Dave is right. The 2 filters are accessible from underneath behind the glovebox. You'll need a stubby Torx screwdriver to get the screws out closest to the bulkhead due to the angle of the carpet/bodywork. Also, there is a drain pipe connected to the cabin filter cover that must be disconnected and reconnected once done. Get charcoal activated Mann filters from the bay. From BMW they are about £90 per pair. When you reassemble be gentle when tightening the screws as the cover's screw holes are quite fragile. My next filter change will require a replacement cover as the ham fisted mechanics at BMW have screwed it together so tightly there isn't much plastic left for them to attach to.
19 hours ago, nashdm2 said:
Its up behind the glove box I think doc Doc. Check out you tube see if there are any vids which detail how to change, but, its not that hard I dont think.
Cheers, my friend.
No dark arts needed then.  Phew!
B)
As ever - great tips, and very helpful.  Thanks, Matthew.
All the best to you and yours!
I will follow your tips assiduously.
~C
~C
Hi C.
This is definitely one of the easier DIY services you can do. Good luck.
B)
No just a Torx screwdriver bit! It's a dark tool.
Check out Realoem for your part numbers.
http://www.realoem.com/bmw/enUS/showparts?id=FR72-EUR-01-2013-F10-BMW-535i&diagId=02_0080
Part 4 is your cabin filter.
Eurocar parts is also your friend for bits too as it's a good source of reference before tracking them down cheaper online.
You can always try Cotswold's if you want genuine.
Thanks, Andrew.
I love how the community is rallying round one of its less mechanically-gifted and rationally-minded brethren.
Your care-in-the-community approach is heart-warming.
Now...what's a screwdriver bit?  Me mind boggles, like.
:huh:
18 hours ago, Dr Taylor said:
Thanks, Andrew.
:huh:
We are all here to help each other!
Torx Screwdriver bit.
https://www.drapertools.com/product/66429/T15-1-4inch-Hex-Draper-TX-STAR-Insert-Bit-25mm-Long-x-2
Goes in a bit holder that you fit onto your ratchet from your socket set, as Matthew said there isn't room to wield a screwdriver.
You can buy them in sets too.
1 hour ago, IINexusII said:
A massive saving of £76.99!
Thanks for the link.
Edited by 535i Andrew
Just replaced the cabin filters with Mann units from Eurocarparts.
This and other write ups really helped. The You tubes I saw seemed more complex, probably because they were LHD.
Didn't have to remove the grey drain tube.
When reattaching the inner panel covering the filters, it helped to put the four screws partially into the panel before offering it up and screwing them in. Also helped to have my daughter's make up mirror to get a good look at where the screws are!
Brake fluid change due in March but I'll leave that to the garage. £81 BMW Value Service seems reasonable.
I managed to do the job in the end, and I agree that YouTube vids can be misleading.  I, for example, thought I would be disconnecting an airbag in order to replace my filters.  I did not, thankfully, have to do this.
Cabin cleaner and a little less prone to indoor fogging now.
REJOICE!
