sams255
F11 530D oil Level
I have had my F11 530D since April 2017 and with 2 oil changes under its belt since I purchased it, it has been ok when it comes to the weekly check on the oil level. Since its last service 5,000 miles ago I have noticed it is starting to consume oil now it's in the middle of min and max. I know with my Audi A4 it would consume oil between services, but for the last 15k miles I had this car the oil level has not dropped and only now I am noticing it. any ideas?
What age and mileage is on the car?
Its normal for modern engines to consume some oil.
In the days of M54 engines acceptable oil usage was up to a litre per 1,000 miles.  According to BMW!
Make sure you check the oil when the engine is fully up to temp (as per BMW recommendation). There is big difference in height between cold and hot.
Have you ruled out a leak? With all the engine covers these days a leak may not be obvious until it fills up the covers and overspills.
I had a leak from transmission oil cooler lines on my Senator, didn't know until it filled up the underbelly and dribbled out when I parked on a slope......
it was only serviced by the dealer 5k ago there doesn't seem to be any oil around the engine bay or dripping from the tray at the bottom.  I suppose just monitor it for now. 5w 30 is that what i need or 0w 30 ?
Either, as long as its to LL04 spec you will be rightly.
OW oil will make it slightly easier to start the engine on cold days but here in the UK its really not an issues if its 5W or 0W.
As Andrew said. And per my post from yesterday:
