-TARBY-
e61 - tailgate top glass panel popping open
Hi All,
I’ve done a bit of searching and I have a better idea of what ‘may’ be the problem but wanted to ask in a fresh thread.
Recently the car has developed a symptom of the top glass panel in the tailgate popping open unexpectedly. It goes like this:
1. Tailgate and top glass closed - unlock the car to get in
2. Get in the car, ignition on and fire her up
3. About 5 seconds after the car has started I hear a clunk and a click and the top glass panel of the tailgate has unlocked. The interior lights are on.
4. No errors.
5. With the car still running I get out and close the glass panel, get back in and all ok.
6: drive off
Things I have observed
It was intermittent for a week or so, now it's everytime
If I lock the central locking when the ignition is on, before I start the engine, the panel stays shut and I can drive off as normal
The switch in the glass panel appears to work when I press it I can hear the lock unlocking. It all sounds firm and direct.
The rest of the tailgate is operating as it should.
I don’t have any other issues. I know the wiring on the e61 in and around the tailgate is suspect and many have had to replace it but I don’t get any other usual reported symptoms.
Is there anything else I should check? Fuses? Relays? Is the switch a suspect?
Much help appreciated before I have to get it looked at.
Tarby.
the wires from the switch are very small and often the 1st to break unfortunately. Just because things seem to be working ok doesn't mean the insulations broken away inside the loom behind the hinges, sometimes taking a bright torch and shining through the hinge to the wires can show the impending doom to prompt a repair before things get really bad.
Posted this for someone else not too long ago, applies here exactly the same.... it might not be the wiring at the hinges:
Check the glass release button. They are only a 'make contact' type switch, momentarily connecting two wires but they have a tendency to remain 'closed'.
You could carefully pop the cover off the button and clean the circuit and foam button with concact cleaner, but be prepared for a flying plunger and spring!
I did this for my brother and it's been behaving for a couple of months.
I hope this helps.
My tailgate glass popped open twice, then never opened again. It was the button, i changed it and all was fine..
There are two wires in it and if they short together the glass opens. So if it's not the button then you have wires shorting out at the top which would have me taking apart in case other wires fail and short out
Update - symptoms have progressed to warning lights on for tailgate, reversing and fog light failure. Also I took the switch apart and cleaned it. The switch is working fine.
as the weather improved Sunday the errors disappeared which is exactly the symptoms of cracking cables.
I’m going to order the looms and replace the cabling.
I’m going to document and take Images of the whole thing.
Cables ordered
http://www.sencom-kabeltechnik.de/index.php
Navigate to BMW and the various cables.
Ive ordered the full set £150 ish.
My mate, who has done this exercise, before got his from here.
I plan to do the job next weekend and I will take pictures and document for future ref.
2 hours ago, -TARBY- said:
Cables ordered
That looks like a nice kit
On ‎13‎/‎02‎/‎2018 at 9:44 AM, -TARBY- said:
Cables ordered
Thanks for the Link, I have just ordered the full set to repair mine.
It was done a few years ago by an Independent but Its never been right, so I figure I`ll repair all the cables Left and right.
I’m not going to be able to post pics or a DIY on this now as I’ve sold the car and they are going to take it with all its alments!
i have a full kit as per the link I posted if anyone wants to buy it off me for £150 (cheaper than what I paid) with free postage. Let me know!
61 12 162Installing the repair wiring harness of the tailgate and rear window on the left
1MG7fLt
Special tools required:
1VnXDFhlio Important!
Repair wiring harness represents the highest vehicle specification. Secure cables that are not needed to avoid noise.
Read and comply with notes on handling wiring harnesses and cables.
Installation note:
Use suitable tool for repair wiring harness.
