Rich b
B47 f10 2014 fuel economy
I recently bought a 2014 f10 with B47 Engine 84k miles.  Generally pleased with car but noticed the fuel economy doesn’t seem as good as previous 5’s with the old n47 engine.  After my last tank i got an average of 43mpg(calculated trip said 40mpg), this included 2x 200mile motorway trips and the rest was my 50mile round trip commute (2/3 motorway). I drive really conservatively and with previous e60 n47 would return 50mpg on my daily commute.
i checked for p codes using Carly and it returned: p22ae/284e00
I booked it in at the dealer but they said there was no error???
Just wondering if anyone else has any experience of this issue, not much on the internet as this is a relatively new engine.
i also checked the dpf and it’s fine, soot mass 18g and ash mass 34g.
any advice greatly appreciated.
It just makes sense to add valuable feedback to a thread already running than start a new one. This thread was started some years ago and has some great contribution and data on it that is a shame to waste given all the effort having gone into it.
9 minutes ago, nashdm2 said:
There is a huge topic already on this subject guys. Its called B47 MPG I think, take a look and add comments to that one please.
Just tried searching b47 then b47 mpg and both returned zero results...
Hi
ive recently bought one, mines a 2015 with 20k on the clock and the first 900 odd miles I’ve managed 45.5 mpg on mainly motorway driving but always in sport mode as I find the others sluggish,
thought that hat was pretty decent.
My commute is 1 mile to the motorway, 24 miles motorway driving, however the smart motorway works means max 50 mph, then 2 miles off the motorway to work.
i don’t use it over weekends as I’ve a weekend car to enjoy.
the best I’ve got was in eco pro and I managed 51.2 mpg for a day but that was really really being a tight arse and driving like a 60 year old granny
All you needed to do was put a link to it.....
I've had mine 6000 miles now and have averaged a true 44.5mpg. That is mainly long trips, albeit a lot have been to Cornwall, fully loaded plus going up and down those constant steep hills is an mpg killer. I can only beat 50mpg if I stick to the motorway speed limit on the GPS and there are no adverse winds.
I got 53mpg once but that involved a 70+ mile drive at an indicated 65mph. It won't be repeated ...
I think I put in the other thread that, essentially, the car is giving me about 3mpg less than I had guessed it would. I didn't buy it for economy, which is just as well.
My c70mile round trip commute (mix of mainly country roads and dual carriageway) gives me 50mpg average if I drive 'conservatively'.
Last fill-up I did 740 miles to the tank until zero range.
Edited by bee
Hi thanks for the info, there is no way I could achieve 740miles.  I really do think there is either a calibration issue with early cars or the pcode is triggering some other form of fuelling.
59 minutes ago, sshooie said:
I average 32 with my 2011 530d....
Is that all you can manage?
Got nearly 33mpg out of mine today.
Heated seat on, air con on, half term traffic jams.
Just saying.....:P
Hi Rich b,
I'm also getting the error code P22AE from my B47 F11 520d. The car is used (60k miles) but is new to me. From what I can find online, this could be to do with the O2 sensor after the cat. It may not be the sensor itself (possible issues further up-stream) but if the sensor is faulty, the car would need to run rich by default as it has no or incorrect air/fuel mix data to go by, therefore the MPG would be low - mine is around the 29-33 mark for a mix of A road and stop-start city traffic, which I think should be higher (avg. 25mph). It went down as low as 24mpg on one stop-start run (avg. 11mph), and I don't really have a heavy left foot.
I'm going to get mine checked out in the next few days and will hopefully report back.
The F10 and 2.0 diesels are shocking poor on economy.
I averaged just over 40mpg in (lets call it) 12 months of ownership. Just not a good match in that car for some reason.
My G30, same engine, avarages 45mpg happily. On a long run, 400 miles at motorway speeds, happily did over 58mpg on cruise control.
So, just got back from the garage and they tell me that the oxygen sensor after the cat is indeed, dead. They have ordered the replacement and are fixing it under buyers warranty (as it is less than a month old and this issue was present at purchase). I expect them to carry out the work in the next few days, and from what I understand, the MPG improvements after such fix can take a while to bear fruit. I'll let you guys know what happens, as this is the closest thread I've found to solving my problem, so maybe it can help others.
After over 8000 miles, I have settled to an average (measured, not computer) of 44.5 MPG. Most of my trips are longer journies. A number are 3 or 4 up down to Cornwall, where the economy is hit by all the hills. I do the odd very short town trip as well.
On my regular, weekly 75 mile out and return, I get 46-53mpg, mainly wind dependent. This is driving mainly in Comfort with cruise control set at about 73-74mph (which is a true 70mph). It seems that any speed above this has a big negative effect on consumption.
I stick by what I said a few months ago: The car does about 3mpg less than I thought it would do before buying it. It doesn't particularly worry me but it is a bit galling to find it is less economical than it's predecessor!
