Shoey88
LCI Tail Light Retrofit without Bruce Cables - Solved!
Hi all,
I wanted to share with you my experience of fitting LCI rear lights on to my Pre-LCI E60.
Just to be clear, I had considered the following before successfully carrying this out:
1) I didn't want the expense of buying Bruce Miranda cables
2) I wanted to utilise the Ricky brake effect
3) I didn't want the hassle of running extra wires from the LM2
4) I wanted to utilise the official BMW retrofit cables
5) I didn't want to change my adaptive bi-xenons, I intended to keep the Pre-LCI ones
6) I wanted to the leave the factory wiring in the car untouched
Firstly, I retrofitted the LM2 light module to my 56 plate E60. There are plenty of guides discussing this, so I will assume you already have the LM2 light module retrofitted or fitted as standard (from the later Pre-LCI models) as this is not possible with the LM1.
I had to purchase the LM2 with adaptive functionality but this coding can be done with any LM2. I got the LM2 for £85 off eBay, the ones without AHL can picked up for a between £40 and £60.
There is a little bit of pin swapping required on the harness bought from BMW. The part number for the Retrofit harness is 61120432110. I ordered it from BMW directly and it cost £25+VAT. I managed to pick up some LCI rear lights off eBay for £130 delivered also.
OK let me discuss the coding first as this will make more sense when I discuss the pin swapping on the retrofit harness.
This assumes you are familiar with NCSEXPERT also, again there are plenty of guides on this. In the LM2, you need to change:
KALTUEBERWACHUNG_BLK_H_L from aktiv to nicht_aktiv
KALTUEBERWACHUNG_BLK_H_R from aktiv to nicht_aktiv
WARMUEBERWACHUNG_BLK_H_L from aktiv to nicht_aktiv
FEHLERMELDUNG_CC_BLK_H_L from aktiv to nicht_aktiv
FEHLERMELDUNG_CC_BLK_H_R from aktiv to nicht_aktiv
all of the above are in relation to the LED indicators and this tells the LM2 to not carry out cold or warm bulb checks and not report any check control messages in due course.
Lastly, you need to change:
PWM_ANSTEURUNG_BL from wert_05 to wert_02 and wert_04
This disables the brake light being used as a side light (I will explain this shortly). Essentially it changes the voltage output from 6.598v to 0v
PWM_ANSTEUERUNG_RL_33 from wert_05 to wert_04
This increases the tail light voltage from the default 6.598v to 100% (around 13.8v)
PWM_AN_NSL_SL from wert_02 and wert_03 to wert_01
This disables the fog light from being used as a side light by reducing the voltage from the default 4.699v to 0v
We have to disable the fog light and brake light as side lights as we have increased the voltage on the side light to 100% therefore you wouldn't be able to tell when pressing the brake or putting the rear fogs on as the brightness wouldn't change.
The bulb checks on the Pre-LCI as standard for the inner side lights are turned off by default so we don't need to edit the coding on these.
The plan is to use the increased side light voltage to power the LED rods to match the OEM LCI lights brightness. The brake light will be utilised in the fog assembly and the fog light will be placed where the brake light was before (the outer light). The inner side light will no longer be powered as that is what we are using. This gives us the Ricky brake effect.
In order to achieve this the following pins need to be swapped on the retrofit harness:
Left hand side rear light
Pin 1 = ground - OK
Pin 2 = fog light - move to Pin 6 brake light
Pin 3 = Reverse - OK
Pin 4 = Side Light - OK (when you get the harness, this linked to Pin 7 on the LCI connector, this need to be moved on the LCI connector side to Pin 4 (LED rods) as we are no longer using the side bulbs
Pin 5 = Indicator - OK
Pin 6 = brake light - move to Pin 2
Right hand side rear light
Exactly the same as above but Pin 4 needs to be moved from Pin 7 on the LCI connector to Pin 2 on the LCI connector side (LED rods)
And that's it!! Plug your lights in with 0 errors and give yourself a pat on the back as you have saved yourself £200+ on buying Bruce Miranda cables and you have a working solution with no need for resisters or relays etc.
It took me a few attempts to get the coding right but hopefully this will help a few people who are interested in this upgrade. If you have welcome lights coded as well these will light up the LED rods now as well instead of the halogen lights which look a lot smarter.
Plus remember: When you sell the vehicle you can code it back to defaults and just plug the old lights back in too! I will upload some pictures at the weekend of my wiring etc. With a before and after.
Jamie
Many thanks for the write up, I hate the way the brake light overwelm the tail light rods