1VnXQFZYDa The components listed below can be assigned to the corresponding wiring harness:
Left wiring harness: Right wiring harness
Aerial diversity aerial amplifier Aerial diversity aerial amplifier
Hose pipe washer jet Additional brake light
Luggage compartment light on tailgate Number plate light
Left rear light, tailgate Right rear light, tailgate
Rear window locking Rear wiper motor
Tailgate/tailgate lock Button for tailgate activation
  Switch for automatic operation of tailgate
1VnXMC9mOc Necessary preliminary tasks:
OMil4St
Lift out speaker cover (1) at points (2) with special tool 00 9 341 .
Pull out and remove speaker cover (1) from moulded roofliner (3) in direction of arrow.
OJtqV7c Installation note:
Tabs (1) and locks (2) of speaker cover (3) must not be damaged.
Make sure speaker cover (3) is completely engaged in moulded roofliner.
Ibd3C8cD Release screws (1). Remove support (2) for rear speaker and disconnect plug connection behind.
CtJmJKm7 Note:
Tailgate shown removed here for purposes of clarity.
Release expanding rivets (1).
Remove cover of tailgate hinge (2).
Dcr48mk7 Release expanding rivets (1).
Dw2PqQge Important!
Take off protective cap.
Mask off area (1).
There is a risk of the rear window slipping off when the nuts (4) are loosened.
Unlock plug connections (2) and disconnect.
Remove cable (3) from guide toward top.
Unscrew nuts (4).
Release screw (5).
Pull out retaining plate (6) in direction of arrow.
Installation note:
Make sure cable (3) is correctly routed.
Make sure retaining plate (6) is correctly seated.
DwNu9ggJ Installation note:
White marks (1) on wiring harness and hose pipe must be visible as shown.
Make sure retaining plate (2) is correctly seated.
Adjust rear window.
DwLiHO4Y
Release screw (1).
Remove retaining plate (2) in direction of arrow.
Unlock and remove wiring harness brackets at hinges (3) with a suitable tool.
DwJARzx0 Installation note:
The white marking (1) on tailgate of wiring harness must be visible as shown.
Make sure wiring harness bracket (2) is correctly seated on hinges.
DwPFoEnK
Unlock plug connections (1) and disconnect.
Unclip wiring harness in area (2).
Feed wiring harness (3) out of tailgate (4).
Installation note:
Make sure wiring harness (3) is correctly seated and routed.
DwCyQJoc Slip in wiring harness (1) toward the inside.
Ctpqtog5
Release screw (1).
Remove rubber grommet (2) in direction of arrow.
Feed out wiring harness (3).
Installation note:
Make sure rubber grommet (3) is correctly seated.
Important!
Do not cut through aerial line and hose pipe!
DwJyXFY2
Disconnect wiring harness (1) in marked area (2) and remove insulation.
Remove insulation from hose pipe and aerial line (3).
Strip insulation from individual cables with insulation stripper recommended by BMW.
FmJOyWv2
For vehicles up to production date 03/2007, the rear light must be converted for repair wiring harness of connector:
Unlock contacts on 4-pin connector (1) with special tool  61 0 314 and pull out of connector housing.
FmREKAq4  Tie back grey-green cable (1) as shown and secure with insulating tape.
FmJGJLMc
Connect cable (1) with supplied three-pin connector housing (2):
Pin 1: White/Yellow
Pin 2: Brown
Pin 3: Black/Yellow
Lock connector housing (2).
EXNC2sK8
Crimp individual cables with special tool 61 4 343 (also applies to 61 4 328) and pin them into 12-pin and 4-pin connectors according to the table.
Connector (1) 12-pin Cable colour Connector (2) 4-pin Cable colour
Pin 1 (from production date 03/2007) Grey/green Pin 1 Brown 1.5  mm
Pin 2 White/Yellow Pin 2 Brown 2.5  mm
Pin 3 Yellow/black Pin 3 White/brown
Pin 4 Yellow Pin 4 Red/yellow
Pin 5 Grey/brown
Pin 6 White/brown
Pin 7 Brown/red
Pin 8 White/red
Pin 9 White/brown
Pin 10 -
Pin 11 -
Pin 12 -
IboIaMnq Disconnect connector (2) from grounding cable (1) of rear window aerial.
