gorba2000
Central locking remote&manual stopped working.
The wizard is back.....
is the boot carpet wet at all? Or even damp in a area that you wouldn't of  thought it could be?
Is it coming through a wheel arch?
What about your jacking points? Are they intact? Is I've read somewhere that if/when they fall off water runs along the body and finds its way into them. This could be the source and it could take forever to find?
Have you got a ramp or jack the car up and inspect the floor of the car for cracks/damp patches!
This is starting to sound like you need a few dry days in which you sell the car fully working.....
I have no access to a ramp, but had peek underneath yesterday and the bottom of the petrol tank on the right side did seem damp.
I have had the boot floor lifted for the last 4 days, to easily check water levels. But previously the boot carpet was bone dry, so waters definitely not coming from above, so must be side or underneath. Surely though, if the water was coming in from wheel arch the water would be filthy? The water in my boot well is clean.
Jacked car yesterday and jacking point seemed fine, although must admit I never paid much attention to it.
It's a tough one as water finds the path of least resistance and it could be in the most unusual place that you could think of, or it could be right infront of you and you can't see the wood for the trees (so to speak)
Don't give up, I'm sure you'll find it!
Keep us updated
Ok, source of water ingress has been located, hallelujah!
The rubber seal around the petrol filler cap has perished.  As water level rises it gets behind the seal and spills over the lip, where it then travels down a small hose and drips/pours out into the bootwell.
Does anybody know if you can change these seals and is it an easy job? Or does anyone have another solution which works?
At the moment I'm not able to confirm 100% that this is the cause of the electrical gremlins . I just sure hope so!
Edited by gorba2000
A smooth ribbon of silicone sealant should do the trick on a temp basis...
On 20/01/2018 at 11:49 AM, BarryM said:
I had my remote stop working along with the boot micro switch earlier this year, turned out it was the boot wiring in the rubber concertina where it feeds into the car so worth a look there
 Where abouts do you mean Barry ?
So the water pooling in the boot from the fuel cap is annoying, but not the cause of my gremlins. I will be putting a line of silicone to stop that soon enough (when I remember to buy some silicone). That particular ingress isn't going anywhere near my electrics as there's a hose directing it below all the electrics into the bootwell.
So I'm thinking it's from somewhere else, hence my query to BarryM. I did look at the wiring which runs along the roof and into the boot hatch by the hinges. They were ever so slightly damp, but the wires didn't appear split anywhere, so should be fine. It was a pain in the backside getting the black plastic housing back on!
Edited by gorba2000
This should help to show how my wires frayed
Nasty, hope that's not the case with mine looks like a pain to sort. Did you notice intermittent faults with your central locking prior to it stopping (I.e as they were perhaps starting to go?)
Anyone know where the equivalent wires would be on my touring?
