-TARBY-
Vibration when braking... maybe my imagination
Hi all
This may sound odd and maybe I don’t even have an issue.
ive had my 2016 535d f11 now for a few weeks and driving it a fair amount and when the mrs lets me drive it I love it!
My question is based on maybe not being experienced with efficient dynamics. When I brake I ‘sense’ a slight vibration. This is around the 40 mph mark. When I brake at any other speed all is fine and when I brake really hard at say 60, it’s all good, nice and solid.
I also sense the vibration or road noise is present at the same speed after I take my foot off the brakes.
My questions..
  • am imagining it? Would there be other symptoms or brake wear or suspension gear issues?
  • Does the effiencieng dynamics braking do anything that could explain this?
  • maybe the road noise and vibration through my run flats is just normal?
the brake service is due in 3500K but I won’t wait until then if anyone here suggests I do have an issue.
thanks
Tarbs
Edited by -TARBY-
I am experiencing similar, only just perceptible.
At my recent service I was advised the inner pads on the front are down to 3mm. There is a noticeable lip on the inner discs.
Discounting wheel balance, I am expecting this to be resolved when I fit my new discs and pads.
Edited by bee
If there is a slight imperfection in the discs or pads, it might only make itself felt at certain speeds, thus frequency.
Could be slightly worn discs or pads or corrosion between the disc and hub.
A common source of vibration (steering wheel shimmy) under braking can also be due to wearing lower arm bushes.
Thanks guys. I have a trusty indie that I can bung some beer money at to check the brakes.
id hate to thing on a car that has only just passed its 2 year and done 21k that it would be anything else but serviceable break components.
But they can still wear?
Ive just been out in it as it was bugging me.
Deffo a shimmy felt through the steering wheel and I think my foot on the brake around 50 mph. If I’m doing 70 and brake hard it will shimmy at 50 etc.
no other issues, it drives like it should, handles and glides along.
gonna need to get it checked out.
One thing to check that has not been mentioned is wheel balancing I’ve had this on various cars I have owned and wheel balancing cured it, worth a check.
At that mileage its got to be tyre wear, balancing or some kind of uneven brake issue.
Issues 1+2 get checked with front wheels off, check and balance.
Issue 3 as you say ought to get checked with your brakes especially as its on 21k -is your wife especially  heavy on the brakes? because i thought most people on here got to 30-40k easily on front pads, rears at 20k very common but not the fronts. Maybe the fronts are binding slightly?
Edited by SuperDave
I would of thought if a disc is warped you would feel it most of if not all of the time, could be a wheel balance issue if its only happening at a certain speed
Edited by Markn47
Ok I took on the point on balancing
My local independent tyre place is top guy so he checked it all.
the front o/s wheel was out of balance by 80g and the n/s very slightly. He corrected them both.
He checked both front discs and there are still 1000s if miles left in them and the pads are about a 3rd worn. I had a good look too.
i took the car back out and I think it could be the out of balance wheel. I’m now hyper sensitive and I actually think the ride is hard and i pick up vibrations etc through so of the diobolical roads we have round here.
i thrashed the arse off it this morning.. zipping up to 80/90 and breaking so hard the abs kicked in.. breaking hard from 70/80 down to 40 and I don’t think the issue is there as it was yesterday.
so the jury is out!! But I’m not as concerned as I was.
i appreciate all your help. It doesn’t matter how long you’ve been driving or what you experience is mechanically, to have others help ask questions that prompt thought and suggestion is just why we are all here, so thanks
Tarby
Glad it sounds like you're sorted -  but - I will say ive test thrashed a one year old e90 for a colleague previously who thought his brakes were playing up and there was a wierd feeling he'd get when braking.... turned out to be worn RFTs! Nowhere near the limit either.
Still doing it. I thought it was ok but I was out over the weekend.
Im going to get all four wheels balanced for peace of mind and then I think I'll replace the front tyres. the backs are only a 1000 or so miles old.
Other than that its going back to the garage I bought it from for them to sort it.
The hubs on these cars tend to rust quickly and that can cause vibration as well. I had to kick both of the front wheels hard to get them off the hub when changing to summers last week, and the winters had only been on for 5 months. Both had quite a bit of rust buildup obviously. I also had a vibration when braking that gradually appeared over those five months.
Taking the wheel off and cleaning the hub with a wire brush might be worth a try.
Edited by Carlton
This turned out to be my tyres if anyone see's this going forward.
I had pirellis on the front and the dealer i bought the car from put new Falken's on the back
At the point where I thought I was going to have to start shelling out discs, i swapped the front and the back wheels.
The symptoms have gone.
I am going to wait for the pirelli's to wear out and then swap the whole lot out for Goodyears.
80g weight for wheel balancing is a lot of weight.   I would suggest that by this point your tyre would have gone out of shape and no amount of rebalancing was going to make it round again, thus your vibrations still being present until said tyre was replaced.
Glad you got it sorted and thanks for the update.
Quote
Quote
Thanks Enzo. I didn't realise that poor balancing can warm the tyre!!! You live and learn!
This isn't fixed. It has got worse. Vibration and judder at all speeds down to about 35 mph when braking. Hard braking seems to be ok.
I will be back with an update when the car has been looked at by BMW. It's booked in week after next. Car is only two years old and has full warranty. I could chase my tail for months replacing stuff.
I'll also do a full post on the whole saga when I get root cause.
I'm similar to you TARBY, had all new tyres and hunter alignment and balancing done.  Vibration whilst driving @ 70 - 80 have disappeared and the vibration when braking has been reduced allot but still present. All disc and pads were inspected and no lip wear etc.
Mine appeared about 3 months after I got the car. It wasn't there before. If I am honest I am hoping it will be something simple albeit expensive I am sure
Sure we don't have the same cars? :) That's identical to mine, starting happening not long after having the car and happens on light braking but not heavy.
Edited by roundy
It does sound like it. You will see I noticed it in March and thought I was going round the twist.
I don't get vibration when running just under braking. I know run flats are sensitive and not everyone's cup of tea but I have had them on all my BMWs.
I'll report back when the $tealer has had a look.
Closest I had was very noticeable vibration only on light braking - regardless of speed. Positive braking and not a thing.
On inspection I found barely any lip and around half pad life remaining. However, a very minor warp on the front left disc - I put it down to the missing air duct (not replaced by police prior to retirement) causing less effective cooling than the fully intact right front. When turned by hand the right disc turned cleanly but the left just dragged on one point on the disc.
Replaced both front discs and pads with ATE (stunningly easy job now) and braking has returned to smooth and true.