Ibj8Sr8x Crimp plug-in contact (2) to ground cable (1).
IblWqyZf Pin ground cable (1) into 4-pin connector at pin 2 ) as illustrated.
IbhQlOms Plug together connectors (1) and (2) for rear window aerial.
IbrYVlz8 Insulate repair area (1), as shown, using the supplied noise tape and insulating tape.
IblDAbFI Slide hose pipe (1), as shown, through the new rubber grommet.
IboQYM7Y Install rubber grommet (1) as illustrated.
DcsuQxcd Installation note:
Insulate wiring harness with the supplied insulating tape in connector area (1).
Insulate wiring harness, route it in the form of a loop in area (2) and fasten it.
61 12 164Installing the repair wiring harness of the tailgate and rear window on the right
1MG7fLt
1VnXKlQbiq Important!
Installation note:
OMil4St
CtJmJKm7 Note:
Removal of the left cover is described here. The right cover is removed in the same manner.
CtAidaQk Note:
Remove cable (2) from guide toward top.
Installation note:
Make sure cable (2) is correctly routed.
Dcr48mk7 Unfasten and disconnect expanding rivets (1)
CtJBYox5 Important!
Mask off area (1).
There is a risk of the rear window slipping off when the nuts (2) are loosened.
Unscrew nuts (2).
Release screw (3).
Pull out retaining plate (4) in direction of arrow.
DcvnXBSI Installation note:
White mark (1) of rear window wiring harness must be visible as shown.
Adjust rear window.
CtM897VK
Release screw (1).
DctjVGsE Installation note:
The white marking (1) of the tailgate wiring harness must be visible as shown.
CtFCvlSn
Unfasten plug connection (1) and disconnect.
Installation note:
Make sure wiring harness (3) is correctly seated.
CtwrWrQA Slip in wiring harness (1) toward the inside.
Ctpqtog5
Release screw (1).
Installation note:
DcuhQEiQ
Disconnect wiring harness (1) in marked area and remove insulation.
FmJOyWv2
Up to production date 03/2007, rear light must be converted for repair wiring harness of cable connector:
Unlock contacts on 4-pin cable connector (1) with special tool 61 0 314 and pull out of connector housing.
FmREKAq4 Tie back grey-yellow cable (1) as illustrated and secure with insulating tape.
FmJGJLMc
Pin 1: Red/yellow
Pin 2: Brown
Pin 3: Yellow/white
EXNC2sK8
Individual cable with special tool 61 4 343 (also corresponds to 61 4 328)
and pin into 26-pin connector and 4-pin connector according to table 2 on the right.
Connector (1) 26-pin Cable colour Connector (2) 4-pin Cable colour, cross-section 2.5 mm
Pin 1 Yellow/white Pin 1 Black/green
Pin 2 Yellow/Red Pin 2 Brown
Pin 3 Grey/yellow Pin 3 Red/white
Pin 4 Red/white Pin 4 Brown
Pin 5 White/blue
Pin 6 White/violet
Pin 7 Blue/yellow
Pin 8 Brown
Pin 9 Brown
Pin 10 Black/Yellow
Pin 11 Brown/blue
Pin 12 from production date 03/2007 (optional) Grey/yellow
Pin 13 Grey/brown
Pin 14 Grey/black
Pin 15 Violet/red
Pin 16 -
Pin 17 (optional) Grey
Pin 18 -
Pin 19 Red/yellow
Pin 20 -
Pin 21 -
Pin 22 -
Pin 23 -
Pin 24 -
Pin 25 -
Pin 26 -
DwE2TNR8 Installation note:
Note:
If once the repair has been carried out it is not possible to unlock the tailgate and the side lights (only with vehicles from LCI) on the right-hand side do not work, swap the grey/yellow cables at pin 3 and pin 12 round.
Note:
When installing the individual cables in the 26-pin connector, a ground cable cannot be assigned separately. Make sure that this ground cable is crimped together with a second ground cable on one pin.
