps again just in case :(
Edited by GoNz0
